Results 1 to 19 of 19
    May 08 2007
    aeb 2.0bt, 00 bagged 1.8, 93 s-10
    jacksonville, nc
    Is there a manual release for the fuel lid?
    Im waiting for my new locking pump to be delivered, and my doors are unlocked and the fuel door is stuck on lock. I am low on gas and I just realized that the pump actually stopped working. What I have been doing was to take out and put in the fuse that controls the locking pump to control the windows and the locks.
    Is there a way to manually open the fuel door from the trunk? Or am I stuck leaving it parked until it comes in?
    Veteran Member Three Rings Jc61990's Avatar
    Aug 22 2008
    2002 Audi TT 1.8TQm
    Long Island, NY
    id say go in the trunk and pull back the carpet. see if you can get it from there
    JC | 2002 Denim Blue TT Coupe 1.8TQm
    Past: 1999.5 Brilliant Black A4 1.8TQ
    Aug 29 2010
    Tampa FL
    i just push the door in an it opens, i didnt know we had a fuel door realease in the car
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    Quote Originally Posted by Brujo View Post
    theres a little bar that holds the fuel door closed when the car is locked. You would never know it was there unluess you tried to fill up with the car locked.
    To the O/P, i kinda think your screwed. Maybe under the carpet in the trunk.
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
    Veteran Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    be very careful and use some neednose?
    AWM BAT A4 / AGP D42 .48 / Tapp 630 / IE Rods / LwFw+ S4 SB / APR Stealth / Garrett-Precision 450 / 2001 FWD Highway Menace
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    if you pull back the carpet, there is a plastic handle that you pull to open the fuel door. it is intended for this exact reason.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 03 2008
    what garage?
    Pittsburgh
    Quote Originally Posted by zrowcool View Post
    Good to know, theres your answer.
    16' Silverado HD
    May 08 2007
    jacksonville, nc
    Awesome, Thank you. I will try that tomorrow.
    Veteran Member Three Rings SeekB00st's Avatar
    Dec 09 2008
    A tricycle
    Nofolk VA (Its Hood Here)
    What.
    I've rebuilt two interior on these cars and never noticed such latch.
    Either one of us has been doing crack.
    Put Werk Here
    [/SIZE]
    Deactivated Two Rings
    Jan 22 2008
    canada
    Quote Originally Posted by SeekB00st View Post
    What.
    Must be you. It definitely exists. White plastic clip that holds the rod that locks the fuel cover. I believe there is a red vacuum tube running to it. Pull it back. I had the same issue when my central locking pump died. Called up the dealer, and they told me about it.
    Jun 19 2008
    Coquitlam, BC
    Quote Originally Posted by donraja84 View Post
    Yep..it's there on my 1998 A4 Quattro as well. Mind you, both donraja84 and I have Canadian model cars.
    Sometimes there are slight differences between Canadian and US market vehicles ( Applies to all manufacturers of cars and light trucks ).
    Jan 29 2007
    08 S4 00 S4
    MD
    There is an emergency opening procedure in the owners manual, which shows you how to manually slide the vacuum operated pin that locks the gas fill door. It's not a release handle per se, but it will open up the door for you. Not sure how different it is in Canada.
    08 S4- Stock SOLD
    May 08 2007
    jacksonville, nc
    what i did was unclip the module that controls the rod for the fuel door. ill leave it like this until i get in the locking pump. thanks guys
    Dec 09 2008
    A tricycle
    It is in the trunk on the passenger side?
    Put Werk Here
    [/SIZE]
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    My interior is completely ripped out already, I am going to go look for said lock-release!
    MontrealAudiClub
    Jan 22 2008
    canada
    yeah, on the passenger side. Open your fuel cover and see if you see a metal rod that comes out when the doors are unlocked, and goes in when the doors are locked. If you do, then this is the rod connected to the white clip. If you followed the rod from the fuel cover into the trunk behind the carpet, you should see a white plastic clip latched into the metal....maybe i'll take a pic!
    Jan 22 2008
    canada
    Metal Rod on the white plastic right above the central locking pump (to give you an idea of the location):
    When Clipped in:
    Senior Member Two Rings Stumanbmx's Avatar
    Nov 04 2007
    '00 A4 1.8TQM
    Minnesota
    Pictures aren't working for me.
    Jan 22 2008
    canada
    Quote Originally Posted by Stumanbmx View Post
    Edited the post - should hopefully be working now.
