Results 1 to 32 of 32
    Established Member Two Rings vLeuv's Avatar
    May 07 2005
    Encinitas, CA
    Transmission output shaft seal?
    So I took my '02 (w/ 90,000) into the stealership for the Coilpack recall and they did the "bumper to bumper" inspection and I got a call from my service rep, at first telling me that my Transmission output shaft seal was seeping...
    ...about an hour later he said its maybe a little more that a seep and said they would replace it for $315
    What should this actually cost to get done? and is it something I should get taken care of soon? Kind of clueless when it comes to repairs so any help you guys can send my way would be greatly appreciated
    -Adam
    Established Member Two Rings mjfrizz's Avatar
    May 06 2010
    St. Louis, MO
    bump...I'm doing this soon, part number I have for the seal is 01V 409 399 A. I've seen DIY where they need to remove a plug to get to the retaining clip that holds the shaft flange on. I've also read some people say there isn't a retaining clip, rather, a bolt holding the flange on. Anybody done this? To remove the flange, in order to change the seal, do you just need to remove a bolt or do you need to remove the plug, and then fish out a retaining clip?
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    mine leaks there a bit as well. my mechanic put it on the list of things to do in the near future, and told me it was common on these cars and wasn't that big of a deal to replace it. I'll report back after I get it done.
    Aug 14 2010
    Hattiesburg, MS
    On my 2003 Tip I started by draining the center differential oil. Then I had to remove the six allen key bolts to disconnect the drive shaft from the output flange. The shaft drops down (support it with some bailing wire to the exhaust pipe) then there is a bolt in the center of the flange that you pull out. You will need a torx socket to loosen it. Then the output flange just slides out. Pull the old seal with a flat blade screw driver and press the new seal in. Don't press it in to far using a socket and a rubber mallet. The only hard part is keeping the rubber gasket in place between the flange and the drive shaft when reinstalling the drive shaft. Fill it back up with gear oil and you should be ready to go. Took about 40 minutes to replace it. BTW clean the seal surface of the output flange and coat it and the inside surface of the seal with clean gear oil before you reinstall the flange. The dealer wanted $72 for the seal alone. I ordered it from ECS Tuning for around $7 and change.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    OK, man, this makes me feel better--I thought I was losing automatic transmission fluid from this thing. If its just gear oil---that seems much cheaper. Go with a quality synthetic? Any suggestions on which one? Doesnt have to be specific does it?
    I may try this on my own-- I may take it in to my non-Audi guy (he's much much cheaper than my INDY specialty shop.
    Off to ECS to find the seal.
    Jun 30 2008
    Erie, Pennsylvania
    This would be the factory fluid:
    http://www.ecstuning.com/ES465371/
    Any synthetic 75W90 is fine.
    Established Member Two Rings Daecarus's Avatar
    Oct 03 2009
    NC
    I just replaced ALL of my tranny shaft seals. The trans was being pulled to install a new 517 Trans torque converter so there wasn't much in additional labor.
    New Seals, Synthetic fluid, 517 Torque converter makes for a decent feeling TIP. Now if only I could get a TCU tune...
    ()xxxxxxxxxxxxxx():::::::::::::::::::::::::::::::: ::::::::::>
    Sports cars were not born on the streets of Tokyo or the back roads of Kansas
    2004 Audi A4 1.8t Quattro
    1993 VW Corrado VR6
    2001 Triumph TT600
    AKA: vw Neo
    Aug 19 2013
    minnesota
    Does any one know where I can get the whole guide assembly? Rather than replacing the seal I want to just replace the whole thing. Can some one provide a list of all the seals on the tranny? There is the front guide seal, rear seal and both front and left seals right?
    Jun 27 2011
    Input shaft Seal p/n:012311113B
    ^For manual transmissions
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Thanks. And thanks for the transmission TYPE clarification, as I don't see that otherwise mentioned in this thread. Or do all B6-spec transmissions use the same output seal?
