Results 1 to 40 of 43
    Established Member Two Rings bigACA4's Avatar
    Sep 29 2010
    LI
    Question Need some advice on good mods for my 2001 a4 1.8t
    I'm currently running a Borla exhaust system. Everything else about the car is stock and I want the car to be a bit more fun to drive. Right now it only has about 165hp and I want to get around 200-250hp. Any suggestions?
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    chip it
    test pipe/hfc
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Veteran Member Three Rings euroazfck's Avatar
    Jul 18 2010
    98 audi a4_ 88 civc hatch "jdm"
    colorado
    Fmic,chip,air filter
    Sep 29 2010
    LI
    Thanks guys I appreciate it, that's what I've been hearing about alot and I just wanted to get alot of opinions before I go through with it. I want to feel a noticable difference in the power of the car I guess this should do the trick.
    Mar 18 2008
    a chip alone will put you into the hp range that you are looking for.
    Then it's just a matter of supporting the power with:
    upgrade intercooler, upgrade dv, maybe upgrade turbo inlet hose/pipe, and new air filter.
    After the power comes upgrades to get the most fun out of the car.
    So suspension, sway bars if you want to, brakes, and good tires.
    APR chip, APR turbo inlet hose, evolution fmic, h&r coilovers, ddm hid, S4 projectors, forge dv, vdo boost gauge.
    Sep 29 2010
    LI
    Thanks kf3506 that was alot of help, i just hope this does not blow a hole in my wallet. I'm not looking to go too serious with all of this. I heard modding becomes an addiction. =0
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    stop while you can!
    get the giac X chip and a HFC and an upgraded DV and call it good. you wont need a FMIC unless you plan on slapping on a different turbo.
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Established Member Two Rings xRAYx's Avatar
    May 30 2010
    Chanhassen/MN
    BAT nuff said
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Chip.
    Sell and buy a 2.8 :P
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    I went with a GIAC chip when I first got my car along with a "hollow" cat and 2.5 piping all the way back. The car really woke up. Get a K&N Drop in panel filter. I think it was around 210hp.
    Make sure if you go with GIAC to get a green coolant sensor :)
    For Sale $3,500 -'99 Audi A4 1.8T Quattro 5sp
    -2001.5 Audi A4 1.8T Quattromatic - BT .50 trizzle -RIP
    Sep 29 2010
    LI
    So I think I'm going to replace the stock K03 with a K04, put a silicone turbo inlet hose, CAI from APR and an R1 diverter valve, no chip.
    Sep 29 2010
    LI
    Quote Originally Posted by discontained View Post
    you know i had a K&N panel filter and I didnt like it too much, I still have and may go back and forth from time to time
    THANK YOU ALL FOR YOUR INFO I APPRECIATE IT.
    Oct 03 2008
    what garage?
    Pittsburgh
    Quote Originally Posted by bigACA4 View Post
    Without a chip, you will barely notice a Ko4
    16' Silverado HD
    Sep 29 2010
    LI
    Quote Originally Posted by SantorianA4 View Post
    That sucks =| i know the chip is one of the more popular mods i just dont know if i want to do that. Its going to be a daily driver and im just looking for a little more noticable power. Not a big increase
    Jul 09 2007
    '01 A4 1.8t
    GA
    its not that much i went from K03s 12psi to k04 18psi to k03s 20 something psi to T04e :)
    without a chip you really wont notice a efficient gain. A Cold Air Intake is not worth the money on turbo cars, better off getting a FMIC
    Veteran Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Dont really need an FMIC with a k03 either...not untill k04 or bigger. Save that money for coilovers.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Look at my mod list. The chip was the best bang for your buck. I WISH I would have done the suspension next to be able to control that power. Don't waste your time with the tip, Cai, or Fmic unless you plan on going atleast k04.
    Get the chip and slap on a suspension. Keep an eye out on the classifieds bc you can pick up some great items, cheap. I'll be selling my ecu with Apr flash on it once I go bt. Atw engine code.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    You won't notice anything unless you install this
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
    Aug 25 2008
    rhode island
    ^ you do internals for your 2871 setup?
    Sep 29 2010
    LI
    Quote Originally Posted by adr3naline fix View Post
    hahaha thats insane. idk if im looking to go that far.
    Oct 03 2008
    what garage?
