Thinking about replacing the engine mounts on my 2.0T CVT - passenger side is leaking. Is it easy as it sounds, similar to this one (without the sway bar removal) ?
http://www.audizine.com/forum/showth...tor-Mounts-DIY
Or is it a bit more complicated for the B7/CVT? I've changed out timing belt if that helps with reference to skills...
Also is 034 comparable to OEM? I want a smooth idle/ride.
Thanks
