Results 1 to 32 of 32
    Senior Member Three Rings SoFarGon's Avatar
    Jun 01 2010
    North East
    High flow cat vs test pipe
    What do you guys run? Why did you choose what you chose? What are the benefits of each? What do you recommend?
    Senior Member Three Rings eastcoastjettin's Avatar
    Dec 26 2007
    MA
    not to be the dick, but this topic has been covered over and over. search is your friend.
    [2018 Ibis S6] [1972 Plymouth Duster 340]
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    test pipe=illegal but if your state doesn't do emmissions, who cares
    cheap
    HFC= Legal and expensive
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Jun 01 2010
    North East
    Quote Originally Posted by makav3li View Post
    cheap
    Performance wise?
    May 06 2010
    Ellsworth AFB, SD
    both about the same i'd say, test pipe i'd assume gives a little more performance because there is no restriction whatsoever, but nothing you'll really notice just driving the car.
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    hfc is arguably legal and i can attest to that...
    Veteran Member Three Rings wildbill's Avatar
    Jan 25 2010
    work
    search button
    nearly identical, all turbos need some backpressure, test pipe is very small to create, hfc is obvious why it creats backpressure
    depends on state if its passable, some do not use sniff test
    no real need for either unless running more than a chipped car
    boost. a new band aid by Johnston&johnston
    Veteran Member Three Rings 9Hooker's Avatar
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    not to mention the AWFUL raspy sound associated with just a test pipe. no one has mentioned it (surprise). it's noticeable, and from outside the car even more so. i laugh at cars i see drive by (4cyl) with no cat.
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by 9Hooker View Post
    +1
    Jun 01 2010
    North East
    So you guys recommend the hi flo cat over the test pipe? My options r 034 hi flo cat/test pipe... But I'm leaning toward the hi flo cat. I also don't wanna drive an Audi and have it smell
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Perhaps it's cause I have a full exhaust, but mine's not raspy at all. 3" tp all the way back to the split, then 2.5" into Magnaflow muffs.
    I hardly ever notice any smell from mine.
    And yes, there are tons of threads on this. Search and read up on what others have said.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Veteran Member Four Rings crazytex21's Avatar
    Jan 31 2010
    Georgia
    cheap
    actually, federal law says that any modification to your Catalytic Converter is illegal, no matter what your state laws say. but when is the last time you got pulled over by a fed... haha. i run a VMR test pipe. i love i. i don't have emmissions testing in my county, so i can get away with it.
    tex lee
    A lot of people think you want to race, when in reality, you just have to motor home because Chipotle.
    ~Shicky~
    Jun 06 2009
    Los Angeles, CA
    I have just a TP and it isn't raspy AT ALL. In fact, it's not loud at all. Almost identical to the cat being on. I was actually surprised. If anything, the spool is SO loud that it muffles the engine noise out. I'm guessing all this raspy talk might be with a full turboback and loud mufflers.
    Test pipe+stock mufflers=no noise at all (raspy or otherwise).
    Jun 06 2009
    Los Angeles, CA
    ^ and yes it does smell a bit, but i know 100% i have an exhaust leak at the turbo->test pipe gasket. I can feel it, but i have just put this "Thermaweld" putty on it designed to repair cracks and holes so we'll see how it holds up. Temp rating up to 2400F
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    I have an APR test pipe and I love it. It does make for a louder exhaust note through my Neuspeed exhaust, but its not raspy at all.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Established Member Two Rings Baruch's Avatar
    Jun 28 2010
    08 A4 Qt 6 Sp MT, 06 GSXR 600
    LI - NY
    I have a test pipe.... smell it when you get out, noise doesn't sound raspy at all either... i like it!
    Smell is around for like 3 seconds and its not bad what so ever
    08 A4 Quattro - 6sp MT
    APR Stg II+ - Carbonio Intake, HPFP Rebuild, Testpipe, APR Catback
    RS4 Rear Sway
    Debadged/35% Tint
    DUH! an Audi
    los angeles, CA
    very quick breakdown:
    testpipe - cheap, more hp gain...louder and smell gas.
    hfc - more expensive, not as much hp gain as tp (5hp less maybe?), a bit louder, no gas smell..
