Results 1 to 10 of 10
    Veteran Member Three Rings saizero's Avatar
    Aug 11 2009
    Chicago
    Does any know the part # to the Low fuel pressure sensor G410 connector?
    so long story short I installed my BSH catch can today and I accidentally broke the releasing tab off of the plug to the G410 sensor. Here's a pic borrowed from illegitimus' DIY to remove the HPFP.
    It's the grey plug I'm looking for. Any help would be appreciated.
    -Simon
    Current AWE Boost Gauge : STaSIS catback : 034 HFC : ECS Snub Mount : Upgraded Piston DV : CTS Turbo Catch Can : ER FMIC : DTM Front/Rear Votex Side Skirts : Stasis/Ohlins SL Coilovers
    VAGCOM Owner
    AKA: vmSAi
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    06e906051k
    Aug 11 2009
    Chicago
    Close, but I need the plug that connects to that sensor. I broke a tab off of it, now it fits loosely when plugged into the sensor.
    thanks though
    -Simon
    VAGCOM Owner
    AKA: vmSAi
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    In which case you are going to need a part of the engine harness that will be $$$$$$. Use a zip tie to fix it!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Aug 11 2009
    Chicago
    yeah I was able to find a VW PDF on the 2.0FSI engine last last night and saw that connector is apart of the main wiring harness that connects to the Engine management system. so yeah I'm SOL'ed. zip ties to rescue!!!
    -Simon
    VAGCOM Owner
    AKA: vmSAi
    Junior Member Two Rings
    Oct 19 2006
    Virginia, USA
    14 years later... here's the answer: 3B0973703G. You can easily source this connector on eBay.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    We're not that far but 12 years. Ha ha, I doubt the subject is still in existence but good to know!
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Feb 15 2016
    Cambridge,Ontario
    Yeah the dude is living in 2024 ?
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Nov 12 2020
    New BeDford Mass
    D179E9A4-511D-4C26-82A3-87FFDC2A3D9D.jpg91FC593A-6B16-4032-A1AC-76722E000E32.jpgD179E9A4-511D-4C26-82A3-87FFDC2A3D9D.jpg91FC593A-6B16-4032-A1AC-76722E000E32.jpgHey it’s an easy fixed, I just did it on my A4, go on ecs tunning.com
    3B0973703G (Connector)
    025682SCH01A (Tool)
    Nov 12 2020
    New BeDford Mass
    😆 I didn’t realize the date 🤦🏽*♂️
