Results 1 to 37 of 37
Thread: Tips & Tricks
    Jul 07 2010
    Minneapolis, MN
    Tips & Tricks
    I tried to search if there was a thread for this but the search fuction is not the greatest.
    I'm new to the car but I just realized that the rear view camera actually has parallel parking mode too if you press top right button on MMI (Guys don't read manuals you know). Another ones:
    - the << >> buttons on the bottom allow you to FFW/REW the song if you hold them down down.
    - Left side scroll wheel in the steering wheel works as a selector button
    Anything other cool small things you guys have found?
    2011 Audi S4 | APR EMCS Stage 2+ Tune | APR Pulley | APR Stage II Intake | AWE Cat-Back | Hoen Fogs | H&R OE Springs | LED Lic. Plate Bulbs | Black Front Filler Plate | VAG-COM | Hotchkis Sway bars | Frozen Adam's AR Rotors + StopTech SS Lines + Motul 600 | Alu Kreuz | VMR v713 | RS4 Grille | Ecodes
    Veteran Member Three Rings K1speeder's Avatar
    Aug 29 2010
    San Francisco
    To mute the radio, press down on the volume toggle on the center console. That was something that I did not have in my B7 S4 and drove me nuts. Is the parallel parking thing only on the 2011? I can't seem to find that for me... Not like the car is hard to parallel park anyway
    2017 Q5 3.0T P+, Brilliant Black
    Past: 2015 S3 P+ • 2010 S4 Prestige, Meteor Gray • 2009 Q5 P+, 3.2, NAV, Brilliant Black
    I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
    Jul 07 2010
    Minneapolis, MN
    Not sure if it's only for 2011. When you put reverse on there's a icon on top right corner which shows the parking mode. Then if you press the top right button next to the big console wheel it changes the mode.
    Senior Member Two Rings Dlepez20's Avatar
    Jul 31 2007
    Phoenix
    I have a 2010 and it's on there. Never noticed it till now. Thanks! Although I'll prob never use it bc we hardly ever have to parallel park in PHX :)
    Veteran Member Three Rings BKNYCS4's Avatar
    Jan 14 2010
    Quote Originally Posted by Dlepez20 View Post
    Yea lucky you! I have to parallel park every dam day ... next to some morons that dont give a crap about their buicks with the huge metal bumbers.... so you can imagine how that is.... luckily i have only one scratch so far that i need to touch up...
    2010 Phantom Black S4, 6MT, Fully Loaded *SOLD
    2019 Nardo Grey SQ5 Fully Loaded *SOLD
    2020 Blue Metallic A6 3.0T, Fully Loaded *SOLD
    2017 Daytona Grey RS3, Fully Built TTE700 *CURRENT
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Quote Originally Posted by JMN View Post
    Nothing new. Same on my old B7.
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by ibiski View Post
    Same as my old 86 Ford
    Veteran Member Four Rings LeadToRome's Avatar
    Apr 25 2010
    I-95
    Your '86 Ford had a back-up camera? Nice.
    The trick I'm looking for is the one that keeps the radio from coming on, loud, every time I start the car. Most of the time I don't care but sometimes, like early in the morning and coffee-deprived, sometimes it is pretty damn annoying. Why does it even come on? Is Audi an investor in radio stations? Are they convinced that we all need more noise, all the time? Is it to cover up the noise deficieny from the exhaust? Enquiring minds want to know!
    Jul 07 2010
    Minneapolis, MN
    One thing I would like to find out (before i get desperate and dig into the manual) is there any way to make AC just into 1 zone? so you don't have to adjust drive/passanger/read heat separately?
    Senior Member Two Rings CowtownSteve's Avatar
    May 30 2010
    Calgary
    agreed this is a huge pain in the ass
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by LeadToRome View Post
    I was addressing this to fast forward trick lol
    Mar 01 2010
    Farmington Hills,Mi
    on b5/b6/b7 models u just have to hold Auto button for few seconds
    Veteran Member Three Rings Deep Sea S4's Avatar
    Nov 06 2009
    As far as the climate control there is a button for ac sync but it only seems to work forma short period of time then reverts back to separate sides.
