Results 1 to 16 of 16
    Active Member One Ring agentblack's Avatar
    Nov 28 2008
    edmonton
    Dual Cold Air Intake
    Just watching some videos on you tube and I noticed that this B5 S4 with a dual intake.
    I'm wondering if anyone else did this and what the response is.
    I could not find any other info about it.
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    not on stock engine management. our cars use a MAFS so youd need megasquirt or 034's efi setup to switch over to a MAP sensor
    Established Member Two Rings ProPain203's Avatar
    Jun 07 2009
    "Tha 203" CT
    is that one of the members with the tial 770 build?
    2006 Saab 93 Aero 2.8t 6MT
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    actually you could do it but it would really be a waste. There is a product you can buy called maf splitter or maf joiner. Basically it takes the avg of the voltage between 2 mafs (so yes you would need to buy another maf as well) and then avgs them and sends one signal back to the ecu. This is less than ideal since you may have a leak or faulty sensor in 1 and it may still avg them as if both were perfect.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    How is that cold air? The inlet piping is touching what appears to be the wastegate. There's no heat shielding anywhere.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    Quote Originally Posted by ProPain203 View Post
    NO, it's wicked motorsports GT car
    http://www.youtube.com/watch?v=61VpJlUpNHg
    Enjoy yo self
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    It is entirely possible to run a mafless set up on our cars using just the MAP sensor instead, although you would need a custom tune by someone that really knows what their doing and in your case its not worth it.
    Jun 14 2007
    2000 S4
    Connecticut
    Pretty sure GURUMAN also had a similar setup..
    When you get turbos that big and have all that custom plumbing, then get that intake setup!
    Feb 09 2007
    00 S4
    MA
    Yes. They fastest cars with the biggest turbos run mafless and have dual intakes and no MAFs.
    That being said. It is entirely possible to do it on a stock car.
    00+ A4's run on just the MAP all day. no reason an S4 can't (on stock management) the downfall is that with dual intakes and no MAF, every sensor is more important, to the point where if one starts to fail (say an 02) your car will run like shit.
    That may not deter you. fine. Buy a MAF splitter and buy another maf, you get the badass look, and dont have to spend 2G's+ on RS4 upper intake shit. Or get a tuner that is OK with tuning a MAFless car, Im pretty sure VAST can (and have done) it.
    it seems to me, that because this hasnt be tried and proven that everyone says its a dumb idea, but I think buying RS4 upper intake parts vs. experimenting with MAFless or Dual MAFs, not buying Rs4 parts may be a more cost effective option, that is if it actually works. I havent seen a single car that is not on stand alone, not running a maf (or two mafs for that matter)
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Quote Originally Posted by omgwtfbbq! View Post
    i was thinking the very same thing... nothing cold about those intakes, just cool lookin
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    They arent trying to get cold air they are trying to eliminate restriction. The champion racing speedvision GT b5 s4 runs the same way using a pectol stand alone system.
    Aug 24 2008
    Santa cruz
    Quote Originally Posted by bandit View Post
    You can see javad from 034 tuning it too in the dyno vid
    Jan 11 2007
    Salt Lake City, Utah
    sfored has something similar
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Nov 28 2008
    edmonton
    its does look bad ass and probably solves the y piping problems
    Aug 15 2009
    2001.5 S4---1988 toyota cressida (1uz turbo swap in progress!)
    maryland
    Does cold air really make that much of a difference the turbos are jus going to heat it right back up, thats what the big ass smic's are for right?
    Oct 26 2006
    A lot of B5 S4's
    WA
    Its all about the restriction not the cold air (or lack there of). I think it would be very beneficial to run a maffless set up on these cars with some custom inlets with just a filter on the end. I'd imagine on a K04 car and a proper custom tune you could see some pretty considerable gains. This is something I plan on talking to Jason at AMD about when I get my K04s on. There are a lot of DBW 1.8Ts that run a maffless set up with no issues on the stock ME7 ECU.