    Besides input and output seals, are they other seals which should be pro-actively replaced at the 100K+ mileage level while the transmission is out for a clutch replacement? The two axle seals perhaps?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Jun 30 2008
    Erie, Pennsylvania
    The rear OUTPUT shaft seals for the B6 chassis are as follows:
    For 5-speed manual trans quattro "01A": 01A 409 400 B ($7)
    For 6-speed manual trans quattro "01E" (2002-2003 V6 only): 01E 409 400 ($33)
    For 6-speed manual trans quattro "02X" (All 2004+): 02X 409 400 ($63)
    For 6-speed manual trans quattro "0A3" (B6 S4): 01E 409 400 ($33)
    For Auto trans "09L" (6-speed AT quattro, B6 S4): 09E 409 399 ($33)
    For Auto trans "01V" (5-speed AT quattro): 018 409 399 B ($7)
    *Note: the 5-speed "01V" auto trans rear seal is very common to leak. After replacement, it would not be uncommon for it to leak again in 50k miles. There is a factory upgraded seal to fix the issue, but it requires also changing the flange itself at a parts cost of over $300.
    Auto trans (5-speed AT quattro) Seal Upgrade parts:
    Seal w/dust lip: 01V409399A ($60)
    Flange with clearance for dust lip: 01V409809A ($300+)
    Aug 19 2013
    minnesota
    Quote Originally Posted by DPDISXR4Ti View Post
    I'm wondering the same thing, so far I've book marked both front axle seals, front shaft seal (is that behind the guide sleeve? there is an inner and out seal -not sure if I have the inner or outer) Rear shaft seal, rear main seal. This guide sleeve has 2 seals, one on the outer edge and one on the inner edge where it mates to the tranny. A replacement guide sleeve is 130 at the dealer here and 75 on ebay. Too bad I don't have a 6 speed, theres one for 30 bucks on ebay!!! Basically I'm just looking for the guide sleeve seals and I'm going to begin my clutch work. I've made a clutch thread and people like Charles Waite have been pretty helpful. I've never done a clutch before and I'm just trying to replace any seals or things that aren't mega expensive while it's all apart. If you view my thread you'll see the things I'm ordering, http://www.audizine.com/forum/showth...slip?p=9085518
    K70205-HD-OFE- SMF 475
    http://www.dxdracingclutches.com/eco...m?item_id=2750
    front axle flang seal left and right 5.21 016409399B
    http://www.ecstuning.com/Audi-B6_A4-...ntial/ES10085/
    main tranny shaft behind guide sleeve seal 5.95 012311113B
    http://www.ecstuning.com/Search/Site...13B/ES1356489/
    propeller Driveshaft Flange Seal 6.34 01A409400B
    http://www.ecstuning.com/Audi-B6_A4-...ial/ES2598103/
    rear main 29.95 06A103171A
    http://www.ecstuning.com/Audi-B6_A4-...ain/ES1899281/
    I think that's everything. Maybe I could do the rear diff too while I'm at it.
    Motul Gear 300 is only 19.95 with free shipping on Amazon. Might as well change the front fluid since I'll have the tranny off.
    Interesting the tranny takes such thick lubricant.
    Aug 19 2013
    minnesota
    Using that part number I'll save a couple bucks by not searching by make and model on ecs, the exact same part popped up under porsche for a few bucks less lol
    Jun 27 2011
    You'll save more money by shopping around. IE not buying from ECS.
    For what it's worth I was going to get my motul gear 300 on Amazon but I walked into my local CarQuest and they said they could have their distributor get them 5 quarts by the next day for only $13/qt.
    Worth calling around as it's definitely overpriced on amazon.
    -CP
    2017 Q7 3.0t
    Jul 03 2010
    New York
    Thanks for all the good info provided here.
    As far as fluids go, is there just one fill location for the 01A 5-speed?
    It sounds like it would make sense to replace the center diff fluid at the same time. Does it spec the same 75W-90? Capacity?
    I guess I really should pick up at least the Haynes manual for this car. http://www.amazon.com/Audi-2002-2008.../ref=pd_cp_b_0
    Jun 27 2011
    Manual trannies only have one fill location , the front and center diff and transmission fluids are all shared.
    -CP
    2017 Q7 3.0t
    Oct 02 2006
    Wadsworth,OH
    Checking with our sources to see if we can get an aftermarket part to lower costs even more.
    *Edit Aftermarket is available
    Jason
    Jul 03 2010
    New York
    Okay, got it - thanks! Anyone happen to know the capacity offhand?
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    I got the seal dimensions, then hopped on ebay and ordered a double lipped rotating shaft oil seal in the same size. 3 bucks vs 60 from the dealer.