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Quote Originally Posted by Stewy View Post
    I dunno... I have Neuspeed exhaust on mine too and it's definately raspier than it was with the cat.. Plus my exhaust drones even more (avant)...
    Anyone local or in Seattle that wants to trade exhaust? My Neuspeed for your APR or anything quieter..
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    May 06 2010
    Ellsworth AFB, SD
    Quote Originally Posted by b4a41point8t View Post
    i think i got a leak at the cat as well, the new exhaust didn't sit right and i can smell it pretty bad in the cabin till i get off my lazy ass and fix it.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I have a HFC and the only difference I see if that when you aren't really getting on the throttle it smells and sounds like a stock car. When you get on the throttle it smells like gas and sounds pretty fucking good
    My understanding is the TP smells all the time and sounds raspy when not really getting on it
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Mar 26 2007
    Colorado
    They brought emissions back to my city, sooooo HFC
    CURRENT:
    2021 Atlas
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    I prefer the HFC just because it keeps the car a bit more civilized. I have 034 test pipes in stock, but I think I just ran out of the HFC's (http://www.europaparts.com/a4/b7/2-0t/exhaust.html)
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by Quattro View Post
    Well written. +1
    Jun 01 2010
    North East
    Quote Originally Posted by Matt@EuropaParts View Post
    Yea I was gonna go see u guys on mon or tues... Damn
    Senior Member Two Rings 06B7's Avatar
    Sep 14 2009
    2006 Audi A4 2.0T
    Trenton, NJ
    034 hfc says that they seen gains of over 27WTQ and 33WHP on our dyno on stock turbo tunes.
    Jun 01 2010
    North East
    Quote Originally Posted by 06B7 View Post
    Prolly with stage 2 programming
    Sep 14 2009
    2006 Audi A4 2.0T
    Trenton, NJ
    When i had it, it felt like i had chipped again but i took it out because there was oil coming out from transmission idk why. When i put the stock fc it was not leaking.
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Quote Originally Posted by wildbill View Post
    search button
    Turbos do not need backpressure. That is all.
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    Quote Originally Posted by Sprode View Post
    agree. turbos need the LEAST backpressure possible, meaning they need the largest pressure differential across the turbine. 0 is the lowest we could concievably go (without negative pressure, or a vacuum downstream from the turbine... impossible) and the largest pressure that can be attained is limited by the motor (the thing creating the pressure in the first place).
    ideally you'd have the exhaust of the turbine vent to atmosphere. that's obnoxious and not really feasable.
    actually you'd look for some type of venturi that would create a slight negative pressure downstream from the turbine. again, not feasable.
    Jacksonville
    When a turbo builds boost, then you want as open as possible. It's the curve under the boost that requires some back pressure. This is more evident with turbos that have lots of lag. If you're exhaust is too large, your car will have terrible response until the boost comes in. Ideally, there'd be a variable sized exhaust.
    Aug 27 2009
    Arlington, VA
    Quote Originally Posted by Charles View Post
    Sorry. N/A engines like some backpressure down low, but that is a function of the cam design and overlap. On a properly setup turbo car, the turbine itself provides all the backpressure an engine will need. The performance of the turbine is directly related to the outlet pressure.
    On top of that, our engines have got to have the least lag of any turbo engine I've seen, probably past the point of detriment as it runs out of breath so quickly.
    Jun 06 2009
    Los Angeles, CA
    ^ this. Backpressure for turbo= no need. As for our cars having no turbo lag, I agree and support this with empirical evidence. The k03 is SO small, that it spools by 2krpm. I have buddies with turbos that ask, where is it? When I point it out they laugh. It really is a tiny bastard. But then again, they don't see boost till 4k (evo) so it's really just a trade-off. Would you like a big slower turbo with incredible high end power (but u have to strangle your engine to see power) or a small snail that hits hard but falls on it's face after 4-5krpm. And believe me, the 4g63(evo) has DISGUSTING turbo lag. I mean... Disgusting! Feels NA 2.0L till late 3krpm.
