Results 1 to 40 of 45
    Nov 15 2006
    00 S4, 99Cobra, 54BelAir
    The Milky Way
    Any advantages to wheel bolts vs studs?
    I've always wondered this. Why does audi use wheel bolts instead of studs? Is there any advantage?
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    It's more difficult to put the wheel on. Audi seems to make decisions like this based on user unfriendliness. "Hm, how can we make this tougher?"
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Quote Originally Posted by S4UCE View Post
    I lol'ed. So true. Fucking europeans.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Sep 22 2009
    Vermont
    not gonna speak for all cars but the rotors like to stick to wheel studs
    Established Member Two Rings 04/01-s4's Avatar
    Jul 28 2009
    01 s4,03 1500hd,2006 FXSTI
    Bloomsburg PA
    I've been running studs for a while and would never go back. My wheels are constantly coming on and off for one reason or another but Id definatly +1 for full stud conversion, and make sure to get noticeably longer ones then a "stock" length just in case you ever decide to run spacers or get different wheels with different offsets. It just makes life ALOT easier.
    2006 HD FXSTI
    2003 silverado 1500hd 4x4 (DD)
    2001.5 s4 / 034 STK conversion in process
    TIA certified
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    yeah I hated the bolts...my next audi I am going to get a stud conversion kit...
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Apr 15 2010
    Mercersburg, PA
    I find it easier to put on wheels with bolts than with studs.. especially if its heavy. You just put it on, and slide it till it lines up with the holes. With a stud i find myself to have to constantly put it up, put it back down, realign it, etc.
    I know for BMX hubs most people are switching over to bolts because its lighter and stronger and bolts can be torqued down better... not sure if its the same for cars though.
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by Thsisinsanity View Post
    huh? what you described is exactly the opposite of reality. studs are 100x easier than bolts. there is no lining up to do with studs, if its on, its lined up.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    you have it backwards..
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Quote Originally Posted by KNaudi View Post
    LoL i was thinking the same thing.
    Veteran Member Three Rings audiluxary's Avatar
    Nov 21 2007
    2001 Audi A4 1.8T/2002 S4 (Imola) stage 2
    The Sticks
    [QUOTE=Thsisinsanity;5817415]I find it easier to put on wheels with bolts than with studs.. especially if its heavy. You just put it on, and slide it till it lines up with the holes. With a stud i find myself to have to constantly put it up, put it back down, realign it, etc.
    I know for BMX hubs most people are switching over to bolts because its lighter and stronger and bolts can be torqued down better... not sure if its the same for cars though.[/QUO
    Have you ever taken an Audi wheel off? This is the most rediculous setup of all wheel setups and a stud conversion is by far easier.
    2001.5 1.8t
    GIAC FXK04 (Hammer) installed with a big fat cell...update, cell has been gone for a long time now but smells like it's running rich.
    2002 Audi S4 - Stage 2 (Imola)
    Sep 11 2007
    Tampa, FL
    funny thing is the morons at audi that designed it. the lip is so unbearably small that if you dont take the time to thread in the tool which acts like a stud mind you then the wheel just falls off or rotates out of place, or you have to use your feet or something to hold the wheel in place so it doesnt fall etc. its a unbelievably stupid setup.
    Veteran Member Four Rings Mattgfx's Avatar
    Sep 27 2006
    Quote Originally Posted by *Blue-Angel* View Post
    this.
    sometimes i wonder what german engineering really means..
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW 328i xdrive
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Established Member Two Rings JLH_S4's Avatar
    May 28 2010
    Arab, Al - Lawrenceville, Ga
    Haha I've never been the biggest fan of these things (I've owned two GTIs and now an S4) but they've also never really bothered me. It's all I've ever known so I guess you just get used to dealing with it. Always know to factor in dealing with lining up the holes to get the bolts back in when you're working. Also - how do you toss spacers on studs? Can you have studs that are just normally ~25mm longer than you need just in case you ever decide to space 'em out? But then I'm guessing your suds would actually stick OUT of the wheel that extra ~25mm... would you be able to use center caps? Geez all the questions that brings up for me.
    Feb 06 2010
    Albuquerque NM
    you know that black threaded thing in the tool kit...
    Nov 15 2006
    The Milky Way
    I was wondering if there was some engineering reason like more clamping force or some such. It seems audi just did it to be a bunch of cocks?
    Senior Member Three Rings s4lou's Avatar
    Apr 21 2010
    1930 ford model A hot rod. 2005 subaru wrx wagon.
    san jose, ca
    studs ftw!
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by anaxagoras View Post
    germans fucking with humanity in general? NO WAY
    My WTB List:
    KNaudi's story
    Senior Member Three Rings Tormented's Avatar
    Sep 12 2010
    2007 Mazda 6
    Texas
    Can anyone post some pics of both options? I dont understand the difference in the two. I am gathering that studs are easier than bolts but im just curious what the difference is with them both. Also where can stud conversions be found? And are there multiple different types and what makes one better than another?
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by Tormented View Post
    really? alright, ill help ya out. here are my studs. they are from Mike@RingerRacing.
