Results 1 to 11 of 11
    Senior Member Three Rings rjkotler's Avatar
    Jul 09 2010
    2020 Audi S3 (Wife's DD)
    MD, USA
    Finding my chass # to detirmine rear brake rotor size
    I need some help on Finding my chass # to detirmine the rear brake rotor size for my wife's A4. Yes I searched and found that I could pull the rotor off and look at the # on it but there has to be a better way.
    2005 A4 1.8T Quattro B6 body stlye.
    Any help out there?
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    depending on what wheel you run, you can probably reach through the spokes....
    you know the fronts are 288mm. measure from the edge of it to the barrel of your rim... then measure the rears the same way. basic math and you can find out that way =)
    245 is more common than 255 on 1.8s
    ..or just call your local Audi dealer with your vin number in hand.
    Active Member Three Rings BAB1990's Avatar
    Jun 26 2010
    give me your vin I will tell you
    Mods:
    Full-Race -|- Tial 44mm Wastegate -|- 5557E BB PTE -|- Custom Downpipe -|- 630 Injectors -|- Maestro Tuned -|-Open Dump -|- Custom Intercooler piping -|- Built Bottom End -|- AMB top (Soon to be AEB) -|- 355 BBK 4 Pot BBK -|- KW V1 -|- 19"V710's 9.5 Rear Matte Black -|- Authentic Otty Front -|- Authentic ABT Sides -|- Black Vinyl Roof -|- Too many to list
    Senior Member Two Rings a420's Avatar
    Apr 14 2008
    I.E.
    Unfortunately there's no other way, but to take off the wheel and measure the rotor yourself.
    Chassis/VIN # won't determine which size rotor you have either (at least, that's what I was told when I was shopping for a pair).
    Jun 26 2010
    Quote Originally Posted by a420 View Post
    Yes his VIN will.
    ETKA will give me option codes.
    Mods:
    Jul 09 2010
    MD, USA
    PM sent with VIN #. Thanks for the help with this.
    Jun 26 2010
    Replied
    Mods:
    Buncha motorcycles
    Memphis, TN
    dealer and ECS told me the vin doesnt mean shit. ENded up pulling the wheel off to measure. but 245mm is likely the case unless you are 3.0
    APR Stage 2/AWE Intake
    Jun 26 2010
    Quote Originally Posted by Papachristou View Post
    Than your dealer and ECS are pretty incompetent. If using ETKA, you will get the proper rotors by looking at the vehicle info. In this case I think he is like 1ZL option, which is 245x10mm rotors. I am at home, but yeah - the vin says all.
    Edit: Do you actually think at Audi the techs are pulling the rotor off everytime to tell the parts guys they need prices on a 245mm or 235mm rotors? I don't think so, given I work in that department. lol.
    Mods:
    Senior Member Two Rings soulvxr6's Avatar
    Aug 30 2010
    yamaha r6, mountain bikes
    lawrence ma
    my nephew works for audi and said if you have the stock 15 inch wheel on it that its 245mm.. i just went through the same thing..hope this helps
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    Vin will determine everything you have on that specific car... Vin will work
