It is very difficult to get car into Reverse (hardest), 1st, 2nd, when car is is on. Have had the stick pop out of my hands trying to put into 2nd and heard a little gear grinding. Clutch pedal travel is still the same, and I have no brake warning light.
I did some research and found that if the car will run through the gears while its off I likely have a clutch problem, rather than a slave cylinder problem; which I tried and it glided through fine when car was off. However I didn't need to push in the clutch to row the gears while it wasn't running; is this normal?
Thing is I went STG III a few months back and have a new STG II Kevlar clutch (& lwfw), and new slave cylinder (Have about 3500 miles on them so far). I did recently install Apikol Rear diff carrier bushings and I have stiffer motor mounts and trans mounts. Perhaps stiffening everything caused something get out of alignment?
Finally, someone suggested that perhaps the flywheel is fused to the clutch, and to fix it one could start the car while in 1st gear to separate the two. Is this bad advice?
