Results 1 to 34 of 34
    Active Member Two Rings ItalianAudi77's Avatar
    Jun 28 2010
    Lansing, MI
    B7 3.2L Oil Change DIY
    Now I am sure that the 3.2L isnt much different for an oil change but I have not seen a DIY for it. So...... ENJOY!!
    TOOLS:
    Flat Head Screw Driver (Big one for the screw tabs holding the splash guard on the bottom, small for the plastic rings you replace in the filter)
    Wrench
    New Filter (From Audi)
    8.1 Quarts of Oil (whatever you choose)
    TIME:
    20-30 Minutes
    So, Here we go!!
    I chose to use ramps, but you can easily just jack up the front as well. If you use jacks, please use jack stands! Also, all you need to do is jack up the driver's side as the drain plug is on the passenger side.
    Next, get under it and unscrew the tabs, there are several.
    Remove the splash guard, pull backwards and it slides right out.
    Remove the filler cap to allow for easy flow of the oil.
    Remove the drain plug, on the passenger side.
    Drain oil, now be careful, this really shoots out there!! Caught me off guard.
    After all the oil drains, and this takes awhile. You need to remove the "decorative Cover" to get to the filter.
    Black 2007 Audi A4 3.2L | quattro | VAG'ed
    Jun 28 2010
    Lansing, MI
    After the cover is removed, the filter is in the back.
    Just a slight twist with some grips.
    Remove filter, good idea to put a paper towel by it as a little oil will spill.
    Remove the filter from the cap, it just takes a slight tug.
    In the cap, you have to remove one of the rings, which an extra should be supplied with your new filter.
    Also the one by the hole for the filter.
    Jun 28 2010
    Lansing, MI
    New filter just snaps right in.
    Add whatever oil is your preference, I just used what Audi recommended.
    Button her back up!
    Now to get rid of that "SERVICE!" notice, hold the "wrench button" and turn the car on (not start) and then once it is on, release the button and hold the "0,0".
    ENJOY YOUR AUDI!!
    There are a few minor steps I excluded, like replacing the washer on the drain plug and obviously tightening it back down.
    **This worked for me, I will not be held responsible for any one else' Audi.
    Established Member Two Rings Euro Vs Earth's Avatar
    Jul 31 2010
    Atlanta GA
    Great DIY. I almost thought I was staring at my own car. I'm a recent 3.2 owner and I was hoping for a DIY. Thanks for this!
    Current: - 09' A6 Avant 3.0t Gray/Blk, 5%tint
    Sold: '10 A3 TDI S-Line, 20% ceramic tint, 312mm front rotor upgrade, JL 10w3 w/WickedCAS custom box.
    B7 3.2Q Black/Beige.
    97 Orvis ZJ
    84 300zx turbo
    Senior Member Three Rings titanium3.2's Avatar
    Dec 17 2007
    Springfield
    thanks that was very helpful
    Senior Member Two Rings AUDI101's Avatar
    Oct 10 2007
    06 A4 S-Line 3.2 Quattro
    Long Island NY
    Exactly what i need Thanks !
    Jul 31 2010
    Atlanta GA
    As directed above, but a minor difference for my car was oil drain was black and faced directly down. Don't ya just love that way your car feels with fresh oil...
    P.s. 6mm allen wrench not 7/32
    97 Orvis ZJ
    84 300zx turbo
    Active Member Two Rings Tachyon's Avatar
    Oct 31 2010
    97' Nissan 240sx
    Socal
    By the way, i think this is a great writeup and should be moved to the tech section i found it very helpful.
    2008 Audi A4 3.2L V6 Quattro in Brilliant Black
    Jan 13 2008
    2008 A4 2.0t Avant 6spd
    Boston MA
    Just a small tip. When you go to remove the filter instead of a paper towel but a ziptop bag over it. Close bag, properly dispose of filter.
    2008 A4 2.0T Avant 6spd. Black on Black Ti S-Line
    Sep 11 2011
    Utah
    This was mentioned in another thread, but the "Engine oil capacity with filter change" is WRONG in the manual and Audi recently mailed out a manual correction. Manual states 8.1 liters. Beginning of this excellent post also erroneously states 8.1 quarts. Correction states it is 6.9 quarts / 6.5 liters. Hope none of the DIY folks put in the 8 quarts in the past. Overfilling is a no-no.
    Senior Member Three Rings A4_Ti's Avatar
    Mar 15 2011
    Nice tip DIY24/7, when I did mine I just paid attention to how much came out and put the same amount back in.
    Also my oil drains straight down too
    oh and great DIY OP
    2007 Audi A4 | 3.2 | S-Line | Titanium | 6MT
    Jul 14 2010
    SF,CA
    There is a VIN split for the B7 3.2L guys.
