I've got all my parts here & am getting ready to wire stuff together. I have the Connects2 adapter & am looking for a couple of answers before I start cutting/splicing wires. Instructions were included if you consider four lousy pictures that don't match up to anything you have instructions so I'm trying to find more details in searches and am not returning the results I'm looking for. I'll number them for ease of response.
1) I don't have a Metra 70-178 (would have ordered it had I known) so I assume I just need to cut the smaller harness off and hard wire all of these wires to the Pioneer wires to plug into the harness, correct?
2) Do I then connect the front RCAs to the front RCA outs on the deck and the rear RCAs to the rear RCA outs on the deck? I assume these will feed the Bose amp the proper signals but I thought I read somewhere I need to connect only the rears and I also read something about a line driver so I want to make sure all I need to do is plug these four RCAs together to get my audio.
3) If I'm getting all the audio via RCAs does this mean I don't need to connect all the speaker wires together? That would save me 8 connections and a few minutes in connecting. I would think that all I shouldn't need to connect all the speaker wires (purple, gray, white & green) from the Pioneer to the wiring harness but maybe I do?
4) Remote turn-on antenna wires... do I just connect all of them together? I have a blue off of the Pioneer, one for the antenna (connects2 CT27AA56... I was told by Enfig that this one works best) and one for the wiring harness (Bose amp?) so I assume I just need to connect all three of these wires together, correct? The Pioneer then sends a signal to the antenna adapter and Bose amps to turn on, correct?
5) Parking brake: I can simply splice this into the ground a few wires over in the harness, correct? This is all I need to allow me to use it while in motion? I think I read something about moving the yellow 'Mute' wire one PIN over in the white Pioneer harness and then grounding both that AND the parking brake wire to the black wire. Not sure why that is but I wanted to confirm that this is indeed how you bypass a Pioneer unit.
6) Mic, I'm going to assume I still need to run the Pioneer mic for bluetooth, right? Just making sure in all it's magic the Connects2 doesn't somehow utilize the factory mic.
7) Do I need to do anything with VAG-COM to make this work properly? Do I need to disable the factory BT module or something like that so it's not trying to pair with my mobile phone instead of the Pioneer? I assume I can just delete the factory BT out of mt phone and all issues will be avoided between these two devices. I also read something about making a change so that the steering wheel control for mode change works properly on the Pioneer deck but am unsure if this applies to me or not.
8) I bought the Connects2 'touch of rubber' dash kit as well as the Pioneer installation kit. I assume I just use the can from the Pioneer kit to attach to the Pioneer and then snap the center bar out of the Connects2 dash kit, right? Do I need to use that trim ring in the Pioneer kit along with the Connects2 dash kit?
I think that's about all I have now and on a couple of the questions I have a good idea but would just like confirmation and on some others I'm really not sure and don't want to screw anything up. If you have for sure answers for just a couple of these feel free to answer what you know for sure. No need to know every single one to reply. Thanks!
