Results 1 to 14 of 14
Thread: 0-60 of a B6 S4
    Veteran Member Four Rings rlebwohl's Avatar
    Mar 21 2004
    2013 Audi RS5, 2023 VW Atlas Cross Sport
    Bucks County, PA
    0-60 of a B6 S4
    Just wondering what the 0-60 time is of a current stock S4 6.sp...
    thanks, rob
    ROB
    2013 RS5
    Veteran Member Three Rings S4arch's Avatar
    Oct 08 2004
    2004 S4, VW Eurovan
    Orange County
    I think Audi claims 5.6 sec. with the 6 speed, I don't know about the tip...
    '04 Nogaro S4 MT
    intake, REVO, LaBree full-back exhaust
    19" 843R HRE's w/. PS-2's
    C/O's comming next...
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Motor Trend was able to get 4.99 with a manual.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Veteran Member Four Rings TheBlueMartin's Avatar
    Jan 06 2005
    2006 A6 3.2, 2009 Q7 4.2 Prestige, 2014 Regal GS M/T
    Ann Arbor, MI
    I dont think the OEM clutch could have been very comfortable with that run. They had to have flogged that thing hard to get a number like that. Mabey they got that number at Ferrari's down-sloped test strip?
    "Mastering others is strength, mastering yourself makes you fearless" Lao Tzu
    2006 A6 3.2 Avant- Black.
    2009 Q7 4.2 Prestige - Lava.
    Senior Member Three Rings ESfour's Avatar
    Dec 19 2004
    2005 A4/S4 brochure says...
    S4 man. 5.2
    S4 tip. 5.6
    2013 Audi A7 Premium Plus
    Mar 21 2004
    Bucks County, PA
    alright, thanks guys
    ROB
    2013 RS5
    Established Member Two Rings B6 S4 is BRZRKR's Avatar
    Nov 08 2004
    1972 Datsun 240Z w/ SR20DET swap, 2005 Audi A6 4.2 Sport Sedan, 2003 Passat Wagon V6 4Motion
    Knoxville, TN
    Car and Driver got 5.2 and AutoWeek got 5.0.
    Best launch I know is NOT the most abusive. Let clutch out smooth for 1/2 of travel while at 4k or so and once it starts to make the clutch 'slip' sound, smoothly drop the clutch altogether. It doesn't hurt much, if at all, to launch that way. There's also no wheelspin this way. My opinions. Others?
    2004 S4 Avant 6 speed
    2003 Passat V6 4Motion GLX Wagon
    1972 Datsun 240Z - Rules the roost.
    Registered Member Two Rings 808S4DRVR's Avatar
    Feb 24 2005
    Hawaii
    Hmmm, interesting. I find my best launch is to rev it to 2800 rpm and slip the clutch. Anything higher than that, the clutch has a bad smell.
    05 B6 S4
    Light Silver Metallic
    18" OZ Superleggera
    ECS Rotors/Carbotech Pads
    Euro Lower Grille
    Nov 08 2004
    Knoxville, TN
    Are you taking ESP off? I don't think that bad smell is as much the clutch as it is some computer gadget screwing things up. I know that smell very well. But it doesn't do it with the ESP off, unless I drop it brutally from a very high rpm (5500 or so... did it once to see. You can do that in an STi, you know.)
    Registered Member Two Rings Richard 350z's Avatar
    Motor Trend's test drivers don't give a rats azz what they do to the clutch. They got an EVO RS to do 0 - 60 mph in 4.4 seconds!!! The RS is quick, but not that quick if bone stock.
    Richard
    2004 Audi S4 (B6)
    2004 Mitsu EVO RS
    __________________________
    "There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games."
    Ernest Hemingway
    Feb 24 2005
    Hawaii
    Hmmm, I did take the ESP off. Still did not have a great 60ft time, until I did the approach as described above.
    05 B6 S4
    18" OZ Superleggera
    Euro Lower Grille
    Registered Member Four Rings |Sandman|'s Avatar
    Jan 02 2005
    A6 3.0 TDI QTip
    Lisboa, Portugal
    well, I´m interested in all this launch conversations... ... how do you make the S4 BURN tire ?? what is the best approach ?
    Thanks
    2005 Audi A6 3.0 TDI Quattro | 2002 Supercharged 330ci
    AKA Silveraudi
    Nov 08 2004
    Knoxville, TN
    If it's wet, it's REALLY easy. Otherwise, I don't suggest doing it often. But I've turned off the ESP and dropped it at 5k or so and kept it with the throttle all the way down for about 5 secs. It'll burn 'em up FAST.
    Jan 02 2005
    A6 3.0 TDI QTip
    Lisboa, Portugal
    yeah, I won´t do it all the time, but as soon as I get mine from Germany in December, you bet I´m going to try it at the first stop light I see ... thanks for the info, I´ll try it as you said..
    Diogo
    AKA Silveraudi
