Results 1 to 24 of 24
    Senior Member Two Rings kaklexicon's Avatar
    Nov 21 2005
    PA
    Oil Cap Test for PCV leak
    I'm a bit confused how the oil cap test works with the B7. Is there supposed to be suction or not? I suspect my PCV needs to be replaced but I'm not sure how to test it. When the car is running, there is alot of suction on the oil cap and it takes some effort to pull off. Does that mean there is a leak somewhere or is that normal?
    2012 Audi A4 2.0T Quattro
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Yes. If you have difficulty pulling off the oil cap while the car is running, your PCV is most likely defective. Also, do you see oil around the cap/coilpacks? That is another known indicator.
    Nov 21 2005
    PA
    Thanks for clarifying that beantown, yes there is some oil around the cap/coilpacks too. Looks like it's time for a PCV upgrade.
    Senior Member Two Rings pierranchis's Avatar
    Nov 18 2009
    2007 A4 FWD 6sp, 02 R6
    Pompano Beach FL
    Beantown, just to get it out there. I pulled out the coilpack closest to the front of the motor and saw oil all over (like dripping soaked) with oil. I already went through the pcv fix from the dealer (that when the car was getting oil around the cap). Could this be the valve cover gasket? If so, should I just bite the bullet and get a catch can while I'm at it? Thanks!
    APR 93|Greddy FMIC|Carbonio|AWE hpfp|Pulley|TP|SB stg 3 clutch|Ecode 11lbs flywheel|Koni Coils|Hardwired V1|B&B Exhaust|RS4 Sway bar
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    Quote Originally Posted by beantown View Post
    Shouldn't there be some vacuum though, or is there supposed to be no resistance when removing the cap at idle?
    No longer my "DTM" S4
    Rolling STOCK B8.5 S4 for over a year and happy!
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    im pretty sure there is suppose to be some vacuum, but if its very hard to take off then its an indicator.
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by pierranchis View Post
    A bad valve cover gasket would be my first assumption. If you're under warranty then you should definitely have the dealer fix it.
    As for a catch-can, I don't have much experience/knowledge on those.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by makav3li View Post
    x2...if you've removed your cap multiple times in the past (guessing you have), then you would immediately notice that it's tighter than usual.
    Senior Member Three Rings deeznuts's Avatar
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    question about this...when i tried this before, there was some vacuum but it wasnt too difficult to pull out, but the car started to stall the more i went to pull it out...is that normal, or is that also an indication that something is bad
    Koni ss, creative test pipe/downpipe, britalman exhaust, greddy fmic, rs4 sways, apr stg II, a lot of adrenaline
    May 06 2010
    Ellsworth AFB, SD
    mine idle's reaall rough when i take off the oil cap, from what i know, thats normal
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    anybody else can second that? i know my buddys b6 2.0 stroker runs perfectly fine when he takes his cap off.
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Whoa, I never knew this haha. Just after I got a CEL I pulled the cap and 1. It was basically on fire and 2. it was difficult to get off.. They did replace the PCV though, 2nd time taken in..
    RIP QG TI B7 A4
    Dec 03 2009
    WOMP WOMP!
    NJ/NY
    hmm this has me worried..i may just be paranoid though.....coils, seals, valve covers, pcv,gaskets....what the fuck my life- i hate this car.
    Senior Member Two Rings xpanel's Avatar
    Oct 13 2010
    Custom Chopper
    Cape Coral, FL
    I had the exact same problem, if you get suction, thats bad, your pcv needs be replaced or repaired, you might also experience very loud whistling sounds.
    2005 A4 3.2 Quattro (crashed)
    2008 A4 2.0T S-Line (sold)
    2008 TT 3.2 manual (Destroyed by Hurricane Ian 2022)
    2018 R8 RWS 1 of 999 IG: cmonbmw
    YouTube Videos
    Custom Shifter
    Established Member Two Rings HermanL's Avatar
    Jul 30 2010
    Columbia MO
    I got suction, but no oil leak, no whistling noise.....so that would mean i have a bad pcv???..god i am getting paranoid too....
    05.5 A4 FWD (GONE)::: APR stage 1 91 93 ::: VMR tespipe ::: BSH stg2 catch can ::: podi gauge ::: K&N drop-in air filter ::: 034 inlet ::: drilled and slotted rotors ::: EBC red stuff pads ::: Di-Noc wrapped trim
    07 6mt E92 335i (Current) :: Cobb Stage 2+ E85 :: BMS intake :: HPF intercooler :: AR downpipe :: AE exhaust :: TC Kline SA coils :: m3 suspension bitz :: Advan RS :: 400rwhp 420lbft
    Jun 21 2009
    OR
    Found this thread that had a very informative post in it:
    http://www.audizine.com/forum/showth...?highlight=pcv
    Scroll down to the one by 09etech, hopefully that clears some things up for everyone.
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by Leo14 View Post
    What do you mean by "it was basically on fire"? That is was extremely hot or actually smoking?
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by event View Post
    Good find and information there, and, an excellent example of the power of the search function lol.
    Nov 21 2005
    PA
    Very informative, thanks!
    Nov 21 2005
    PA
    Just a quick update, it was definitely the PCV Valve. I installed and new one and the oil leak stopped. Also, the old one was letting full air flow through both ways. nasty...
    Jul 27 2009
    '15 S3
    Boston
    Nice, good to hear. Was the PCV itself the only part you replaced?
    Nov 21 2005
    PA
    Actually, when it first started happening I took it to the dealership and they replaced the valve cover and valve cover gasket under warranty. Then it kept doing it, so I did the upgraded PCV on my own. The oil stopped leaking after that. However, the dealership did say the valve cover gasket was bad, so I guess it was both.
    Mar 09 2010
    North E. Jerz
    Basically on fire, aka really really really really hot. =P
    RIP QG TI B7 A4
    Established Member Two Rings CVTwhatadumidea's Avatar
    Jul 16 2008
    2010 MB C300 4Matic Sport
    Fort Wayne
    Bad pcv? Click here for video
    QGM '08 B7 2.0T 6MT Premium+ | APR Stage 2+ | Podi Mechanical Boost Gauge | RAI HFC/DP combo | APR HPFP | ECS snub mount | JHM chromoly lwfw and RS4 clutch | LaPower Bluetooth Module | Black Headliner Conversion | Pipercross Dry filter | R8 Coils | GFB DV+ |
