Results 1 to 12 of 12
Thread: EGT thread ?
    Jul 10 2009
    Audi S4 B5 Avant
    Finland
    EGT thread ?
    I have tried to search everywhere, no luck.
    What thread is on the EGT sensor?
    I'm planning to put other EGT sensor on OEM manifold.
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Nevermind
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Senior Member Three Rings ^@ViVid's Avatar
    Sep 03 2010
    2000 S4, 2004 SHD RL, 2003 MDX, 1st Gen RX-7 700whp
    San Diego
    Jul 10 2009
    Audi S4 B5 Avant
    Finland
    "You have to still use the factory EGT sensors or else the car will go into limp mode. You can use vagcom to display your temps. If you want to have a gauge that will display the EGT, one of those OBD2 ones that will give you an EGT reading, or you can drill a hole in your manifold, thread it and put an aftermarket one in. "
    I have googled, but no luck. I could find any answer to my question from your link Vivid ? Or did you try to say to use google?
    My EGT's are deleted. All this is familiar to me. Just want to know what is the thread size on manifold that I can find right plug and on the other side PLX EGT sensor.
    At the moment it's not possible to me to unscrew one of the EGT's out and measure thread.
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    If your EGT's are deleted, why do you want to plug them? Just leave them in.
    EPL Stage 3 with a bunch of other crap.
    Sep 03 2010
    San Diego
    Yah I was just saying google it : ). You're best bet would be to take the sensor down to a hardware store and measure it. Most of them have device's in the bolt/tap section where you can get thread size, and pitch.
    Mar 10 2009
    il
    Not to thread jack OP, but what kind of effect does an EGT delete have on performance and fuel economy etc?? does the car run rich w/o EGT's? does it pass emissions tests? (in cali)
    Jul 10 2009
    Audi S4 B5 Avant
    Finland
    M.S4: Yes, that's one way to go. But I want to have EGT reading in my cabin and I already have PLX boost sensor and AFR on DM100 display.
    Also my EGT sensors are quite new ones, so I can sell those with good price !
    So I need one plug on the drivers side. Passenger side is where I want to put EGT sensor (easier to access). Problem is that sensor thread is 1/8" NPT.
    Now I want to know what is OEM EGT thread?
    Choices:
    1. Buy reducer from OEM size to 1/8" NPT (Is it 1/4" to 1/8" NPT? )
    2. Make new 1/8" NPT thread and plug OEM thread on the manifold
    3. weld 1/8" NPT fitting on place of OEM
    Best choice would be 1. Of course I can take oem EGT out and go to shop and measure thread. I Don't go details here why, but it would be so much easier to me knowing thread and buy right reducer.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    I'm not good with measurements and stuff, but I have an EGT kicking around and it has 1/32" between each thread and is 3/8" wide (not including where the threads stick out a bit). The threading lasts about 1/4".
    Hopefully this can help?
    Brilliant Black 2001 S4 - 6MT <3
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Quote Originally Posted by MakkeS4 View Post
    Choices:
    Did you get the right answer yet Makke ?
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jul 10 2009
    Audi S4 B5 Avant
    Finland
    OEM thread on manifold is M12x1
    Veteran Member Three Rings judeisnotobscur's Avatar
    Apr 22 2009
    America
    thank you very much... this will go down in history as the most complete thread on AZ.
    a question folllowed by an answer... we should sticky this. LOL that the OP answered his own question.
    Timing is Everything
