Remove the two allen bolts underneath the covers on the front of the seats (You'll want the seat in the furthest back position, and fully elevated). Once this is done, simply tilt the seat back slightly, and slide it towards the rear of the car (look at the seat rails from the backseat and it should be somewhat obvious how it'll come out, you'll need to unbolt the caps on the backside of each rail to fully expose the back of the track where the seat will exit). Make sure to unplug the 3 (I believe) harnesses from the front side of the seat and you're done. I'll try and find the AW writeup which is a bit more detailed than my description, but it'll get you started.
