Results 1 to 21 of 21
    Established Member Two Rings Reggieroo's Avatar
    Sep 15 2010
    2000 Audi S6 Avant, 93 V8 Range Rover classic.
    Worcestershire, UK
    allroad jacking up mode?
    What's the allroad jacking up mode all about? It tells you in the manual before the car is raised on a jack to put it in jacking up mode?
    Last week in the tyre shop they just jacked it up & removed the wheel to do the balancing.
    I'm going to test fit some alloys today so wondered if it's necessary?
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    If the vehicle is not in Jack Mode there is a greater danger of damaging the shock absorbers/pneumatic dampers/other parts.
    Senior Member Three Rings MLFHNTR's Avatar
    May 29 2010
    '04 Allroad, '02 GTI
    Daytona Beach
    The jacking mode is simple
    -make sure you are in level 2
    -with the car not running but the key is in the accessory pos
    -hold down the up and down buttons together
    2 Hooker Limit...
    Embry-Riddle European Car Club President
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    you can be in any level, definitely put the car in Jack Mode. it locks the suspension into a fixed level, so the car does not attempt to level itself while being lifted. If you continually jack it without lock the suspension, you likely screwup the compressor, bags and sensors. As stated, just hold down the up and down buttons at the same time until the dash icon illuminates.
    Sep 15 2010
    Worcestershire, UK
    I used the jacking mode when test fitting the wheels, have to make sure garages do the same in the future.
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Is this also necessary when putting the car on a lift?
    '91 Coupe Quattro - 034, H&R, Autocraft, Keskin - S2 look alike
    '06 A4 Avant 2.0T Quattro Manual
    '12 Touareg TDI Lux
    May 29 2010
    Daytona Beach
    yes is the wheels are going to free hang. if not the car will constantly try to adjust itself.
    2 Hooker Limit...
    Jan 18 2008
    Chapel Hill, NC
    Quote Originally Posted by MLFHNTR View Post
    I was under the impression the keys had to be in the on position for the car to begin the leveling process. Is that not the case?
    '12 Touareg TDI Lux
    May 29 2010
    Daytona Beach
    My AR will adjust for my trailer when i put it on there when the car is in the off position. you can here the rear bags inflate after adding the weight. sometimes it will do it when you are sitting on the back as well.
    2 Hooker Limit...
    Jan 18 2008
    Chapel Hill, NC
    So if an Allroad is sitting in a parking lot with one corner dipped down all the way, this would imply that the pump is burned out?
    '12 Touareg TDI Lux
    Sep 11 2009
    NE
    Quote Originally Posted by j_sonel View Post
    No, it only implies that the bag in question has gone bad. The car will self level without ignition on (parked) only if there is still pressure in holding tank. The car will not start the pump without ignition on to re-fill the tank. Hence a leaky bag will cause the tank to run out of air eventually due to auto adjustment and that corner will sag.
    Jan 18 2008
    Chapel Hill, NC
    Quote Originally Posted by julex View Post
    Excellent info. Thanks!
    '12 Touareg TDI Lux
    Senior Member Two Rings JustMtnB44's Avatar
    Nov 22 2009
    Pittsburgh, PA
    Can anyone think of a good reason that Audi wired the allroad so that the suspension can still adjust itself without the keys in the ignition? In my opinion, this makes no sense and is somewhat retarded. There wouldn't have to be a jack mode and the concerns that go with it if the suspension just stayed where it was when the car is shut off.
    Current: 2016 Golf R
    Past: 2004 allroad 4.2, Ebony Pearl Effect FBP, H-sport sway bars, Phatbox MP3 player, stock 18" wheels with Continental DWS tires, stock 17" wheels with Yokohama Geolandar tires, custom tow hitch
    Sep 15 2010
    Worcestershire, UK
    A funny thing happened yesterday morning when I went out to the car, the front was dropped right down. It's ok this morning & hasn't happened before. So after me putting it in jacking mode that day, jacking it up to fit wheels etc the front suspension dropped over night, I hadn't driven it either after fitting wheels, just left it on the drive. I had to put it in jacking mode like four times that day to change wheels & the last time I did it I left the engine running?
    May 29 2010
    Daytona Beach
    Quote Originally Posted by JustMtnB44 View Post
    never thought about it actually
    Quote Originally Posted by Reggieroo View Post
    I know the only time i really found to front being down is when i forgot jacking mode when i went to do an oil change. After dropping it off of the jack the front bags were deflated.
    2 Hooker Limit...
    Registered Member One Ring solidjon's Avatar
    Sep 15 2015
    Southport
    I'm in the UK and my allroad has new Arnott air suspension and a new compressor, yet I can just leave it on the drive for a couple of weeks when I'm not driving it, and the suspension will drop all round. I can't imagine faulty Arnott's or the new compressor, so what's my problem. Any advise would be really appreciated, and my battery will drain flat too. I've owned the car since 2009, and I"m on my 3rd battery, and I never buy cheap nasty batteries either, Bosch Silver, Exide deep cycle, and I can't remember the one on at the moment, but it was around the £100 mark, thats about $140.
    Thanks in advance.
    May 22 2010
    N.E. Connecticut
    Quote Originally Posted by solidjon View Post
    Thanks in advance.
    You have either a ground issue or it is short circuiting somewhere from a frayed wire touching metal. Or something is not turning off & draining the battery.
    Active Member One Ring lo7us's Avatar
    Jan 22 2017
    A4/B5, A6/C5, R1200GSA, 4Runner, Tahoe
    Sonoma, CA
    So I took my 2001 allroad to get front and rear wheel alignment. I mentioned the "Jack mode" 3 times! When I went to pick it up the drivers front bag was popped! Now they are claiming no fault, it was worn and if he doesn't find a "cut" (presumably from a tool) then it's not there fault 😬 Can anyone else verify that of the car was not on "Jack mode", then that would cause the air bag to pop. Also, should the other side be replaced at the same time? This is going to be way more expressive, and I'm just wanting to verify the failing to use the Jack mode would cause this popped shock air bag
    Jan 22 2017
    Sonoma, CA
    So, the alignment shop, messed up the order for the replacement part, broke my hubcap, any I had to pay $789.00 to get me car back, and the steering wheel is still not straight 😡🤬😠
    Established Member Two Rings SUBAMMAS's Avatar
    Mar 15 2020
    PacificNW
    Quote Originally Posted by lo7us View Post
    Sounds like you should take them to small claims court. That's messed up.
    '05 Allroad 4.2
    Jan 22 2017
    Sonoma, CA
    Technically, yes but who wants to spend any energy revisiting the total BS. I have a motorcycle service business, 15 years now, and if I mess up, I own it, fix it, learn from it. Ironically he wants me to repair a bike be has... So I might be able to recover some of my money, but I'm still working for it. I looked at the popped drivers front air spring, the alignment shop said it was original (it was not because Audi had the 4 rings on the factory air springs) he claimed because there was not visible tool cut, that it just "happened" to fail when the worked on the car! I repeated the "Jack mode" three times to the manager, but I should of said it again to the tech who actually worked on the car. It's very clear to me, he did not put it in "Jack mode" and the lowered shock kept pressurizing to equalize the suspension and consequently over-pressured the air spring. 🤪
