Results 1 to 9 of 9
    May 08 2009
    Easthampton, MA
    ball joint boot repair - worth it?
    Just thinking... I have a broken ball joint boot on my lower front. You can buy a repair kit for $16 which includes two boots, so you get to keep one for future needs as well (fits lower front and aft).
    did anyone do this, and is it worth it? if the boot is broken, then isn't the balljoint likely to be already worn out from lack of grease?
    new boot or new control arm ($65)?
    Jun 30 2008
    Erie, Pennsylvania
    Unless the arm is basically brand new, this probably isn't worth it. just throw some grease on it to help keep the dirt out and run it until it dies. It will die soon enough no matter what you do. No need to do extra work, IMO.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    yeah i would honestly say just run it till it starts making noise or has excessive play in it, then get a new control arm
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    May 08 2009
    Easthampton, MA
    cool, thanks.
    Veteran Member Four Rings A4edwin's Avatar
    Dec 07 2008
    01 a6 4.2 sport, 92vw cabriolet, 03 Tahoe, 03 Ford Explorer sport.
    New York
    i replaced mine and have had no problem with it since it's been replaced. 16 bucks for a boot kit or 100 bucks for a replacement axle.
    unitronic tune, milltek exhaust, Avant garde m590 wheels 19x9.5 e.t. 40, sumitomo tires 255/35/19 tires, h&r coilovers, ecs 12.5-15mm spacers, ecs slotted rotors, pbr pads, "oem allweather mats" <
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    Quote Originally Posted by A4edwin View Post
    They aren't talking about the cv boot.
    and I would say just swap the boot for occasions where you ruin the boot removing it with pickle forks, yet the ball joint is still good.
    Sep 13 2007
    pm sent
    Sep 17 2005
    Fremont, California
    What he said.
    May 08 2009
    Easthampton, MA
    So, i ordered a new one, along with a wheel bearing that i also need for the same wheel. have heard some "clunck" sonds from there so i figure it's worth trying to see if that will go away with a new arm. $120 for both parts including shipping is pretty good (blauparts).
    thanks for you guys' imput. Since i have no way of knowing how long the boot has been torn like that, it seems i should go with the new control arm argument. Like someone said, if i had torn it myself and knew that it hadn't been in use ungreased for a length of time a boot would be worth it.