    But the is a button in the setup mode
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    The parking brake automatically releases when you have enough power to over come it. Nice touch for a manual car.
    With the key-less entry and engine start option the trunk lid will not latch down if the key is inside it - I wonder which gender that is for! I haven't been willing to try it on a car without that option.
    Individual setting for the Audi drive select will let me change it so that I can have all the go fast settings and lazy steering.
    Of course these are things I have found on other people's cars but cool stuff nun the less.
    Quote Originally Posted by JDMB1975 View Post
    There maybe a setting in the car menu or somewhere in the setup menu. I know the fan speed is the same for both sides and can't be changed independently - I had to look that up in the manual for a customer and point it out to them.
    Senior Member Two Rings dr bryan's Avatar
    Apr 12 2010
    Tualatin, OR
    Just hold the driver side climate control button in for a few seconds until both sides pop up on the screen. They are now locked together. If the passenger side is adjusted it will go back to individual settings.
    '17 S6
    Active Member Two Rings Nav's Avatar
    Feb 03 2010
    2009 BMW 335xi, 2005 BMW X5
    Toronto/Ontario
    If you push the temperature knob in and hold it for a couple seconds it changes to 1 zone.
    Feb 03 2010
    Toronto/Ontario
    Quote Originally Posted by JimmyBones View Post
    It would be normal to assume that all the car's air is coming from one fan no? So i guess that's why you can't individually control what side gets how much air.
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by Nav View Post
    That is exactly the reason but the customer didn't realize that until I explained it to him. After that he still said no for fixed right the first time in the CSI survey which screwed me for the month too.
    Veteran Member Three Rings awhk82's Avatar
    Jul 13 2007
    Hong Kong
    Try turning off MMI (holding the centre console volume knob for 2 seconds until you see the MMI splash screen) before shutting off your car and the MMI will remain off until you hit the volume knob again.
    2012 RS4 Avant - Suzuka Grey
    Capristo Catback, HMS X-pipe
    Before...
    11 TTRS | 10 S5 SB | 08 A4 3.2 | 06 A4 2.0T | 05 A3 SB 2.0T | 04 S4 | 99 A4 2.8
    Established Member Two Rings HDClown's Avatar
    Aug 20 2010
    Orlando, FL
    Kind of related, but kind of not. On cars with NAV, when you press the right-side scroll wheel on the steering wheel, it will speak the next navigtation direction (if guidance is enabled), but when guidance is not enabled, it just says "navigation is not active". On cars without NAV, I've been told pressing this wheel mutes the volume. Anyone know of a way to change this behavior on NAV cars so that the press will do mute when guidance is not active OR, to just totally change it to a mute button all the time?
    2011 S4 - Quartz Gray on Black Alcantara - S-Tronic, Sport Differential, MMI Nav Plus, B&O, Carbon Atlas Trim, 19" Five-Tri-Spoke Wheels
    Apr 25 2010
    I-95
    Quote Originally Posted by awhk82 View Post
    I guess what I meant to say is I wish there was a way to keep the radio from coming on for a lazy, forgetful guy.
    Senior Member Three Rings legbend's Avatar
    Sep 06 2009
    Chi
    The parking brake thing only seems to work if you have your seat-belt on, apparently.
    2010 S4 - SOLD
    Prestige, Drive Assist, Sport Diff
    Exterior | OEM Black Optics Grille
    Engine | Stratmosphere Intake, Stasis ECU
    Veteran Member Three Rings Tenedorr's Avatar
    Apr 23 2014
    2007 Audi A4 2.0t
    Maine
    IDK about radio power but I know there is a volume preset for when you first start the car.
    Mar 26 2010
    US
    With the headlight switch in auto mode, the headlights will come on, when one hits the foglight switch. This is handy for rainy days, when headlights need to be on if the wipers are running (it's the law in CA & it is often too bright for the headlights to come on automatically).
    When the headlight switch indicator is orange, the daylight running lights are on, when green, the headlights are on also.
