Results 1 to 28 of 28
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Map controlled thermostat fault code
    17701 - Map controlled engine cooling thermostat (F265): Short to plus
    P1293 - 001 - Upper limit exceeded
    This DTC keeps coming up. Any ideas as to what may be the cause?
    I'm guessing thermostat needs to be replaced? Just wanted to confirm with you guys first. This doesn't seem to be a common issue. Most people just replace them when they start to leak...
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    You need to replace the thermostat housing with sensor. The sensor is bad. I just did mine the other day. When I took the thermostat housing out the sensor was all corroded. Ordered mine through Europaparts, like 80 bucks. There is also a writeup on how to change the housing which is spot on.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Sep 15 2010
    massapequa ny
    can you just change sensor or is it built into housing?
    Quote Originally Posted by POPO View Post
    is it possible when i flushed coolant last month i screwed this up? will this damage car driving with this code?
    Control Module Part Number: 8E0 909 518 BC
    Component and/or Version: 1.8L R4/5VT G
    0010
    Software Coding: 0016751
    Work Shop Code: WSC 13873
    1 Fault Found:
    17700 - Map Controlled Engine Cooling Thermostat
    (F265): Open Circuit
    P1292 - 004 - No Signal/Communication -
    Jun 23 2008
    Quote Originally Posted by Trev View Post
    Just vag-com'd my car tonight and got...
    Engine:
    17701
    P1293
    So I should change the thermostat housing, engine coolant temperature sensor behind the engine and their is another right next to the thermostat? So I should order 2 green coolant temp sensors?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The thermostat has a heater, not a sensor. MAP controlled thermostat There are two sensors. The green four pin sensor on the back of the motor and the gray 2 pin sensor in the lower radiator hose.
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    This could also cause high rpm at idle due to the t stat giving incorrect readings and or making the car think its constantly in warm up mode? I got this map controlled code but also noticed higher rpm at idle. My car is hanging around 1000 rpm now. When I kick on my a/c, it drops it back down to below 1000 rpm at idle.
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Nov 21 2011
    UK
    i have the same error code - can the green sensor be replaced to rectify this or as above does the whole thermostat need to be changed? Is there a link to the thread to swop it out?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by fla View Post
    Green sensor won't cause a mapped thermostat code. Here's a DIY for the t-stat: Clicky click
    Thanks to Matt
    Jun 07 2012
    Lansing Michigan
    The sensor in the t stat can't be removed. I think it may be a blue one, or a green one. I tried before sucking it up and buying the whole t stat unit for 100+$.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Kodymfk View Post
    The thermostat doesn't have a sensor. It has a heater that the ECM uses to force the thermostat open sooner than the normal mechanical opening temperature.
    Jun 07 2012
    Lansing Michigan
    Ahh, I see. Ya, I had the same code. Tried to replace just the sensor or mechanical item connected to piece. Found out that wasn't possible and replaced the whole unit. Been good to go since.
    Nov 21 2011
    UK
    Thanks to Matt
    As usual great info, thanks OG. What would be the effect on running this with the fault as I wont have time to do this for a few weeks :( ?
    Apr 07 2011
    Dec 28 2006
    Western Maryland
    You should be OK. The mechanical portion of the thermostat should still function. You have just lost the ECM's ability to open it sooner under high load conditions. just drive your car gently (no excessive full throttle runs) and you should be fine. You may notice your cooling fans running more than usual but that's about it.
    Jun 09 2016
    u.k
    I know this is an old thread but can the blue sensor on the thermostat housing part be changed on it's own or not?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by caluma4x4 View Post
    It is not a sensor on the map controlled thermostat. It is a heater embedded in the wax element that actuates the thermostat opening. It gives the ECM the ability to apply power to the heating element and force the thermostat to open under specific conditions. If you unplug the heater the thermostat will continue to function as a high temperature thermostat. No it is not replaceable.
