Results 1 to 40 of 44
    Veteran Member Three Rings darkstar's Avatar
    Dec 24 2004
    1998 silverado, 1986 c10
    Folsom, CA
    B6 Passat rack to fit on B6/B7 A4/S4
    Hey guys doing my own DIY for the B6 passat VW rack to Fit on our cars
    I got my rack from genuinevwaudiparts.com Rack *here* P/N 3C0071126
    Tools needed
    - rack tool (comes with rack has allen and special socket for the rack bolts)
    - square
    - punch
    - hammer
    - scoring tool ( i used tungsten from my tig)
    - some sort of saw (hack saw should work fine)
    - flat heat screw driver
    - drill or drill press
    -measuring instrument (calipers, tape measure, ruler whatever you have!)
    optional
    - extra set of allen's
    I used the measurements that dackler posted PDF file here Thanks for those makes things a lot easier! they were dead on!
    Ok so first thing is first i always worked from the right side of the racks that way i could retain the factor stickers on the bottoms telling you which front and rear.
    1: Start by first taking off the side mounts that clamp inside of the doors using the tool supplied with the rack.
    2: Then remove the small plastic plugs that are hiding 2 (5MM) allen bolts remove both bolts.
    3: Then you are able to remove the inner supporting foot and cover, then side out the steel sliding block. the side of the rack should be fully disassembled.
    4: after the rack is all disassembled on the right side then its time to start making some holes! i used dackler measurements they are listed above.
    now for the front rack the holes need to be moved forward 55.0mm rear rack needs to be moved inwards 88.0mm these steps can be used for both just makes sure you use the correct measurements on the correct rack.
    Now what i did was i used my square and lined it up with the factory slotted hole and covered up the radius part (just so that the slotted hole no longer had and radius showing) with the square then scored it. then repeated the same from the next hole.
    5: Next i used my calipers and set them to my measurements i need (front 55.0mm)(rear 88.0mm) then i used my square and measured from my original line that i scored moved inward on the rack till i moved the correct distance then scored the rack then repeated the same step for the next hole.
    6: now at this point you should almost be ready to drill some holes but before i did i went and test fit the rack on my car i liked up the rack with the holes in the door and seat the right side support foot under lining it up with the gutters where it sits on the car then used a marker to mark the front hole to make sure i am where i need to be with my measurements
    7: After you make sure you measurements are on target you need to find the center of the rack so you can use a punch to get you a nice punch to get you drill bit started the rack is 2.25" wide so the center would be 1/2 of that which is 1.125" using you square measure it out and score it on each spot where the new holes will be.
    Dec 24 2004
    Folsom, CA
    8: Now using your punch line up your makes you made and punch a started spot for the drill.
    9: Now its time to drill some holes! i started off with a small pilot bit like 1/16 then step up to a 1/4" bit
    10: now after i drilled them out i went ahead and went and test fitting again to make sure the holes were correct and i didn't have to slot them at all to get a good fitment. so slide the sliding block back in and using the 2 (5mm) allen bolts fit the support foot back on to the rack and make sure that you fit is good between the gutters.
    *note*you may need to use a screw driver to get the sliding black in place
    **note if you do not have good fitment you may have to slot the holes with a dremel or die grinder to get the fit you need you can always try adjusting from the unmodified side.
    WE ARE GETTING CLOSE!
    11: Now take the support leg off and remove sliding block, then using the measuring device i used my caliper, measure from the end to the amount you moved the holes on the rack (front 55.0mm) (rear 88.00mm)
    12: Now we are ready to cut! i used a bandsaw you can use whatever you life or have access to. i clamped my piece very carefully and confirmed my amount i wanted to remove, then cut!
    13: after i cut my piece i went ahead and used a metal file and cleaned up my cut.