    2005: 8.1qts
    2006+: 6.9qts
    if your oil pan is black and drain plug bolt faces straight down, it should be 6.9qts; at least that's how it is on my car.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Awesome DIY... we do carry an oil change kit for the 3.2 if anyone is interested.
    Oil Change Kit (3.2L, 3.0T)
    Order everything required to perform the highest-quality oil change in your Audi 3.2L or 3.0T engine. Please scroll down for the applicable Audi models.
    The oil in this kit is Audi certified and parts are OEM (or better) quality and TüV/ISO 9001 certified. Our professionals carefully selected and tested every component of this kit to ensure the perfect fit and quality. Your satisfaction is 100% guaranteed.
    You can customize this Audi oil change kit to fit your specific needs. Just use the check boxes and radio buttons to select/deselect the desired kit components.
    Engine Oil (1 x 5 liter bottle)*
    • Liqui Moly Synthoil Premium 5W40 Engine Oil (5 Liter) +$30.00 (Liqui Moly, LM2041)
    • Pento High Performance II 5W40 Engine Oil (5 Liter) +$36.95 (Pentosin, G052167M2)
    • Total Quartz 9000 Energy 5W40 Engine Oil (5 Quart) +$30.00 (Total, 184952)
    • Motul 8100 X-cess 5W40 Engine Oil (5 Liter) +$40.95 (Motul, 368251)
    • Motul Specific 505.01 502.00 505.00 5W40 Engine Oil (5 Liter) +$40.95 (Motul, 842451)
    Engine Oil (2 x 1 liter bottles, choose same as above)*
    • Liqui Moly Synthoil Premium 5W40 Engine Oil (1 Liter) +$7.00 (Liqui Moly, LM2040)
    • Pento High Performance II 5W40 Engine Oil (1 Liter) +$8.95 (Pentosin, G052167M2)
    • Total Quartz 9000 Energy 5W40 Engine Oil (1 Quart) +$7.00 (Total, 185703)
    • Motul 8100 X-cess 5W40 Engine Oil (1 Liter) +$8.95 (Motul, 368211)
    • Motul Specific 505.01 502.00 505.00 5W40 Engine Oil (1 Liter) +$8.95 (Motul, 842411)
    Oil Filter
    • Oil Filter (3.2L, 3.0T) +$9.95 (Mann, 06E115562A)
    Oil Drain Plug*
    • Oil Drain Plug Kit (14mm) +$1.00 (Genuine Audi VW, N90813202)
    • Magnetic Oil Drain Plug Kit (14mm, 10 Seal Washers) +$11.00 (Metalnerd, N90813202)
    Oil Change Tools
    • 1 x Oil Filter Socket (36mm) +$11.00 (Metalnerd, MNSH36)
    Engine Cleaner
    • Motul Engine Clean Auto (300 ml) +$19.49 (Motul, 816138)
    • Liqui Moly Pro-Line Engine Flush (500 ml) +$14.95 (Liqui Moly, LM2037)
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Great write-up man. Thanks for taking the time to do that.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Active Member Two Rings iwishihadanr8's Avatar
    Sep 19 2011
    Northeast
    Excellent write up! Good job taking the shot of the oil draining out of the pan. Question: is there a specific oil that one should use? I bought some Valvoline synthetic that meets VW 502 00 guidelines but don't know if that brand is recommended.
    Sep 19 2011
    Northeast
    One more question. If I am using jack stands and a large floor jack where do I place the jack under the car?
    Jun 30 2009
    Washington DC
    I cant believe how easy it is to remove the filters on teh 3.2l. WOW
    It is not the same with the 2.0ti have.
    Sep 19 2011
    Northeast
    Does anyone know if the B7 S4 the same method?
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Darnit. Thanks a lot. Now I have no reason not to do this myself. Seriously - nice write-up, and I appreciate the follow up posts w/ quantity info as well.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by homieelee View Post
    2005: 8.1qts
    2006+: 6.9qts
    FYI. Mine is an '08. Black lower pan, bolt into the bottom. I had eight quarts of oil, and used 'em all.
    Thanks again to the OP...made this much easier. For whatever reason, the service reset procedure isn't working. Documented the same way in the owner's manual, so the problem is obviously between the seat and the dash, but it's pissing me off. :)
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    nice write-up and photos. I'm sure it will help our V6 brethren.
    I am a little surprised though that you use a 5W-40 oil in a V6, especially in Michigan.
    I'm sure it meets the requirements but a 5W-30 might perform better in a non-turbo engine.
    Also, if you remove the oil fill cap after removing the oil drain plug it may not splash out as much, at least mine doesn't.
    Brillo
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Whats a 3.2?
