Hey guys!
I hope all are doing well. I have not been on in while because I have been moving/settling in. I moved from New Jersey to Washington state. As a refresher i drive a 2000 silver S4 Q6MT. For the longest time now my front driver door has been "unaligned". Like in all Audi's it is very simple to close the door. However, mine seems to be hanging angled slightly down. When i look in my rearview mirror you can see how the window trim is a little bit lower than the rear door. This makes shutting the door a pain. I am forced to apply a little extra force or even re-close it when it does not shut. I am writing to see if anyone has any tips on how to fix this issue. I have already played with the mechanism on the pillar and adjusted it as much as i could. Are there any other adjustments on the hinge side? If so how do i go about adjusting the door. Any help would be greatly appreciated.
Also, I tried to do the headlight restore DIY but mine did not come out looking like the one in the DIY. As the final step I used the MCguires headlight restore. I used sand paper all the way up to 2000 grit. Should i have gone higher or do i need to get something besides McGuires?
Thanks again for helping out.
-Pavel
Bremerton, Washington
