Results 1 to 3 of 3
    Jun 15 2010
    San Antonio, TX
    Washer fluid reservoir capacity
    I'm using my washer fluid reservoir for my water/meth injection and trying to figure out how much it can actually hold. I've tried searching around and found many various number and haven't found the same number twice. The numbers I've found said 3L, 4.5L and one said it was over 5L if you have the headlight washers.
    Once the low level light comes on, how much space do I have left? I read that the sensor is fairly high up, but I'm pretty much mixing the water and methanol as I need it so I'd rather not have a bunch left over sitting around.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    My washer tank says 4.5L on the side and when the low level light comes on it takes around 3.7L to fill it back up.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Veteran Member Three Rings spokismB5S4's Avatar
    Jun 06 2009
    01.5 S4 6mt, 03 RS6, 91 coupe quattro, 12 STI, 02 S6 01E, 97 328is w/6266, 87 325is, 86 325e
    Yea mine says 4.5l on it as well
