Results 1 to 26 of 26
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    DIY: CityLight with Fog Mod
    I know this is a repost but I wanted to put my spin on it...
    First of all, HUGE props to "FatAuto" for figuring this out. For reference >>> FatAuto's AW Link
    Here's how I did it and I've just include lotso pics for people who like pics
    1. Identify wires (Position #1 & #2) on the light switch harness
    2. Cut Wire #2. Allow for ample wire for step #3 & #4 below.
    3. Strip Wire #2.
    4. Crimp on Male Wire Tab Connector to #2 Wire.
    5. Use these style wire tap for a fool-proof tap. The best wire taps money can buy, IMHO.
    6. Crimp on Wire Tap onto Wire #1. Crimp far enough downstream to allow for the ease of Step #7 below.
    FYI, I barely left enough room for mine, but for you guys, go further downstream (See Step #7).
    7. Connect up Male Wire Tab to Wire Tap & Tape raw end of Wire #2.
    8. Done, in 5 minutes time. Fogs w/CityLights Mod...
    Whooot !!!!
    Original Thread w/ Discussion: http://www.audizine.com/forum/showthread.php?t=124446
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Registered Member One Ring turboaudia4's Avatar
    Apr 18 2008
    vw cc vr6 and 98 vr6 Jetta
    l.i.
    Re: B6/B7 A4/S4: CityLight with Fog Mod
    is this feature with the parking lights or as day time runing lights?
    Apr 18 2008
    l.i.
    i wasnt sure wat citylights were but i searched around and found out i dont have them so how do i make this work for my car. (03 a4)
    Sep 18 2008
    Houston
    Question Re: B6/B7 A4/S4: CityLight with Fog Mod
    DOES anybody know if this will still allow the fog lights to power on when you Unlock/Lock the car with the remote???
    Sep 18 2008
    Houston
    Will this allow the fog lights to still power on when you Unlock/Lock the car with the remote????
    Thanks
    Registered Member Two Rings
    Jul 26 2008
    South Africa
    Hi,
    Can you please explain what exactly it is that this mod does ?? Does it allow you to switch on your fogs, even if your park lights are not switched on ?? Or does this mod permanently switch on your fogs as daylight driving lights ??
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Can you do this with out the VAG tool ?
    Bit of a Newb to the audi world.
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    Do you need the VAG tool for this?
    Veteran Member Four Rings scottykenneth's Avatar
    Dec 01 2006
    S .NJ
    awesome!
    Instagram:ScottyKenneth
    ScottyKenneth's Build Thread
    PRESENT : White 2018 Porsche 911 GT3 ( manual) / 2018 Jeep Grand Cherokee Altitude
    PAST : 2018 White Carrera 911 GTS / 2018 GT Silver Carrera 911 GTS / 2016 Porsche Cayman GT4 / 2015 []RS5 / 2014 S5 / 2010 A5 SLINE / 2007 A4 SLINE / 2001 A4 /
    Veteran Member Three Rings WayzataAudi's Avatar
    Feb 18 2009
    911SC Targa
    Colorado
    that looks sick..but if i do that will i still have fogs for low beam use? and what do you do with the other end of the wire you cut?
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    i just found this thread and i'm doing it TODAY haha
    thanks!
    Senior Member Two Rings DFDUB.S-Line's Avatar
    Mar 20 2009
    Texas
    Great DIY, just completed it, took 5 mins max. Love the site people keep the DIY post coming.
    Bryan
    Apr 07 2009
    The 203
    Very exact tutorial. Great pictures. Thanks!
    Established Member Two Rings xRyan2.0T's Avatar
    Feb 10 2009
    B7 2.0T FWD, BMW 325i E86,
    would this be the same for halogen set up?? to run fog lights with parking lights??
    Senior Member Three Rings SwassMike's Avatar
    Apr 26 2009
    06 Giant OCR C3
    Fort Lauderdale, FL
    I did this on my B7 (2005.5) and it works, however when my lights are set to "auto", the green light behind the "auto" text flickers. Is this a simple loose or poorly connected wire problem or something else?
    Veteran Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    Wonderful! This weekend it will be mine!
    Registered Member One Ring bradwellman's Avatar
    Jan 25 2010
    Minneapolis, MN
    Did you have to VAG your car to RDW before splitting/jumping the wire, like FatAuto did?
    Veteran Member Four Rings jsantiago17's Avatar
    Aug 07 2008
    2004 A4 Quattro3.0L UltraSport
    Westchester, NY
    I know I'm reviving a thread that's over 3 years old , but I'm not the most electrically inclined person. I read the below from Eddie Man, but it doesn't mention anything about having to VAGCOM, in order to getting the fogs to work separately....the post from Fat Auto does. Do you guys know if I can get the fogs to work separately, WITHOUT Vagcom'ing it?