    Pittsburgh
    Honestly man, If i were in your shoes i would get a chip/dv and forget about the rest.
    A chip is the only *cheap* mod that will give you serious power increase without losing the DD reliability aspect.
    16' Silverado HD
    Sep 29 2010
    LI
    Thumbs up
    I feel you , im just taking in all opinions and suggestions bc im totally new to all of this and i want to get into it
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    Oh man, warning! The more power you get, the more you want. I'm so freaking hooked, I'm like a junkie.
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
    Senior Member Two Rings pattshreds's Avatar
    Dec 26 2009
    too many things right now
    south shore, ma
    Quote Originally Posted by flynnr View Post
    stop while you can!
    do not get GIAC unless you like your motor in peices. go unitronics
    Dec 26 2009
    south shore, ma
    LOL true
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Nos.
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Sep 29 2010
    LI
    Quote Originally Posted by bikerbob951 View Post
    thats exactly what im afraid of haha. i just dont want to sell my car an get an S4 with more miles so im looking for some modifications.
    Established Member Two Rings DrkZide's Avatar
    Aug 08 2010
    Denver
    Aren't chips like $400?
    I'm at the beginning of modding the Wife's Audi too. Looking at Carbonio, TP, DP, Exhaust, Chip (if I can ever decide on which one), DV, TIP, Trip chip, FMIC, K04 and I think that's it.
    Absurdum est ut alios regat, qui seipsum regere nescit
    "De Oppresso Liber" - "Nous Defions"
    Sep 29 2010
    LI
    [QUOTE=DrkZide;5736371]Aren't chips like $400?
    Nice, and she's up for it?
    Aug 08 2010
    Denver
    Quote Originally Posted by DrkZide View Post
    It was her idea.
    Nov 11 2008
    Oxnard, Ca
    Aren't chips like $400?.
    nah... u can get speedtuning for around $200..
    but they can be up to 500+
    Speedtuning, 2.5" custom exhaust to a Magnaflow, K&N pannel, Forge Splitter, VDO Boost Gauge, Neuspeed Race springs, KONI adjustables
    Sep 29 2010
    LI
    It was her idea.
    Damn.
    2001 A4 | Borla Exhaust |
    Sep 29 2010
    LI
    Thumbs up
    Quote Originally Posted by nova_ss672001 View Post
    sigh -_-
    Jun 30 2008
    Erie, Pennsylvania
    PM k0mpresd here on the forums. He can do a flash tune on your 2001 ecu. Probably the cheapest option for a chip. He can also do emission deletes on it as well (secondary air, cat efficiency, etc). Great guy to work with.
    Senior Member Two Rings 01'.B5.Phil.G's Avatar
    Apr 14 2010
    Nor*Cal/Daly City/CA
    I also have an 01' 1.8TQM and so far I've installed a GIAC-X chip, 710N Bosch DV, 034 Motorsports HFC, Techtonics 2.5" downpipe back Borla exhaust, on H&R coilovers and I'm fairly satisfied with it for the time being. I'd recommend checking the classifieds section for the B5 under engine/performance. I got everything for my B5 on there. Luckily everyone was local and I picked up the parts in person and am very happy with the deals I got. Also check out the regional forums and check out the classifieds section in your area. Once my K03s goes I'm going BT. Thinking of GT28RS eliminator kit. Also if your turbo goes scratch the K04 upgrade, I think it's only est. to about 15-30HP more from the K03S.
    GL with your upgrades!
    Jul 11 2008
    Vail, Co
    K04, MTM software, FMIC
    Dec 17 2008
    Milwaukee
    Quote Originally Posted by wesleyfbm View Post
    Sry for late response. No, you do not. The GT2871R can be tuned to about 350awhp if tuned very aggressively (rod limits at about 375 for AWM, 400 for AEB). I'm at 307awhp (on a good day) and there is no need for rods. To further show the stability, I have had the same turbo and tune for the last 35k miles.
    My car is SOLD
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    nitrous
    Jul 29 2015
    Vancouver
    Quote Originally Posted by kf3506 View Post
    Are you saying to upgrade the entire air intake system to like a cold air intake or just get a better aftermarket filter?
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Motoza E85 tune and supporting mods; HFC/test pipe, 710n DV, Ebay fmic. Your car will be fun!
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