    14: Now it is time to start putting things back together! start with sliding in the slide block, then put on the support foot cover, then put on the support foot and secure with 2 (5mm) allen bolts.**note** it was easier to put the deep of the 2 bolts on the racks side, then install 2 small plugs to cover bolt holes, after that then put on outer tensioning clamp.
    **note make sure to leave the tensioning clamps pretty loose to help fitting the rack.
    15: installation! at last! ok so now open all 4 doors find the alignment marks inside the door jamb. Lining the correct front and rear backs on the car making sure you have the left on the driver side of the car. tighten down rack according to manufactures instructions.
    Dec 24 2004
    Folsom, CA
    16: stalling rubber strips with the rack installed and molded caps closed push down the rubber strips in the channel then cut when you get to the other side.
    Now enjoy your 56 dollar rack!!!!!!
    the end!
    Veteran Member Three Rings NetLogic's Avatar
    Jan 05 2009
    02 A4 1.8TQM Avant
    New Orleans
    Thanks for the post and taking the time to do the DIY. A+
    Luke
    Dec 24 2004
    Folsom, CA
    Thanks! i hope it helps those people out that want to do it.. pretty much step by step!
    Veteran Member Three Rings gray6spd's Avatar
    Jan 18 2009
    is nonexistent
    texas
    Sweet DIY! My bars are at my cousin's machine shop getting new slots in the morning!
    PREVIOUS:
    2004 1.8T Dolphin Grey- Quattro - 6MT - Sport Package - K&N - 35% - Stage: still in college and broke -
    2015 S4 3.0T Sepang Blue Pearl - DSG - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber - Totalled by a damn F150
    CURRENT:
    2015 S4 3.0T Daytona Grey Pearl - Quattro - DSG - Black Optic - B&O - Sport Diff - Carbon Fiber
    2012 Infiniti G37 Sport 3.7L Obsidian Black - Eibach Springs - K&N -
    Proud of my pink coolant.
    Dec 24 2004
    Folsom, CA
    Good times dude! its such a good deal you cant pass it up! pretty much 300 bucks off.. i like how this rack is a little lower profile too!
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    Good stuff...now put a fairing on it!
    Veteran Member Two Rings dackler's Avatar
    Jan 31 2005
    Cortland NY
    Awesome writeup! I'm glad the measurements worked out for ya!
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Awesome writeup!!!! This couldn't have come at a better time. I just got my Passat rack in the mail yesterday from ECS and was planning on doing this mod this weekend. Great job!
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Dec 19 2007
    York, PA
    part number?
    Jan 05 2009
    02 A4 1.8TQM Avant
    New Orleans
    Quote Originally Posted by n7plus1 View Post
    part number?
    3C0071126
    Luke
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Good stuff, until I saw the price I was thinnk why all that work for something that looks just like the Audi one's, nice write up.
    Oct 02 2006
    Wadsworth,OH
    Fantastic DIY, great photos and your car - well you car is also fantastic looking!
    Sep 27 2007
    Boston, MA
    darkstar, would you be willing to do this mod for a fee?
    Dec 19 2007
    York, PA
    i want to do this but need a part number to search.
    Jan 31 2005
    Cortland NY
    Check post #12 above
    Dec 19 2007
    York, PA
    mustve missed that thank you.
    Veteran Member Three Rings J3RR3L's Avatar
    Dec 10 2006
    2003B6A4
    i like the way it clamps to the roof. looks like a better than my yakima mounts
    Maestro GTX3071
    Dec 24 2004
    Folsom, CA
    Thanks guys i think it took longer to do the write up then to mod the rack! i hope it comes in handy for those who are wanting to do this... i have used so many DIY from AZ and A4 mods to pretty much do anything on my car! just wanted to pass on the love!
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    I ordered one from GAP and they said its going to be 2 weeks until they have it in stock just so everyone knows.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Dec 24 2004
    Folsom, CA
    good looking out! i took about a week to receive mine! the rack actually had been damaged during shipping Bill over there took care of me and shipped out the replacement part ASAP!
