Originally Posted by
Le31504
confused... The N249 valve shouldnt have anyting to do with this... right?
the N112 maybe... but you are talking about an combination valve... and ist the combination valve the EGR (its in the same spot on the engine anyway... back of engine... metal mushroom thing
Sorry for my error. Brain fart. The mix up should not be causing any misunderstanding now.
If the N112 is leaking, that will apply a low amount of vacuum signal to the Combination valve opening the Combi valve slightly. If this is the case the exhaust pressure pulses are being heard through the Combi valve, through the SAI pump into the air cleaner via the SAI air supply pipe from the air cleaner. The fact that pinching the Combi valve signal line closed stops the noise is consistent with the N112 leaking slightly and the symptoms you describe.
To check the N112, use a vacuum pump with a vac gage attached, connect to the vac supply port on the N112 solenoid valve, disconnect the vac signal hose from the N112 to the Combi valve, and apply vacuum with the pump. If the N112 is leaking vacuum to the Combi valve, the vacuum applied to the N112 supply port will decrease/leak off, as shown on the pump vac gage, and will not hold steady at the test vacuum value applied by the pump. Don't apply to much vacuum to the N112 for the test. ~4 inHG or equivalent vacuum is enough test vacuum.
BTW, if the Combi valve is open even a small amount with a warmed up engine, and without the SAI pump running, the Combi valve can be damaged by overheating the valve seat inside from the exhaust gas flowing backwards into the Combi valve. To check the sealing of the closed Combi valve, remove the valve from the head and try and blow air through the Combi valve. It should not be possible to blow through the closed Combi valve. If you can blow air through the closed Combi valve, that will cause the popping noise in the air cleaner also, and is a result of the leaking N112 solenoid valve. If this is the case replace the Combi valve.
The 1.8T uses INTERNAL EGR, and is a function of the VVT, there is no separate external EGR valve.
