Results 1 to 23 of 23
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Will torn lower control arm bushing cause creaking noise?
    I notice that the car now makes a creaking/squeaky noise when I turn the steering wheel. I took the wheel off and noticed that the rubber boot of the lower control arm that connects to the hub is torn and floppy. Would this be the cause of the noise or something else? I'm hoping this is in and not my PS pump.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Veteran Member Four Rings bez101's Avatar
    Oct 06 2009
    sheffield
    they could be makeing the noise you have
    as there torn and floppy its a good idea to change them anyway
    fingers crossed its not your rack or pump
    Mar 21 2005
    2019 RS5 SB / 2025 SQ7
    RI
    Yes, absolutely. Just happened to my car. New lower control arm fixed the problem.
    Oct 02 2006
    Wadsworth,OH
    It sounds like a lower control arm bushing over a power steering pump from my end. A bad lower control arm bushing will for sure make a creaky/squeak noise.
    We offer replacement control arms as well as press-in bushings for your existing control arms if you're looking to save some dough. Click here:
    Active Member Two Rings MCKAYIVA4's Avatar
    Aug 20 2010
    b5 2.8 qm, 95 chevy silverado z71, 68 volks beetle
    Pittsburgh
    deffinetly your suspension creating that noise. If i was you I would check every bushing and replace all that look suspect.
    Feb 12 2009
    T.O.
    I had torn bushings in my Upper Control Arms (b6 s4 160,000km) - i had them replaced and i still have creaking/knocking (its quick, sounds like 1 or 2 quick knocks) steering noise when moving at extreme slow speeds (out of parking spots etc). It's really bothering me... the control arms did nothing the sound is exactly the same.... if anyone could suggest something to me i would be greatful
    Sep 27 2007
    Columbia, SC
    I'm hoping is the control arms. It will sometimes creak a little when going slow over uneven pavement with the wheel straight.
    If it's the PS, what would be the symptoms?
    96 Soarer GT - Gone
    Veteran Member Four Rings rs4 tony's Avatar
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by bint2k View Post
    I have this same noise. When parrarel parking. Any clue of what it could be?
    2007 Audi Rs4 Daytona Pearl/Carbon Fiber Trim/Navi/Lambo Verde Ithaca Pearl Painted Calipers/H&R Springs/JHM 93 Octane Tune/K&n Drop In/Apikol Red Rear Diff. Mount/StopTech S.S. Lines/Michelin Super Sports 275-30-19/H&R 8mm Front Spacers/MTM 10mm Rear Spacers/JHM Intake Manifold Spacers/SPEC Stage 3+ with LW Steel FW/JHMCatless Downpipes/JHM 2.75" Non-res Catback Exhaust/JHM Lightweight Front & Rear Rotors/034 Torque Mount/
    Instagram: @rs4_tony
    Senior Member Three Rings Breppinq's Avatar
    Apr 05 2012
    VW ATLAS, VW JETTA GLI MK4
    Long island, NY
    If it's knocking check your tie rods. Jack your car up and move the wheel left and right then up and down and see if there's play could also be your ball joints which you'll have to get control arms for anyway. I changed all 8 control arms and tie rods with a kit it's cheaper than buying everything one by one. Goodluck
    Veteran Member Three Rings EMF614's Avatar
    Jun 15 2011
    cbus
    Quote Originally Posted by rs4 tony View Post
    I know if you don't torque down the bolts to the correct specs or don't tighten them under load, it can cause noises.
    Ethan
    Single Turbo B5 S4
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Breppinq View Post
    Did this. No noise or looseness left to right, up to down.
    All bolts are torqued to proper specs. My two techs believe it can be the lower curved control arm considering that is what moves when backing into a spot. I have videos too. Here.
    http://youtu.be/Y0Ex-1XEYEA
    http://youtu.be/f_TyP0BS4ZM
    http://youtu.be/jUrcGRqIfpA
    Noises in the video are toward the end. If you get a chance take a look in a quiet spot(I know you guys are probably working right now)
    Apr 05 2012
    Long island, NY
    That last video almost sounds like a loose caliper bolt. Did u do brakes recently? And You should jack up the front end and have someone by the wheels looking as listening as you turn the wheel that's how I found my lower control arm bushing was bad you could visually see it move while the wheel was being moved back and forth
    Sep 13 2010
    Long Island, NY
    Yea I can't get the noise to happen with no load on it. And my caliper bolts r nice n tight 90ft lbs
    Sep 13 2010
    Long Island, NY
    My tech told me to jack the car up, wedge a big flat head screw driver between the subframe and control arm and lightly pry it and see how much play there is.
    Apr 05 2012
    Long island, NY
    Yeah i would suggest that too get a pry bar and wedge it in there and wiggle it see if you hear the knocking or see any play anywhere and also check your engine mounts sounds weird but if theyre worn out they can also make a knocking sound. Heres a good video from eric the car guy for some references http://www.youtube.com/watch?v=scFbb...V8JomfEPUeuqAI
    Sep 13 2010
    Long Island, NY
    Yea I did my engine mounts about a month ago. They r right
    May 16 2008
    South Texas
    Yes
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by Scotty@Advanced View Post
    Yes
    Yes??? What?
    Active Member Two Rings silver b5 s4's Avatar
    Jul 02 2013
    Albuquerque,NM
    What about the CV joints? I know I have a cracked boot and need it replaced. I also have this creaking noise when turning at extremely low speeds. Is this not the CV joint?
    Apr 05 2012
    Long island, NY
    this gave me a creaking sound
    Sep 13 2010
    Long Island, NY
    Quote Originally Posted by silver b5 s4 View Post
    When turning there should be a small click. That's normal I heard. Like a pin type click. Hard to explain. But my cv boots are all good
    May 16 2008
    South Texas
    Yes??? What?
    Yes is the answer to the question that was asked. ^^^^^^^
    Sep 13 2010
    Long Island, NY
    Here's a video of the play in my arms. The uppers r right and new as of September 2012. The curved seems to have play. The straight arm is very tight.
    http://www.youtube.com/watch?v=bB96QfPNUiM
    Up close video:
    http://www.youtube.com/watch?v=AoFDZnXfTcY
    And back in February 2011 I had a bushing noise. Similar but audi replaced the lower control arm bushings. One on the right side and one on the left side. Which lower arm did they touch? Bc if they touched the straight arm, then the curved arm has 115k miles on it. Lol
