Results 1 to 19 of 19
    Senior Member Two Rings collins123420's Avatar
    Jul 07 2008
    '04 A4 1.8tcvt Moro
    How to tell if it's G12?
    I was reading up on coolants and read that if you have G12 in your car already then you can't top it off with anything other than G12, otherwise it'll jell up and cause problems. This is true right? And how do you tell if you have G12 in, or if it's something else? Living here in central FL I don't have to worry about it getting too cold, since it only reaches barely below freezing (and that's rare), so I read I should probably put in a 20% coolant to 80% water mixture. So, how to tell which coolant? Color? Any other recommendations regarding all this? THANKS IN ADVANCE!!!
    P.S. 2004 1.8t CVT (even though it doesn't make a difference lol)
    *SP*
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Color of G12 is PINK.
    You are correct. If there is a different type of coolant in the system (other than G12), it should be flushed really well and re-filled with G12. If you mix G12 and an alternate coolant bad things will happen. (Search).
    Mix ratio is 50:50 or up to 80:20 (water:G12)
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    i am pretty sure that you can only buy it at the dealer. i have never found it anywhere else. i normally do a 50/50 mixture...
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Quote Originally Posted by JEENYUS View Post
    audi/vw dealer, german auto shops should carry it (at least the ones around portland do), on-line. i dont think napa or autozone will have it. i also do 50:50 since i do drive/park in very cold conditions when i go skiing. being in florida though, you can do a higher water:G12 ratio.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Personally I would recommended sticking with a 50/50 mix no matter where you live. The coolant additives are formulated for a 50/50 ratio and they do more than just protect the block from freezing. What advantage do you expect to you see by changing it?
    Jul 07 2008
    '04 A4 1.8tcvt Moro
    I've heard that water has better cooling properties than the G12, since the G12 has more properties for freezing protection, and since I don't really have to worry about the freezing aspect that I should do 80% water 20% G12. Anyone else heard that?
    *SP*
    Dec 28 2006
    Western Maryland
    Water does transfer heat better. However, the coolant will raise the boiling point of the mix, so you are a lot less likely to have a boil-over with the 50/50 mix. Also, the cooling system in the 1.8T does a pretty good job keeping temperatures in check. The only time you hear of temperature related issues with the 1.8T (even for the BT and BAT guys) is when there is a mechanical problem such as a bad water pump or t-stat. As previously stated I would recommend using the 50/50 mix as the coolant was designed.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Heads up, G12, which is pink, has been replaced by G12+, which is purple. G12+ mixes perfectly fine with G12 (and G11, which is blue, the reason why G12 was reformulated into G12+).
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by FORCE_FED_DUB View Post
    But boy that g12+ is expensive as compared to the G12!! I had to pick up some coolant a few weeks ago when I blew my ECT sensor and I considered switching to the g12+ until i saw the price. It was almost twice as much as the G12 at the local v-dub dealer.
    Dec 19 2007
    York, PA
    any reason that i would want to pick up g12+?
    Aug 10 2008
    Denver, Colorado
    Was there truly a difference in cost, or was the VW dealer trying to liquidate their backstock of G12? They come up as the same part numbers, just a different suffix
    Quote Originally Posted by n7plus1 View Post
    No. From what I've read, G12+ simply solved a compatibility problem with their old G11 used in the mid-90's
    -Cam
    Dec 28 2006
    Western Maryland
    After some quick Googling this is what I came up with:
    In January, 2003, VW/Audi introduced G12+ (part number G 012 A8F A4), an antifreeze with purple coloration. It can be freely mixed with the original pink G12 (part number ZVW 237 G12). The VAG specification for G12+ is TL 774-F. From the information at the BASF site, Glysantin G 30 meets both specifications. The only significant difference between the two is the color - changed to help prevent people from thinking that GM Dexcool compatible (typically orange) coolant could be used to top-up the original G12 (pink), which is not the case.
    I also found out why it cost more: It is sold in a higher concentration so you don't need as much when you mix it with water.
    Active Member Two Rings PGH~DOPEST~B6's Avatar
    Sep 03 2010
    Lots of tools
    Pittsburgh,Pa
    They sell G-12 at my local Napa here....but most of the time they are sold out and you have to order it. But they do have it...and I'm sure any Napa could order it for you guys...maybe not but it might be worth a try because I'm sure its alot cheaper then a dealer. I dont remember the price off the top of my head but I'll try to find my slip if anyone is interested.
    WE THE PEOPLE~PITTSBURGH
    Jun 30 2008
    Erie, Pennsylvania
    I didn't know it came in different concentrations. Old Guy, can you elaborate? How do you get to 50/50, then?
    Dec 28 2006
    Western Maryland
    OK.... After a little more Googling I question the site that I was on regarding the concentration. Going to the the manufacturers site Clicky click it appears that the concentration mix is no different than the G12. Add more water for less protection against freezing, less water for more freeze protection. I guess the V-dub dealer was just gouging.
    Dec 19 2007
    York, PA
    i want to run purple b/c ive never seen it...interesting
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    How was the ECT sensor replacement? Mine just went bad...and the A4mods writeup makes it sounds pretty aggravating
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by CoreyRS View Post
    Having replaced the rear coolant flange a few years ago I was already intimately familiar with everything on the back of the motor. Consequently replacing the ECT sensor only took a few minutes. I did it by standing in front of the car laying across the motor and working my hands in from either side, doing it all by feel. If you have never done one it will probably take a bit more effort. It would help to use a mirror to at least see what you are working with before you start. The factory position of the retaining clip seems to be from the block side, so you will have to push toward the block on the clip "fingers". You can install the replacement clip in the other direction. Be sure to purchase at least 2 extra clips and "O" rings. They are dirt cheap and you will be hating life if you drop a clip and have to find it.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    FYI, some/most Napa's should carry the full line of Pentosin fluids. I get mine there, G12, AT-1, PS fluid and I think I got a can of super blue there too.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