    Jun 09 2016
    u.k
    Thank you old guy, I have to get this part replaced soon, I did change the J plug whenI got the car as it was leaking. The car did run very warm one day, I think that has killed the heating element in the thermostat.
    The cooling fans never ran so I suspect the relay, can you point me to it's location at all, thanks again for your help.
    On further searching it's more likely to be the fan controle module, a common fault apparently.
    Dec 28 2006
    Western Maryland
    T The car did run very warm one day, I think that has killed the heating element in the thermostat.
    On further searching it's more likely to be the fan control module, a common fault apparently.
    Running hot wouldn't hurt the heating element in the thermostat. If it overheated while driving it would more likely be the thermostat sticking. If it overheats at idle that could indicate a bad fan or fan control module.
    Jun 09 2016
    u.k
    I refilled and bled the system and it hasn't done it again since, just the fault code for the thermostat 17701 short to plus, upper limit exceeded. Will change it as soon as I can
    Thanks old guy.
    Sent from my ANE-LX1 using Tapatalk
    Junior Member Two Rings
    Aug 21 2019
    Sweden
    Hi, old guy. I have an A4 1.8t With two issues/problems that bothers me.
    first: A coolant flange that leaks, (new one ordered and will be replaced soon)
    second: High rpm at idle (more frequent when Engine is warm).
    The coolant temp is stable around 90degrees so theres no problem with the thermostat.
    When i do the scan i get:
    P1292 Map Controlled Engine Cooling Thermostat (F265): Open Circuit
    P0507 Idle Control System RPM: Higher than Expected.
    My first question:
    Do you think the p0507 fault code is caused by the P1292 fault code? (as mentioned by Kodymfk) or do you Think the code is set by something else. E.g vacuum leakage ?
    second question:
    The fault code p1292. How accurate is error detection? Could it be anything other than the MAP controlled thermostat that could be faulty. In addition to cables and items connected to MAP controlled thermostat.I do not want to change MAP if it is not necessary, after all it costs a little money.
    my idea was to change coolant flange and maybe order a MAP!??, replace both, and hope it solves my two problems. If the idle problem does not go away then I have to start looking for vacuum leakage. If you have any other suggestions, I am grateful for answers
    Dec 28 2006
    Western Maryland
    The P1292 is a pretty specific code. You have an open circuit to the thermostat heater. It's either the heating element is burned out or you have a faulty plug or broken wire. The element is pretty easy to check. Just check for continuity across the element. If you have continuity on the heating element the problem will be somewhere in the wiring to the element.
    The P0507 is most likely being caused by a vacuum leak somewhere. With the engine at idle clamp off the vacuum hoses one at a time that are connected to the intake manifold. If clamping one of them causes a reduction in the idle speed you will know where to look for the leak.
    Aug 21 2019
    Sweden
    Ok. Thanks! Gonna measure the connector to the heating element, probably/hopefully the fault is in the heater...then do some fault isolation on the vacuum hoses.
    Aug 21 2019
    Sweden
    I measured the heating element in the MAP Thermostat and I got endless resistance so I guess it is short circuit there. I decided not to do anything about it because the thermostat works anyway and it doesn't leak.
    I also inspected the PCV valve (035 103 245) and found that it was broken, it has now been replaced and the car's idle works perfectly
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I had the P1293 code a while back and replaced the whole thermostat assembly. A few months later, and the code keeps popping up again. Has anyone had similar issues?
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Jul 10 2015
    Colorado
    Quote Originally Posted by BumblebVR6 View Post
    What brand did you use?
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by kwilson View Post
    Mahle or HT brand from ECS I believe.
    B6 USP Avant
    AMB + GSX28RS
    Jul 10 2015
    Colorado
    I've read that there have been many problems with the aftermarket thermostats. I only use genuine thermostats, and have never had a problem.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I’m thinking the same thing. I have a low mileage oem thermostat I removed from my other motor. I think I’ll use that on the new motor I’m building or get new oem. Thanks.
    B6 USP Avant
    AMB + GSX28RS