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    nicely done....and very nice car!
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    god i wish i had all those tools and stuff. would have made it a lot easier to do mine. probably took me 3 hours the first time because i had a hack saw blade (no handle) and a cordless drill and a sharpie.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Dec 19 2007
    York, PA
    Quote Originally Posted by JustinCase View Post
    coo, thanks justin.
    Dec 19 2007
    York, PA
    any reason you didnt do slots instead of just holes?
    Sep 02 2008
    Boonies VA
    Great job, I was all excited about this, then realized it would not work on my Avant! nonetheless a great DIY and way to save a large amount of money.
    White Wagon
    May 12 2008
    ECS has them in stock. I got mine in less than a week for $90 shipped.
    http://www.ecstuning.com/Volkswagen-...Rack/ES342630/
    - Mags
    Veteran Member Three Rings Homer's Avatar
    Jan 27 2010
    2006 A4 6MT Quattro, 1990 Volvo 240 Turbo
    Bay Area
    Cross post from B7 forum on my part, but who makes the factory rack system? Just bought the rack from GAP, but I'm looking to see if attachments can be bought elsewhere.
    -Jacob
    1990 Volvo 240 Turbo-Project Car
    2017 Audi allroad prestige
    May 12 2008
    The cross bars are similiar to the Thule Aero bars so anything with those mounts will work. ECS actually have some cool bike carriers that come in different colors.
    - Mags
    Mar 27 2008
    Denver
    Wow... this may have to happen when I make my rack for the Avant... Will it attach to the Avant you think? I might have to get creative.
    Dec 24 2004
    Folsom, CA
    Quote Originally Posted by alpinestar180 View Post
    Lol well as long as you got it done that all that matters!
    The measurements were spot on i didnt see a need to slot the holes.. if the fit wasn't very good i would have.
    That is a good question. i would think maybe the rack system would attach to the factory rails instead of in the doors. if you have the mounts inside the doors why not try it!
    Dec 19 2007
    York, PA
    Quote Originally Posted by bmags88 View Post
    yeah, the rocky mounts...my roomie got one for his b5.5 passat...pretty good quality.
    Oct 02 2006
    Wadsworth,OH
    We do indeed. They are colorfully powder coated so you can make your rack as stand out as you'd like - or as subtle as you like. Really, for the price, quality and function - our Rockymounts can't be beat. They were designed for VW Audi and BMW base bars specifically so fitment is superb. For anyone interested they are found here.
    Jan 27 2010
    Bay Area
    Quote Originally Posted by Chris@ECSTuning View Post
    I see a few pictures on your site that seem to use the "Euro PitchFork Standard Plate/Custom Rear Mount Kit".
    Is that included or extra?
    -Jacob
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Homer View Post
    I realize it isn't photo'd directly but yes, they are included by default with all our Rockymount kits.
    Established Member Two Rings mda0428's Avatar
    Aug 09 2009
    Providence, RI
    any idea why the rack is now $250 on genuine?
    2007 A4 2.0T 6A S-Line 15% Tint, APR Stage 2+, GSG CAI, GSG FMIC, Stasis Exhaust, VMR Test Pipe, APR HPFP, ST V1 Coilovers, VMR V710 19x8.5 Front, 19x9.5 Rear, Pioneer Avic z2 Nav, JL 12w6v2, JL 500.1
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mda0428 View Post
    Hard to say - but I suspect it is because this item is no longer being manufactured and quantities are now limited to what are available. ECS now offers two options:
    One: B6 Passat rack that will be ready to be modified to fit the B6/7 for $74.96.
    Two: ECS-assembled B6/B7 roof rack that is ready to mount on your car for $149.95.
    ...and we have a BUNCH of these on hand!
    Sep 27 2007
    Boston, MA
    Just placed my order through ECS. w00t!
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mister_tu View Post
    Thanks!!
