Results 1 to 28 of 28
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    Advise...opinions...please amg monoblocks
    Hey guys, im about to go pick up a nice set of OEM amg monoblocks that were freshly refinished with a polished lip for very cheap, i just want to know your opinions on how they would look on my santorian, at the ride height im currently at, maybe a bit lower, i dont want to slam it because i like to corner fast and such=] Heres a pic of my car as it is now, and a pic of the monoblocks
    (not actual pic, the ones im looking to get also say amg on them.)
    6 Speed Single Turbo S4
    Q7 TDI S-Line
    Veteran Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    sick. i've got some 17' staggered monos from my old benz with all weathers on them that i've been wanting to throw on for winter. i test fitted and bolts from audi are too large around to fit thru the AMGs. im guessing yours will pose the same problem since they are genuine oem monoblocks, so maybe someone has the answer for us to fit these on. i've always thought they would look sick on our rides so glad to see someone with the same taste ;) will def. be checking in on this thread.
    ps slam the shit out of your car on 'em!
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    got the same wheels but mine are the aeroII 2 piece wheels and are 18x8.5 et44, idk wat size yours are. but if they are the same as mine. throw some 225/40/18 tires and your golden.
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Veteran Member Three Rings davidkae's Avatar
    Apr 20 2004
    Torrance
    Are those b6 avus wheels in the picture? What size spacers and tire size are you running? Looks great!
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    not advised, personally.
    benz hubs are alot bigger then audi, so you’ll need the hub rings, major ones.
    its been done alot, but test have shown + weight. on a couple levels.
    its possible but i don’t think its worth it IMO
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Quote Originally Posted by Yesmar View Post
    I'm not sure if the fact hub rings are needed is really an issue--did you mean spacers perhaps (and I'm not saying spacers are necessarily bad either)? Hubrings are needed for a variety of aftermarket wheels, including BBS wheels. If they are the proper size and installed correctly, there should be no issue.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    May 15 2009
    Harrisburg, PA
    mercedes wheels dont fit audi wheel, yeah, the same bolt patteren fitment, but the hubs simpoly dont fit...
    no i didnt mean spacers, maybey they willl help with any gap, but the mec hubs are larger then the audi hubs, so we need to fill that gap.
    i heard sometrhing about the 96 wheels on, but i still think they will need hubrings..
    idk..
    May 17 2010
    Colorado
    they def need hubcentric rings, 66.56 to 57.1 no biggie
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    OP do it, if i could i have a picture (on one of the 5 computers at home) of a set of 18x8.5/18x9 (iirc) amg mono blocks. looked sick.
    having said they looked great, it was a silver car, with a light salmon colored wheel. and it still looked good.
    Veteran Member Three Rings <CHILIBISKITS4>'s Avatar
    Nov 28 2009
    Lakeland Hills, WA
    it'd look good. and since you like it, thats even more reason. do it.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    idk..
    my BBS RFs were benz fitment with hub rings and my current BBS CHs have hub rings as well...not really seeing what the problem is. OP, benz wheels use a more narrow wheel bolt/lug so you will need to bore the lug holes out slightly. again, not a really big deal for a wheel shop
    Oct 20 2008
    fuck off
    Nov 09 2009
    tri-state
    yea thanks for the responses guys, hubcentric rings are no problem, a pro shop around here charges 45 bucks for the set installed, im just worried about the bolts and drilling them out, but im confused since the guy im buying them from has them on a mk6 gti and hes selling them with lugs would that work on my car, could they be drilled already by chance? (he doesnt know much so i dont even bother asking), someone help me out with this so i can go pick them up lol
    Q7 TDI S-Line
    Veteran Member Four Rings Aggv's Avatar
    Sep 26 2006
    Ohio
    I think all Benz wheels are 5-112, which wont require any drilling to fit an audi, but the hub centric rings are still needed
    S4
    May 07 2007
    Quote Originally Posted by Aggv View Post
    the diameter of the bolts is smaller though i think.
    Jun 10 2010
    Quote Originally Posted by .Mad Hatter. View Post
    Isn't Mercedes a 12mm lug hole whereas Audi is 14mm.
    I really like AMG Monoblocks on B5's as well.
    Nov 09 2009
    tri-state
    yea that what i mean, the merc bolts are 12mm and audi/vw is 14mm...but since this guy says they fit his mk6 perfectly fine, they might be drilled already?
    Q7 TDI S-Line
    Oct 20 2008
    fuck off
    Quote Originally Posted by Congratulati0ns View Post
    if they dont, can't you just get a stud kit from 034/ecs that works?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Holy misinformation, Batman! Some people should really step away from the keyboard when they don't know what they're talking about.
    Yes, Mercedes and Audi share a 5x112 lug pattern.
    Mercedes wheels have a 66.56mm hub bore, Audi has a 57.1mm. Hub rings for them are cheap and work great. MANY aftermarket wheel companies utilize them and they are perfectly safe and make your wheels fit as if they were machined with hub bore from the factory.
    Some of the older Mercedes used 12mm wheel bolts, Audi uses 14mm. Drilling out the holes bigger is very simple. Just get a good 3/5" drill bit and go to town on each lug hole being careful the hold the drill perpenticular (straight up). The bit will self-center itself in the existing holes. I've done this dozens of times without an issue.
    -Darrick
    Established Member Two Rings HelthInsXpert's Avatar
    Jan 22 2010
    996TT, Ducati 1098s, Stg III B5
    Columbus, GA
    I think they look fantastic.
    B5 S4 EPL Stg 3/ FLIK Arctic/ SSAC Dp's/ Piano Trim/
    Ask about Health or Life insurance in Florida, Georgia, Texas, and Arizona or click HERE
    Nov 09 2009
    tri-state
    Quote Originally Posted by davidkae View Post
    i didnt see this, so thanks and yea theyre 18'' b6 avus, 15mm spacers out back, 5mm up front, 235/40/18 all around, heres another pic, next to my buddies R
    Q7 TDI S-Line
    Nov 09 2009
    tri-state
    ok guys, going to pick up the wheels later today! Hopefully they fit or im gunna be pisseedd
    Q7 TDI S-Line
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    Did these ever fit right? Do you have installed pics?
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Nov 09 2009
    tri-state
    Nope never bought them since thhey weren't in the condition described however im currently waiting for tires for my new 8.5 front and 9 rear amg wheels from a cl500
    Sep 03 2008
    Wareham, MA 02571
    CL500 - Are those 12mm or 14mm? If 14mm you should be all set. I have an older set of 17X7.5 AMG Monoblocks, but with the 12mm holes :(
    I am going to try to drill them - some ppl over on vortex report great success...already have MB -> Audi hub-centric rings.
    Jun 10 2010
    I bought a set of Mercedes Six Slots and the bolt holes are 14mm. I think it all depends on the year (I think).
    Nov 09 2009
    tri-state
    Quote Originally Posted by audikidS4 View Post
    They are 14mm. front 18x8.5 and rear 18x9... i already ran benz wheels so i have hubrings and all that stuff, and yea you can just redrill them, i helped my friend redrill his with no problem, took a few minutes.
    I believe they stopped making 12mm one a while back, like pre 1990...i know all newer ones are 14mm
    Q7 TDI S-Line
    Jan 23 2011
    2000 S4
    Yorktown Heights/Ny
    Looks Good
