Results 1 to 22 of 22
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    Running no snub mount
    If your running track density motor, tranny and rear diff mounts, Do you even need to run the snub mount?
    Flame if you want...
    And what motions is the snub even stopping? The front and backwards movement of the engine when engaging/disengaging the clutch? And wouldn't a DTS bar stop that from moving then?
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    I noticed when my snub mount was missing but I have stock mounts everywhere else. You could really feel it kick when shifting. Put in a 034 mount setup and it's a lot better.
    Why you wanting to get rid of it?
    97 Audi A4 Laser Red 1.8t Quattro 5spd STOCK FOR NOW
    Aug 17 2009
    Pittsburgh
    Quote Originally Posted by revbjeff View Post
    I would imagine to reduce more weight up front by doing a custom aluminum lower rad support without worrying about the snub mount.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    I think there are other things to do to replace weight other than removing the stock radiator/snub mount. Just my .02
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    Quote Originally Posted by biketsai View Post
    x2
    Sep 10 2008
    Ontario
    It doesn't support the rad. Its only a boost pipe and snub. I'm running a fmic anyways so I only use it for a snub.
    And I have the 034 snub and cradle right now.
    I mainly wondered what it tries to accomplish since I couldn't find an answer from searching all different key words about it.
    Jun 04 2007
    Austin/DFW, TX
    I believe it reduces play in the driveline. Especially when under load the front of the motor wants to pop up, a good snub mount prevents it from shifting/tilting back.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    The snub is not directly at the center, so my guessing is it's mostly to take the engine twisting its way through the hood and help the longevity of the engine mount.
    Jun 30 2008
    Erie, Pennsylvania
    Excess engine movement is hard on other things as well, like the exhaust flex pipe, wiring harness, intercooler pipes, etc.
    Aug 13 2008
    Indiana
    The snub mount is more of a torque mount not a motor mount but removing it would be extremely undesirable.
    -Nic
    Sep 10 2008
    Ontario
    Okay, I will just chop off the inlets on the sides and weld them up.
    I would have just thought the engine wouldn't be twisting much since I'm running the firm track mounts everywhere.
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    If you have track mounts ( engine x2 and trans x2? ) and a DTS I cant imagine it even mattering. The track mounts allow NO movement. Just make sure you get the JHM solid DTS mount.
    .02
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
    Aug 13 2008
    Indiana
    Quote Originally Posted by 2001A4QUATTRO View Post
    .02
    IMO that's like saying you have race springs on 3 wheels so you don't need your 4th wheel.
    -Nic
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Well most track mounts are a little softer than a solid set-up, but not by much. Track mounts are not hydraulic they are solid poly. With 2 engine, 2 trans mounts and a solid DTS... That is better than the car came stock. If I was saying to take out one of the main mounts than I could see what you are saying. As stated previously, the snub is only a torque mount. /
    Established Member Two Rings adam.wilber's Avatar
    Sep 15 2010
    NC, Fort Bragg
    i replaced my factory snub mount with an APR poly mount... now for my question... what might happen if i swap out my motor/tranny mounts out for solid aluminum ones?
    Sep 10 2008
    Ontario
    You will get some vibrations. Even with my firm track mounts there is vibration, but barely anything. I only really notice my hood vibrating in the sun, and I like it since its like I got a muscle car engine in my car.
    Deactivated Two Rings
    May 13 2010
    Long Beach, CA
    Quote Originally Posted by dowsett6 View Post
    The reason why you have a Snub Mount is cause the Front axles are connected directly to the Engine.(engine being bolted to Trans etc) With the resistance of the Axle turning/rotating, it causes the Force on the Trans/engine to lift in Opposite direction. For Example: Driving forward, the engine wants to lift.... if you drive backwards the engine wants to Drop down. The snub mount was design to help Aid In keeping the motor level. One reason why all S4 motor mounts always crack, Is because of the motor lifting during hard Acceleration.
    Sep 10 2008
    Ontario
    Quote Originally Posted by Info@RavenMS View Post
    Okay, thats an awesome reply. And actually makes alot of sense. Keeping the 034 cradle and snub for sure.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    here is what happens when not using a snub mount.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    you also have to remember that the front snub mount bracket/boost pipes help tie the left and right side of the frame rails together, removing that will have a lot of unwanted movement especially once your in boost
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    034's Time Attack B5 has track density mounts all around and they do not run the front snub mount. The track density mounts don't have any play in them. With the stock rubber motor mounts, there is a lot of slop that the snub mount helps to eliminate.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jun 05 2007
    2001.5 A4 1.8TQMS
    ^^^ Great reply. I believe everybody here doesn't listen to what was already posted twice...
    While using the stock mounts the snub is definately required.
    While using track density MM and TM and a solid DTS the snub mount is useless.
    Extra mounts cause extra vibration sometimes. I had a track acura integra and had full track rear, pass and drivers side MM.
    I also purchased the 2 front torque mounts. Had TONS of vibes. Turns out that the front two torque mounts were not necessary
    due to the fact that the track mounts were solid.
    /thread
