Put on my FSD/Eibach Pro set just last weekend and so far really like them.
For starters, the drop is perfect for me. See before/after pics here - from stock suspension (not S-line suspension).
http://www.audizine.com/forum/showth...Pro?highlight=
I will say I can see how some would say they're bouncy. At speed on the highway there is a bit of recoil, but I wouldn't go so far to call it a bounce. Going 70 over a bump or depression is going to cause some suspension movement. I was thinking about it last night as I was driving on the interstate. My thought was I did feel a bit of movement, but it wasn't like boing, boing, boing.... More of a down, up, and settle. My impression was that maybe the stock suspension would have just eaten that bump up whereas a sport suspension would have just slammed you and been done with it.
I'd call the FSD an OEM+ damper. The ride to me does feel tighter than the stock base suspension I had, but doesn't feel like a true performance sport suspension.
In the end, it depends on what you're going for. If you want minimal body roll, tight cornering and don't mind a jarring ride, then don't get FSD. If you want a daily driver that handles better than stock, then go for FSD.
Ultimatly, my decision points were:
- Wanted lower ride, thus needed springs or coilovers
- Didn't want to pay for quality coilovers, so that meant springs
- I've read that adding just lowering springs to stock suspension can at best cause premature wear of shocks or at worst be a shitty ride
- I didn't want a shitty ride or have to replace blown stock shocks in 1 year or whenever
- So that meant shock/spring combo
- I didn't want a rough ride. Sure, I'll take less body roll and better handling, but would compromise some handling for a good dailey driver
- From what I read, that's Koni FSD. So far, I agree
Search here and Audi Forums for reviews. I came across many that were very positive. Good luck.
