Results 1 to 12 of 12
    Established Member Two Rings cmaust's Avatar
    Jan 09 2010
    suspension noise after replacing all ctrl arms, tie rods, and sway bar links
    i bought the front suspension kit and installed, and now my car makes a clunking noise on the right side when i go over a bump, similar to the sound of when my CA's were worn out
    did i do something wrong? or is it possible that something is loose? everything was double checked but perhaps i did something wrong during the install
    Veteran Member Three Rings BLopes07's Avatar
    Nov 08 2009
    North Jersey
    this is ironic. i had my bro's shop install h&r coils on my b7 and i have the same clunking sound in the front right. I had it checked and they say everything is good and they dont know why it does that noise.
    [Audi 2006 A4 2.0T]-Revo Stage 2-custom borla exhaust-034 Silicon Turbo Inlet Hose-034 Test Pipe-Oem Piston Diverter-Carbonio-VMR Boost Gauge-v8 coils
    -Full S.Line Conversion-S4 Door Blades-Deval Lip-Oem Titanium Rims--H&R Coils-Titanium Grille-ECS Drilled and Slotted Rotars
    Jan 09 2010
    thats weird.. the next day i have off im gonna take off the wheel to get a better look but everything looks alright.
    i havent taken it for an alignment yet, but its barely off, and i dont see that being the issue anyway.
    Nov 08 2009
    North Jersey
    My car is all allighned everything was done right but for some reason it make a noise like a screw isn't in correctly. I'm on the same boat and yest I got it double checked and mechanic said everything was perfect but idk way to do anymore it's annoying
    Active Member Two Rings Racerx220's Avatar
    May 05 2010
    Philadelphia , PA
    i just changed my control arms and tie rod ends and all that and i get a clunk noise sometimes to everything is tight i normally get it going into a drive way or going from fwd to reverse
    Apr 18 2007
    ny
    Check the sway bar bushings
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Check the upper and lower shock mounts, make sure the aluminum plate at the top is tight to the body, check sway bar mounts.
    Jim
    I Do Werk.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by BLopes07 View Post
    Probably the top shock mounting nut. Far too many people don't tighten this nut properly by using an impact gun. A loose nut here is very common with suspension installs, and always will cause a clunk.
    Senior Member Two Rings rxphiler's Avatar
    Jan 22 2008
    05 Porsche Cayenne TT, 06 Ford Expedition King Ranch, 92 UrS4 sedan, 05 Volvo V50 Wagon
    Charleston, SC
    x2 on the sway bar bolts they have to be tightened while under load. I did my front end and had a similar clunk and it was the sway bar.
    2000 A6 2.7T MT6
    Darin intake, B&M short shifter, power gaskets and cheap ebay trunk lip spoiler... oh yeah an a little push from GIAC!!! C5 union
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    My vote is for the sway bar links number one and the the upper nut on the shock number two.
    Try the easy one first...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Jan 09 2010
    well this is quite embarrassing
    the lower rear CA didnt even have a nut O_O
    im glad i parked the car and checked it as soon as possible. who knows what could have happened. i appreciate all the help though
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    X1000 on the sway bar links. If they are loose, that "clunk" is more than likely them. I had the same issue on the rear of the car and it was the rear links. Im putting my chips on the links. GL
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
