Results 1 to 17 of 17
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Car is smoking under the hood
    Hey guys,
    this morning when i drove to work i noticed a burning rubber smell. it was coming from the front of the car and i popped the hood. there was a decent amount of smoke coming from under the airbox area. what is under there that would cause the burning rubber smell.
    John
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Senior Member Two Rings Audiudo's Avatar
    Jun 05 2009
    2003 ZX6-R
    New York
    I have the same issue! I have a C5 and noticed it and smelled the burning rubber. The car sat for a period of time before I drove it (about 1 or 2 weeks) so that is the only explanation I have now. Right now I don't see the smoke but the smell is noticeable at times.
    04.A6.S-Line.Team.A.C.E.
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    valve cover gasket
    i have the same problem but i fix this week
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Are you sure its rubber, its fairly easy to mistake rubber burning smell with burning oil. Leaky valve cover gaskets leak right down onto the exhaust manifolds. That would be my guess since the lower side of the head is right next to the airbox and i had that problem before diagnosing it as valve cover gaskets. Fairly cheap fix of about 40-60 bucks if you have a couple hours free on the weekend. Good luck
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by PSU S4 View Post
    +1
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    valve cover gasket as stated perviously
    Sep 11 2009
    NE
    I would say "Valve cover gasket" but it is a misnomer. In 99.99% it is actually the cam plug leaking. Buy new cam plugs and replace these first to see if that cures the problem. Replacing Cam plugs doesn't involve taking valve covers out and takes 15 minutes per side, fairly easy DIY.
    Cam plug:
    Veteran Member Four Rings imola's Avatar
    May 23 2007
    You sure it's not just something along these lines?
    sold :(
    Veteran Member Three Rings Blake2423's Avatar
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    How exactly do you replace those cam plug i bought them but did not know how to install
    Sep 11 2009
    NE
    Jam a screw driver (with a hammer) into each and pry them out. Press new ones in by hand.
    They are located on the back of engine, towards the top.
    You can see the driver's side right on the back edge of motor, on top of head in the corner where it meets red valve coves.
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    Quote Originally Posted by s4killer View Post
    valve cover gasket
    i got my whole valve cover gasket kit! ( cam seals blah blah blah ). fixing sometime this week!
    Garage: b5 s4 silver stg3 f21s
    RIP Daz 4/14/16. Legend.
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    The engine is still in so it may be difficult to reach, should I still put a bead of sealant on it?
    Sep 11 2009
    NE
    Quote Originally Posted by Blake2423 View Post
    They are not that hard to reach at all.
    So, absolutely no sealant. Just press them in. I made a mistake of putting sealant on one and it popped out next time I was pressure testing... silicone prevented ribs from digging into the metal.
    Driver side requires you to remove three screws from expansion tank and move it aside.
    Passenger side requires removal of accordion hose and MAF housing.
    Sep 11 2010
    '04 Cayenne Turbo
    Atlanta, GA
    I jammed screw driver in there and a seal pick but nothing allowed me to get at it. I was just peeling the rubber off the outside. The car has 120000 miles on it should i just pry at it harder?
    Feb 06 2010
    Albuquerque NM
    i hammered a very small tipped screw driver in there and pulled it out.
    Dec 06 2007
    Calgary, AB, Canada
    It's probably the VG gasket, rather than the cam plug in this case. You should see residue from the area the leak is coming from...
    Oct 19 2008
    Do the valve cover gaskets and cam tensioner seals. Seen it more than once at my shop for the same complaint. Only issue is you need a tool to release the tension off the tensioner chain, other than that not a bad job. Good luck
