Originally Posted by
old guy
An exhaust leak at the flex joint shouldn't affect the idle. It will only make the car noisier. You most likely have a small vacuum leak somewhere.
I didn't think it would affect it but it was the only noticeable thing i could find and wanted to verify.
MikeWire
An exhaust leak at the flex pipe would just be loud and probably annoying.
Oh, it is.
RecklessTuning
your exhaust could fall off at the turbo and it wouldn't cause your car to shut off.
again, this is what i though, just wanted to verify.
Thanks everyone. I'll check for leaks, clean the MAF, and change the plugs.
i hope that napa has a flex joint in the right size so i don't have to wait for it to be shipped, then i can get it welded in tomorrow.
I think a full check valve replacement on both cars might be the next project.
* been a bad few weeks though, on the tiptronic the front suspension is making an awful clank when hitting any bumps - don't know what i'm going to do about that yet, prob put on some koni struts and springs, maybe a lower cost coilover setup, we'll see. won't be for a couple months anyway.
* it's now dumping coolant out the turbo return line (replace the feed line last week), don't have $200+ for a set of braided lines right now so i'm just using some 250deg rated coolant hose from napa, hope it holds up being that close to the turbo. going to fix that up tonight.
* and i noticed oil leaking in at the valve gasket on cly1 this morning when swapping the coils from one car to the other. valve cover is easy from what i hear, that will prob get done later this month or next.
the 5spd has this new exhaust issue, the idle issue, a clunk going in and out of 2nd gear (only second from what my fiancee says), and need to install the O2 sensor i got for it.
just sucks trying to do all this in the driveway with limited tools.