    Thanks for your help in advance!
    |Milltek Exhaust|Unitronic Flashed|JHM Short Shifter|Koni Sports|Eibach Pros|RS4 Rear Sway|Euro RS4 Steering Wheel|RS4 Race Pedals|Miro 111's|S4 Mirrors|
    |B6 S4 Calipers|JHM 2 Piece Lightweight Rotors|Akebono Euro Ceramic Brake Pads|Evoms CAI|Hoen Xenon Match Foglights
    http://www.youtube.com/watch?v=xccmzudcY8o
    http://www.youtube.com/watch?v=BZOJIV1y0EQ
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Looks like its a mod for US cars only, I assume ROW has this as a standard feature?
    B7 A4 GT28
    Senior Member Two Rings Krmass25's Avatar
    Aug 18 2013
    AMERICA
    From what i gather, this leaves the fog lights on all the time and removes the function of the fog switch on the dash. .
    If I am incorrect please let me know. Also. What did you do with the #2 wire that was cut going down into the harness? Is this just left cut off?
    If I were to do this mod I would jump the connection the same way as shown here without cutting any wires or cutting them to put a bosch relay in between. When the relay is activated the relay could close the connection to return the lights to normal function. When open it can be wired to supply the voltage to the fogs and have a switch to turn them on and off. This way you could turn the fogs off if you would like and the switch would retain its functionality.
    To shut them off one would need to flip the switch which would close the relay connection and the lights would return to the stock function. This would be a lot more practical. You would be able to have the fogs used as DRLs and shut them on and off as pleased without losing the DRL's in the headlight switch. The switch when turned to headlight and pulled for the fogs would retain their normal function when the foglight switch is in the off position.
    Any thoughts? We could write up the diagram pretty easy, I would just need to sort out which kind of relay and label the inputs/outputs. Would need to sit down and look it over but this should be a super simple mod and a lot better than being stuck with fogs on all the time and no functional fog switch in the dash. .
    ***Side note:
    As a mobile electronics certified professional I have to advise against the use of a wire tap. These are terrible and cause electrical havoc and meltdown half the time. It is cheap to get a pen sized solder iron, use a sharp pic tool to poke a hole straight through the wire that you want to splice in to, no cutting needed and no pinching of the wire from the clamp on splicer. Feed a bare pigtail of wire through the hole you created in the main wire and warm it up, let the solder suck into the joint. Zip tie the pigtail to the main wire sideways with tiny zip tie. (now it isn't going anywhere) and wrap with a little electric tape for protection and finish.
    _______ Pigtail/wire you are splicing in
    --------------------------------- Main wire
    Use sharp pick tool to poke a hole through the main wire large enough to feed the bare end of the other wire you are connecting through it.
    Squeeze the little hole around the spliced in end you feed in, solder, zip tie down with tiny zip tie and cover with real electric tape.
    You now have a solid spliced three way without removing the rubber from the wire or compromising the integrity of the strands within.
    Senior Member Two Rings bryonm's Avatar
    Jun 02 2013
    Mililani, Hawaii
    There is a much better way to do this without cutting wires, I wouldn't do it this way at all
    Established Member Two Rings JPS's Avatar
    Jun 15 2013
    United States
    Quote Originally Posted by bryonm View Post
    and how is that done?
    Established Member Two Rings m3fuz's Avatar
    Oct 14 2012
    Hamilton, MA
    Yes - please share.
    Just a Roundel guy exploring the 4 Ring world...
    2007 A4 Avant, 1987 325e
    2 E36 M3s, an E34 M5, and an E28 535is - all gone
    Established Member Two Rings kr3w45's Avatar
    Mar 19 2014
    02 a4, 06 a4, 09 a4, yamaha r6
    Boston, MA
    FYI on not cutting any wires:
    I tried piggy backing a wire without cutting- it allowed the fog lights to work with the city lights.. but for some reason my left low beam was not coming on. Voltage / resistance was fine. I traced it from the headlight harness to the switch. Everything checked out okay.
    I ended up trying to source the problem and just cut the Yellow/Black wire and the low beam came back on and fog lights now work with the city lights!
    In my case there wasn't an easy way to do this mod without cutting. Hope this helps.
    Automate your Dealership: www.DealerScience.com
    Automotive Technician @ Amherst Autoworks
    B7 A4 - Frankenturbo F23L
    B8 S4 Stage 2
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by JPS View Post
    Quote Originally Posted by m3fuz View Post
    Yes - please share.
    He is probably talking about this method:
    http://www.audizine.com/forum/showth...hlight=fatauto
    Just uses some electrical tape and a bit of wire, only takes a few minutes. If your headlights start acting crazy though, it likely means the tape has slipped off the pin.
    White Wagon
    Established Member Two Rings 2stroke's Avatar
    Jun 01 2009
    SWEDEN
    Question
    Quote Originally Posted by Krmass25 View Post
    From what I gather, this leaves the fog lights on all the time and removes the function of the fog switch on the dash...
    ...If I were to do this mod I would jump the connection the same way as shown here without cutting any wires or cutting them to put a bosch relay in between.
    Any thoughts?
    Krmass
    Please help me out on this one !
    // Regards from Sweden.
