Results 1 to 21 of 21
    Established Member Two Rings Baruch's Avatar
    Jun 28 2010
    08 A4 Qt 6 Sp MT, 06 GSXR 600
    LI - NY
    Fuel Pump DIY Removal/Installation Guide
    Anyone know where to find one, tried searching the forum but to no avail - I may be border-line retarded so don't make fun of me if there a bunch around. DIY Injector removal/installation I could use as well!
    THanks in advance!
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Try searching for a DIY for the cam follower, as it involves removing the fuel pump. I know there are a few out there. Try google if you don't find one on AZ.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Senior Member Two Rings rings65's Avatar
    Jan 14 2008
    '06 A4 S-Line
    Wheaton/Winfield, IL
    This is for the follower but should be the same steps:
    http://picasaweb.google.com/BJ.McGee...llowerInstall#
    Veteran Member Three Rings U2RedEye's Avatar
    Aug 20 2009
    B5 S4 Avant (Santorin Blue)
    i cant recall how i found it, but i know there's a fuel pump removal DIY on AudiWorld. i changed my own several months back. its not too difficult. i own an Avant, so its a bit different as far as location. one piece of advice...MAKE SURE YOURE FUEL IS BELOW 1/4 TANK. it makes the job a bit easier. also, make sure you place pump and sender leads back on firmly!
    Team A.C.E. NY ...Hobby? Lifestyle!!
    R.I.P. Sway
    ...STAGE 3+ in progress...
    ...More To Follow!...
    Aug 20 2009
    http://www.audizine.com/forum/showth...nt.?highlight=
    here's the thread that has the link to the DIY. pardon my last post, it wasnt audiworld....
    PS....read the whole thread as there are pointers from several ppl which would have helped had i read through it the first time.
    R.I.P. Sway
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    is the fwd and quattro the same? I know it's located at a different location
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    for the cam follower replacement i cant remember where but in the later models (that have more flexible fuel lines and do not use the banjo bolt) don't you just have to unscrew the long torx bolts and gently pull the fuel pump back, grab the old follower, put the new one in and swap the o ring? rather then completely removing the fuel pump
    apology for the threadjack
    Aug 20 2009
    Quote Originally Posted by plokm View Post
    are you speaking about the fuel pump location?
    im lost on this one...but maybe it was directed more at the OP?
    R.I.P. Sway
    Jul 08 2010
    tucson
    danbury
    i was just asking a question i dont actually know if that is possible but i remember reading it on a forum somewhere and i was hoping i could get better confirmation as my cam follower is going to need replacing soon
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    Quote Originally Posted by rings65 View Post
    I put together a DIY loosely based on the photo guide you just provided... Here's the thread with the link to the PDF which you can download http://www.audizine.com/forum/showth...orm?highlight=
    Feb 19 2007
    Louisiana
    im talking about the intank pump
    Aug 20 2009
    as far as the in-tank pump, from my understanding the difference is in the avant vs saloon, not quattro vs fwd. the avant has the access cover under the cargo mat as opposed to the saloon/sedan which is under the back seat.
    now as far as the cam follower issue, i have no knowledge about it. you may have to search the forums for info on that.
    R.I.P. Sway
    Oct 16 2008
    South Florida - Ft Lauderdale
    This might help: http://www.audizine.com/forum/showth...ent?highlight=
    I replaced both, left sender and pump (right side). Pretty straight forward but BEFORE YOU EVEN START, BUY THE TOOL TO DISCONNECT THE FUEL LINES.
    Tool is only $15: http://www.ecstuning.com/Audi-B7_A4-...All/ES1306816/
    Phil
    Jun 28 2010
    LI - NY
    Thanks a bunch guys! Really appreciate the info - now once i get some money going to be taking it out and sending it out... anyone know a good DIY guide to switching out the injectors? Probably going to do S3 injectors being that Im not going to be doing a big turbo -Ko4 max
    Jul 18 2007
    Lancaster CA
    Quote Originally Posted by mr shickadance View Post
    I know this is an old thread but for reference I left the rubber hose connected. Had to move the hose out of the plastic guide to allow more length to maneuver. Then carefully took out the pump to replace the follower. It's still pretty tight but doable.
    Senior Member Three Rings jonnybravo's Avatar
    Nov 23 2009
    San Jose
    How did you remove the 2 lines? Its too damn tight to fit the fuel line pliers in there. This damn intake pump is a pain in the ass!
    Phil
    Oct 16 2008
    Nah, you just have big hands
    phil
    Nov 23 2009
    San Jose
    Haha...must be..Took a longer then I though but I ended up getting it done.
    phil
    Oct 14 2009
    Okinawa Japan
    LMFAO at no ones knows if op is reffering to lpfp or hpfp hahaha, when I had my lpfp out I had to use some PB blast to loosen up the ring that holds it down, this in turn caused my lpfp gasket to get a little stretched :-/
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Aug 18 2008
    Florida
    Accidental bump.
    '24 RS3 Daytona Grey Pearl
    Jul 18 2007
    Lancaster CA
    Quote Originally Posted by jonnybravo View Post
    I will say that removing those fuel lines was by FAR the most difficult thing to do out of all of the maintenance jobs. Did it without tool but ended up snapping off the tabs. If you do need to replace those send and return lines I have them. Bought them just in case but turned out that I didn't need them. Will sell for half the price, comes as a pair- PM me.
