Results 1 to 15 of 15
Thread: Axel Bolts
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Axel Bolts
    Are the rear axel bolts reusable if you torx them to spec or are they crush to yield aka one use only?
    TIA
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jan 29 2007
    08 S4 00 S4
    MD
    They are torque to yield bolts, designed to be used once.
    08 S4- Stock SOLD
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by mholme View Post
    agreed. You can reuse them if they're in good shape and torqued slightly lower if you're in a bind, but I would not exceed 80mph with re-used bolts.
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Vegas
    Audi and Bently, etc say to never reuse the front or rear axle bolts, but I have for a while. My boy with an B6 A4 has 2 reused front bolts for almost 3 years now...so I'm not sure how vital it is to use a new one EVERY time to remove your axle for whatever reason...
    Rob B. - Kansas City, MO
    2001.5 Nogaro S4 | 6 speed | Alcantara | DD with no major mods
    2008 A4 2.0T | Wife's car
    Senior Member Two Rings jms-4's Avatar
    May 14 2009
    2000 Audi S4, 68 Mustang
    Renton, WA
    The bolt is designed to stretch, hence the massive torque spec. Once metal stretches the first time, it loses it's strength. Take a paperclip and straighten it, then bend it in half a straight a bunch of times. What happens? Eventually it breaks.
    My issue is that after doing some CV boots, when I use the new bolt, I can't get it completely torqued to spec, even with a 5ft extension and a friend. I can't get the 180 degrees, but rather closer to 90.
    Jeff
    2000 S4
    Revo w/SPS3
    AMS TBB, Stern snub mount, Apikol Rear Diff Mount
    3" custom exhaust, Minor lemmi tweaks
    ST Coilovers
    710N, EBC Slotted + Dimpled
    Incognito Piggie Pipes, 034 Density Trans Mounts
    Voodoo MBC Ceramic in MBC only mode
    other stuff
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    I thought this thread was about cv axle bolts. But the correct term here is collar bolts.
    Yeah I would never reuse them. You should always use new collar bolts.
    But in response to the comment above. I can only stretch them 90degrees as well. Manual says 180. Raxles says 90..................Dont know what to do. Ive used a 3' breaker bar and I still cant get them to budge.
    Sep 16 2005
    Asheville, NC
    I've always felt like a girlie for not being able to get those torqued to 180 - glad to hear someone else has that problem. I also had a helluva time trying to torque the flywheel bolts when I changed my clutch.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    May 14 2009
    Renton, WA
    I even went out and bought a breaker bar that is rated up to 500lbs of torque and still couldn't get it to go past 90.
    I'm not worried about leaving it at 90 degrees
    Jeff
    2000 S4
    Revo w/SPS3
    ST Coilovers
    other stuff
    Sep 11 2007
    Tampa, FL
    Id love to see a poll thread of those you actually did torque it that much and what they used to do it.
    Sep 11 2009
    NE
    Quote Originally Posted by *Blue-Angel* View Post
    Axle bolt? I did... not a big deal with heavy duty ratchet and few feet of iron pipe :). Just apply as much force as you can, I usually just literally either jump or hang off the extension until it is torqued to spec.
    Now the flywheel bolts are different story. These suckers are impossible to torque to specced value as couple of things work against you... engine is usually sitting on some crate so with enough torque it will start moving/tilting, that's after you overcome the problem of crankshaft spinning along with the bolt (24 mm socket+ratchet+some pipe on crank bolt will stop it from moving) and on top of that flywheel is surrounded by engine pieces that will prevent you from using short sockets and with extensions it is impossible to apply enough torque before the socket slips off...
    Seeing how the bolt looks...is there a special socket out there that will both utilize bolts outer hex pattern as well as tap inside star pattern?
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    I torqued it to spec. I had to use a 5 ft piece of pipe over my breaker bar.
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    i have reused my a4 front axle bolts twice and no problem for over 3 years, at most speed ranges 25-120mph and track days also
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    GSXR 1000, 2010 A4
    Hayward, CA
    Sounds like some of you need to hit the gym!
    X2 for reduce- reuse- recycle!
    Sep 11 2009
    NE
    Quote Originally Posted by skinnytirez View Post
    Hehe, unfortunately gym would have nothing to do with ability to troque Axle bolts. If anything, the fatter the dude the better as he could just lean/slump over/sit on breaker bar and exert far more power than moderately built/fit person :)
    Dec 03 2007
    Lots of grease and special tools to work on the Avant
    Raleigh, NC
    Quote Originally Posted by bw86 View Post
    X2
    Just replaced both axles last week. I thought at any minute the freakin' bolt was going to snap. The longer the pipe the better ;)
    01' S4 Avant - The Silver Sleeper