    Aug 19 2013
    minnesota
    Quote Originally Posted by ddillenger View Post
    What brand? Link?
    Aug 19 2013
    minnesota
    I called every auto zone in my area and the lowest I can get it is whole sale for 19.89.
    I also got most of my seals from them too! Car quest... Not bad. My rear main will be a Victor Reins. I like there gaskets. The valve cover, tube seal and timing seals were vr and it came with a big tube of reinzosil for 31 bucks... Think that came form blauparts or something on ebay.
    Jul 03 2010
    New York
    You guys might want to click on the link Jason provided above. ECS now has one listed for $3.16.
    Oct 02 2006
    Wadsworth,OH
    Remember to pick up fluid as well!
    Jason
    May 16 2008
    South Texas
    Assuming you have a tiptronic...
    If it's the rear output seal, then do not use the double lip seal.. It will just leak again. Audi retrofitted a new triple lip seal and a flange, which is probably why it costs so much.
    Aug 19 2013
    minnesota
    Quote Originally Posted by Scotty@Advanced View Post
    I got the 5 speed manual, all axle seals are the same part number, the seals between the tranny and rear diff are different I think?
    there are diff to axle seals, all the same.
    radial shaft seal for the guide sleeve
    O-Ring for the Guide sleeve
    Tranny output shaft seal
    Rear shaft seal to diff
    Rear Main
    Aug 19 2013
    minnesota
    Jason
    Could you please tell me where that seal fits? I've got the rear main, all 4 axle seals, the rear diff seal the transmission prop seal, the guide sleeve O-Ring and what I believe to be the inner seal for the guide sleeve which is 012311113B? are these the same seals?
    or to put it easier
    Whats the difference between this Radial Shaft Seal http://www.ecstuning.com/Search/Site...172/ES1356489/
    And this Input Shaft Seal
    http://www.ecstuning.com/Search/Site...172/ES2696172/
    I thought I had every thing until I realized that part number you gave doesn't come up for any of the b6 5 speed seals?
    lol is the radial shaft seal the same as the inner guide sleeve seal? And the seal your posting is a seal behind that in the transmission?
    Aug 26 2005
    Quote Originally Posted by Daecarus View Post
    I here ya, the general lack of TCU tunes for our B6 1.8Ts mystifies me.
    Vorsprung durch Technik
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by jacobsen View Post
    or to put it easier
    They are the same. One part number is superseded meaning the part number changes but the actual part is still the same. This part is your input shaft seal on the transmission.
    Below is a pic of its location.
    Jason
    Aug 19 2013
    minnesota
    Jason
    Thanks, I know the guide tube has 2 seals, one inner and one outer which is an O-Ring which is what 10 should be? Looks like 10A goes into the recess of the input shaft. But I thought the guide sleeve had it's own seals before the 10A seal
    Oct 02 2006
    Wadsworth,OH
    I can only go by what the diagram says. #10 I would assume to be the o ring seal. #10A is the one that goes into the transmission.
    Jason
    Feb 14 2019
    Portland OR USA
    Sorry to necro-bump this post but I'm having the same leak from my rear output flange seal on my 2006 A4 Quattro Cabriolet. Its a 5 speed auto tiptronic, and I've found the correct seal on ECS website.
    What I'd like to find out from you all is if its worth me doing this myself? Or should I just take it to a shop?
    I only have a floor jack and jack stands to work with in my garage, and I've been told the quattro automatics are more difficult to do this repair on than the manual transmissions.
    Suggestions? And what do you think is a fair price for a shop to do this repair?
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    Quote Originally Posted by AquaticEngineer View Post
    It's easy enough to do yourself. I did mine recently along with other stuff. Remove catback exhaust (4 hangers and 2 rusty clamps), remove heat shield at front of driveshaft/propshaft (2 t40), remove front driveshaft (mine has 6 6mm hex insert. Careful, they have red loctite. I stripped 2 blasting it with an impact and made the job harder) and rest in on something or tie it up. Remove output flange (1 t40), and seal flange (4 t40). Remove old seal and press in new. Check the grease on your driveshaft end (it's the old puck style CV). Button it back up.
    Tech instructions say to clean off the threads on the driveshaft bolts and put a tiny bit of red loctite on them to keep them from spinning out.
