    Oct 06 2009
    AUDI S4 B5
    Hull, United Kingdom
    1.8T Passat FWD 5 speed - 1.9tdi FWD 6 Speed Manual transmission Swap
    Hi there any advice on this please if you've tried it, feedback would be great as im thinking of doing it... Im hoping to ripp through gears on GT30 build on the standard FWD box so would be good to have longer gears and for the extra 6th gear would be better for driving down to shows economy .
    B5 S4 Franken Turbo
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    well i dont know much about the swap or if anyone has done it before, but i know acouple people who did hte s4 6spd swap in a 1.8t, and the gear ratio difference is horrible, you have no low end torqe, the gears are very long, yes you are pulling less rpms everywhere you drive but power was a big compromise, comapred if you have a pretty built car with enough power then it might be a good match. maybe the tdi tranny is geared completly different and usses lower gears because its a 4cylinder motor also and just offers a longer overdrive, im sure someone on here can give you some answers
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    What do you want to know?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    Most people doing a 1.8 build stick with the stock 5 speed...they just upgrade the clutch
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Oct 06 2009
    AUDI S4 B5
    I have a upgraded clutch and flywheel, would that all mate up with the tdi box? i just wanted to know if it could be done and wondering what the gearing would be like.
    B5 S4 Franken Turbo