    My WTB List:
    KNaudi's story
    Jun 24 2010
    ringerracing.com
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by RONDAL View Post
    ringerracing.com
    we might be taken to the AZ dungeon and waterboarded.
    My WTB List:
    KNaudi's story
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    oh and some people really don't like the way studs looks on the wheels (don't understand it) but it is definitely a different look from the flush look of bolts
    My WTB List:
    KNaudi's story
    Veteran Member Four Rings odhinnhrafn's Avatar
    Jun 25 2010
    '01 Audi S4, '15 Chevy Colorado
    Reno, NV
    At the same time, though, snapping a bolt (my old ones were rusted, looked like the PO never removed em, breaking torque just snapped one of the bolts in half...) just means drill/tap the bolt out, replace. Snapping a stud (when it's built into the hub) can mean having to replace the hub.
    Jan 29 2007
    08 S4 00 S4
    MD
    This debate gets started every couple of years on a number of forums and I've never seen a clear cut answer as to what the reason is for German cars to use bolts instead of studs. Some say it's for cost reasons, easier to repair a broken bolt than replacing a stud, others because the load of the wheel is carried by the hub ring with bolts vs the wheel studs, which could also damage them during removal or installation. I don't know, I will say this..if you know how to remove a wheel, the difference is negligible between the two. It takes about 2-3 minutes to R&R a wheel, whether it uses studs to mount it or bolts.
    08 S4- Stock SOLD
    Jun 24 2010
    does anyone know the size and pitch of the studs that are needed?
    Jan 29 2007
    08 S4 00 S4
    MD
    I think it's probably the exposed threads that's that doesn't appeal to some, I don't know if I would run wheels like that where I live. Not that they don't make nuts that cover them. Nothing wrong with the way it looks from my view.
    08 S4- Stock SOLD
    Sep 11 2007
    Tampa, FL
    I will have to agree with your last statement. going between my mazdas and the audi is going from studs to bolts. id have to say once you come up with a system then the time is very small. but overall the studs are quicker and easier to r&r than bolts and the fact that the wheel needs to dangle on the small lip of the hub.
    Jan 29 2007
    08 S4 00 S4
    MD
    Yup, you can slide a wheel on a 5 point stud set up, zip the nuts on and be done. But for bolts, you obvioulsly have line things up. for the rear wheels, it's not an issue. Just R&R with the ebrake on and the holes are in place. For the front, the set up still doesn't turn that much. Stick the wheel on, spin it and put a bolts in place. I actually don't have an issue with the wheel coming off of the ring when lining up the bolts. At the most, I have to hold it with light finger pressure to get a bolt in the hole(That's what she said)..
    08 S4- Stock SOLD
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    Regular wheel bolts do two things at once; A stud conversion splits the work into 2. While the fixed studs help hold the wheel in place, the lug nuts keep the wheels torqued down. As already mentioned, it makes installing wheels easier and faster. Depending on the length stud you get, you can also run spacers safely without the need to buy new wheel bolts. Speaking of, proper installation of wheel spacers is also made easier. Having a stud kit also allows for having a wide range of lugs to choose from, some of which can be forged aluminum which can help drop some more unsprung weight.
    Rich | 2001.5 EPL stg III+ TiAL 605.2 Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
    Sep 27 2006
    Quote Originally Posted by mholme View Post
    mholme you're the god of audizine
    AKA: Bigair
    Sold: 00 Audi S4
    Sold: 08 BMW 135i
    Sold: 11 BMW M3
    Current: 15 Audi S3
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    I've been trying to get an answer on this but can I use 4 ball seat nuts and 1 conical locking nut? I'm trying to order the stud conversion kit from raven but I want to get the locking nut set but they only come in conical seat. I have OEM wheels and vmr 708's.
    Tial 605's EPL Tuned
    Lots of other goodies.
    Aug 23 2004
    2000 BMW 328i
    ^^Are VMRs ball seat?
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Quote Originally Posted by Bimmerchop View Post
    yup
    My WTB List:
    KNaudi's story
    Aug 23 2004
    2000 BMW 328i
    Hmm... I just always figured they had a conical seat like most aftermarket companies out there.
    Nov 14 2006
    VA
    So that means I can't use ravens lock nuts right?
    Aug 23 2004
    2000 BMW 328i
    Can you? Yes, but it won't sit securely. Just buy a set of ball seat lock nuts from someone else.
    Feb 02 2008
    17 pure white vr6 Touareg sport tech
    I assumed the reason Audi used bolts instead of studs is because the wheel cap will not fit over studs, depending on length. Obviously I could be way off though.
    Jun 15 2010
    San Antonio, TX
    Unless the length of the stud is the issue, I don't think that's typically an issue. Just need a nice set of lugs and it looks fine. Here's how my Volk's looked with Ray's lugs on my RX-8:
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Another advantage is when dealing with morons at tire shops. We have experience and take the time and are careful with our expensive wheels to line things up and get them mounted properly without trashing the finish around the bolt holes. If you are like me and don't mount your own tires (how many of us do?) you are taking a leap of faith every time new tires are needed and or rotated/rebalanced. Ask me how I know.