    Senior Member Two Rings AdiDas's Avatar
    Aug 19 2012
    Pittsburgh, PA
    Hey guys, this might be a stupid question, but i was wondering how you ensure you don't overfill. Do you just measure out exactly 8.1 quarts before pouring in the new oil?
    Thanks
    2005.5 3.2 V6 A4
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Re: B7 3.2L Oil Change DIY
    Quote Originally Posted by AdiDas View Post
    Thanks
    I normally add a bit less than the required amount then top off by checking the dip stick. Then I get it up to operating temp and check it again. Not a v6, but same principal.
    Mar 31 2012
    Savannah. GA. USA. TO. ON. CAN
    Good write up.
    A tip for next OC. Insert OFC to the OFH. Then fill OFH with oil. This will prevent a dry start-up after an OC and instant oil supply to the valvetrain.
    Shown on a TDI engine, similar concept for other engines.
    []S POWER
    Mar 24 2013
    Oakdale, CT
    I'd recommend using the appropriate socket or wrench for the filter housing instead of vice-grips. Those things are expensive to replace. I believe the 2.0T is 36mm, not sure about the 3.2L.
    -Adam
    Established Member Two Rings shawn0223's Avatar
    Jul 05 2010
    02 E-320, 1998 corolla
    Mansfield, tx
    it's the same on the 3.2
    Shawn
    2006 A4 3.2Q 6MT||19" RS4 Reps||Yellow Koni Coilovers||RS4 Rear Swaybar||Interior LEDs||Fly's LED DRLs||License Plate LEDs||6000k HID Fogs||ECS Tuning Snub Mount & RS4 Grill||RNS-E Aux Mod ||42DD Catch Can||
    Aug 22 2010
    Piscataway, NJ
    Many Audi/VW models house the oil filter cartridge in a plastic oil filter housing that requires a 36mm socket to properly remove it without damaging the housing. This compact socket is used to properly remove the black plastic oil filter housing. Made by Metalnerd, specifically for the latest Audi/VW models.
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    to make this even easier, you can also get an Oil Extractor:
    https://www.ecstuning.com/b-motive-p...llon/1702~mtv/
    wish my filter was on top of the motor...
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Quote Originally Posted by ItalianAudi77 View Post
    TOOLS:
    Wrench
    I read the whole DIY. Great info!
    This is not a cheap out question "on my oil filter" as this DIY is 10 years old.(I'm happy to buy an Audi OEM oil filter)
    I see that the OP listed the filter option as OEM from Audi, I am fine with that. I just want to ask the question, have we the Audi forum found any other filter bands that we are happy to use? I would think offerings from MANN: (probably the OEM spec) and BOSCH would be at a high level = to an OEM option?? But if not, and 3.2 cars only find that the dealer filter is the best, well then I'll buy dealer. Just looking out side the box after ten years?
    I've even seen some other options like Wix and K&N both known to make quality filters.
    Maybe a list for this DIY? All expectable filters on the market:
    #1 = Audi OEM
    #2 = xxxxxxxx
    #3 = xxxxxxxx
    #4 = xxxxxxxx
    #5 = xxxxxxxx
    ..... and good luck with fram
    SOLD the GOINHAM A4 ---> GT2860 Project
    Mar 04 2019
    Staten Island, NY
    I use Wix filter very high quality. Never an issue. Also get the pump and remove the oil through dip stick opening. No need to drop belly pan or be under the car. Worth every penny if you do your own oil changes. I have a 2005 3.2 and it’s worth it to not go under car. I go with Amsoil European 5w-40, the wix filter and at 131k miles my silver fox is all good.
    You a bounty hunter...Man's got to do something for a living these days......Dying aint much of a livin boy....
    Mar 04 2019
    Staten Island, NY
    Quote Originally Posted by beefski View Post
    I use Wix filter very high quality. Never an issue. Also get the pump and remove the oil through dip stick opening. No need to drop belly pan or be under the car. Worth every penny if you do your own oil changes. I have a 2005 3.2 and it’s worth it to not go under car. I go with Amsoil European 5w-40, the wix filter and at 131k miles my silver fox is all good. You can get a reasonable priced pump from harbor freight or maybe amazon.
    Nov 17 2011
    Fredneck Maryland
    I'm not due for an oil change yet, but I do have a oil transfer pump on the way from amazon to test. I'm mainly just sparking some questions. Hopefully they are helpful.
    Mar 04 2019
    Staten Island, NY
    Quote Originally Posted by GOODBYNAAIR View Post
    Yeah, always good to seek addtl info. Audi’s are very finike with their parts and fluids I have used Wix filters for years on all my vehicles and have never has an issue. I did fuel filter, got the Audi part instead of aftermarket. Same with fuel cap.
