Results 1 to 11 of 11
Thread: Q5 Brake Pads
    Sep 16 2009
    Question Q5 Brake Pads
    HI.
    My Brake Pads warning light just came on. I have only 22K miles on the car but dealer is saying that it's normal for Q5.
    I'm thinking of doing that service not at the dealer. Does anyone know what size pads I need?
    Brake pads - 320x30mm - 320x30mm or Brake pads - 345x29.5mm - 345x29.5mm for a 2009 Q5.
    Also, what else do I need - Just the pads and the sensor?
    Will the warning light go away on it's own once the sensor is replaced? Or does the dealer need to changes something in the system.
    Veteran Member Three Rings K1speeder's Avatar
    Aug 29 2010
    San Francisco
    Not sure about the size of the pads but I just had to replace mine at 23,000 miles. I haven't replaced tires yet even.
    2017 Q5 3.0T P+, Brilliant Black
    Past: 2015 S3 P+ • 2010 S4 Prestige, Meteor Gray • 2009 Q5 P+, 3.2, NAV, Brilliant Black
    I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    I think I'll replace mine with some Hawk pads. Less dust.
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 16 2009
    Quote Originally Posted by K1speeder View Post
    how much did it run you at the dealer? or did you do them someplace else?
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I just bought the pads .. about $100ish at the dealer .. and had a mechanic friend swap them out for $60 ... need to do the rears now ..
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Apr 10 2009
    Anyone have a DIY for the pad removal? Done plenty on BMW but never on a Q5 set up.
    Registered Member One Ring dalecarlsbad's Avatar
    Oct 29 2010
    I have had very good luck with EBC Red Stuff pads. Better grip and low dust. Just installed a set on the TT and will be doing the same on the wife's 2011 Q5.
    http://www.buybrakes.com/store/EBC-DP31988C
    2008 2.0 TT Coupe
    2011 Q-5
    Apr 19 2012
    Chicago, IL
    Quote Originally Posted by Atlas View Post
    I'm looking to do a DIY on my wife's 2010 Q5 3.2. Is there a DIY anywhere online to walk through this?
    Thanks,
    Nikos
    2012 A6 3.0T Prestige
    2005 Porsche 911 Carrera S
    1983 Porsche 911SC
    1967 Alfa Romeo Duetto
    Veteran Member Four Rings BirdmanQ5's Avatar
    May 31 2012
    2017 Audi S3
    Toronto, ON
    Quote Originally Posted by ed@mtl View Post
    Stay away from Hawk Pads. I put Hawk Ceramics on my OEM rotors, and after 20,000km this is what happened. To explain the video, I hold the wheel when I accelerate, then let go and brake to show how warped the rotors are.
    2017 AUDI S3 | TECHNIK | DAYTONA GREY | BLACK OPTICS | SUPER SPORT SEATS | ADVANCED HANDLING | TECHNOLOGY PACKAGE | AWE SWITCHPATH 102MM | ED SPOILER | 034 SPRINGS + REAR SWAY | VORSTEINER VFF102 20x9 ET35 CARBON GRAPHITE | THINKWARE F770
    2016 AUDI S3, 2013 AUDI S4, 2011 AUDI Q5, 2010 AUDI A4, 2006 AUDI A4
    @IALEXSERBERT | @AUDI_TN | @SIXAUTO
    AUDITRUENORTH//
    WWW.SIXAUTOCONCIERGE.COM
    Mar 19 2004
    I didn't get the Ceramics ones.
    Nov 25 2011
    Q5
    Plymouth , Ma.
    From what I know and have experienced the Pads won't warp rotors. Need to use a torque wrench when installing wheels.Never use the air impact guns as they will wreck rotor faster than one could imagine. Rotors can also warp from being over heated usuually caused by severe ,continuous hard braking or using the brake pedal as a foot rest..Once they are warped toss them out and buy new. Rotors today are so thin you can't resurface them properly. Just not enough metal on them .