    BMW M3 Competition X-drive
    Nov 21 2013
    United Kingdom
    Would be a nice touch if the reversing camera could be switched on when normally driving. Reason being I will be going on a Swiss/Austrian tour in June in a group of 12 cars, be good for the passenger to view what's going on behind.
    Any suggestions guys ?
    2014 S4 Black Edition.
    Nav High 7.5"
    B&O dsp surround
    Sports Diff
    Full Audi Drive Select
    Interior ambient lighting
    Euro Piano Black Trim.
    Apr 28 2014
    austin/tx
    Quote Originally Posted by The.Wizard View Post
    ...or if you're trying to throw down some banana peels?
    Feb 25 2013
    MI
    Quote Originally Posted by ATX_S4 View Post
    Don't forget the green turtle shell
    Veteran Member Four Rings SilveR316's Avatar
    Jun 01 2013
    Downtown Toronto
    4 year old necro thread... nice.
    You can turn down the radio to level 1 or something, and it should be at the same volume when you start the car next time. Kind of annoying that it won't remember that you muted it though.
    2017 S6|Sepang Blue|Black Optics|Silver Mirrors|ASC WiFi Module|AWE Exhaust|034 Drivetrain Mounts
    2014 S4|Prestige|Estoril Blue|6MT - AWE 102mm|Alu Kreuz|KW H.A.S.|SPC Control Arms|20x9.5 Vorsteiner V-FF 102|Vorsteiner Front Spoiler|Deval Valence - Build - SOLD
    Nov 08 2013
    2013 328i Convertible
    Lafayette, Colo
    Quote Originally Posted by dr bryan View Post
    This works on my 2011--great feature since this was driving me nuts until I mentioned it on another post and someone gave the answer!
    Established Member Two Rings toerag's Avatar
    Apr 17 2013
    UK
    mine does, just hit the parking button..
    Monsoon - Magma - Black Edition - B8.5 S4 Avant
    Senior Member Four Rings riseabv's Avatar
    Sep 04 2013
    2010 Mercedes C350
    Southwest
    Quote Originally Posted by toerag View Post
    14 s4 glacier white | b&o | carbon atlas | h&r OE | SPC uca's | 19x9.5 Stance SC6 | Hoen fogs | 15% Pinnacle Tint | Roc-Euro | Magnaflow exhaust | Special Goodies ...
    Apr 17 2013
    UK
    Quote Originally Posted by riseabv View Post
    If I push it at any speed the rear camera comes on and stays on
    (not my picture, same button though)
    Jun 01 2013
    Downtown Toronto
    Probably a European thing. American S4 models don't have this.
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by SilveR316 View Post
    How can I make this happen?
    Currently, my radio starts up at something less than what it was when I turned off the car. For example, radio is at volume level 15 and I turn off the car. I start the car the next morning and the volume is at 7. Same thing if I mute it. Volume level is 15 and I mute it. When I unmute it, the volume level comes back at 7. Again, not actual numbers, but the volume ALWAYS comes back on at something less than what I left it at. Why can't it just stay where I put it?
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Established Member Two Rings webvictim's Avatar
    Jan 07 2013
    San Jose, CA
    Don't have this in my S4, but I had a loaner 2014 A6 that did.
    2013 S4 S-tronic • Sports Differential • Moonlight Blue • Black Nappa Leather • Stone guards • CF inlays • Advanced key • 19" peelers • B&O • Hardwired V1
    Apr 17 2013
    UK
    enables/disables rear camera & front/rear parking sensors, maybe an avant thing
    Jun 01 2013
    Downtown Toronto
    Quote Originally Posted by VR2V8 View Post
    Not sure, but I've noticed that my 2014 leaves the volume at what it was previously. The mute/unmute thing used to annoy me a lot, so I started turning the volume down to 1 before turning the car off and it's still set at 1 when I turn it back on.
    Quote Originally Posted by webvictim View Post
    Could be an avant thing. I know a Q5 I was in recently had this feature as well so it's not like they don't have it at all here.
