Results 1 to 10 of 10
    Senior Member Three Rings 02rubya4's Avatar
    Nov 13 2009
    1998 Plymouth Neon (may that P.O.S. R.I.P)
    Putnam County, NY/ Prov. RI
    high mileage oil
    Anyone here use it? I picked up 5 quarts of Mobil 1 5w 30 high mileage. My car has 106k and was wondering if there are any one uses it or if there are drawbacks.
    Tia fellas
    Mar 27 2005
    The Cold North
    You'll be fine along with everyone else that buys into the Mobil 1 marketing.
    next time if you want a better quality synthetic at the chain parts store pick up the GC 0w-30 & mahle filter.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Nov 13 2009
    Gc? Never heard of that. Plus I've been using regular Mobil 1 for some time now my only issue was that if additives in the high mileage will f anything up also brings up another point is it an issue to switch from 5w to 0w or is it ok to just do
    Apr 19 2010
    NE PA
    Why does everyone knock mobil1? You dont become the leading, probably most widely available, and reasonably priced FULL synthetic oil (as in, base stock and all) by selling garbage. I can attest that in my last car, an '06 mazda3 2.0. I ran that oil since I got the car (brand new). After 5 years and 100k miles of beating the shit out that engine, constant high revs, running it to the rev limiter daily...etc, all trying to get to class/work on time, that engine was SPOTLESS. I religiously changed the oil (5w20)/ mobil1 filter every 5k. Even during the summer months I would lose at most 4 oz between OC intervals. Something else that helps, I always let the car run atleast a minute or until the revs came down to low idle on a cold start b4 driving when its warm out, or in the winter, atleast 15 minutes, for the cars sake and my own. ( -14*F here last winter) So for me, say what you will, knock it all you want, mobil1 it is. It proved me once. ::now thats thinkin with your dipstick::
    o4 1.8tq 6mt | forge DV | vogtland | TT injectors | APR 1+ | 20% tint | k&n drop in | rs4 rear sway | CIM boost gauge | ECS snub
    -dan
    'I limit myself to one drink a day. Right now I'm 3 months ahead.'
    Jan 16 2007
    Wetzlar
    GC is no longer green :-). I still have bunch of it for my other car. Right now I use Total 0w-30 and Mahle filter and change it every 8-9k. Blackstone reports are perfect.
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    These debates over engine oil never end...
    Nov 13 2009
    Quote Originally Posted by BASARAB View Post
    if you read my OP i'm not looking to start an oil debate thread because i know there is thousands of them on AZ. Im just curious about if the additves are bad in the long run for our engines (1.8t)
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    Anything that goes inside an engine is hard to review scientifically without some serious and very expensive testing. I mean long term tests with oil analysis done over intervals, plus a full tear down of the engine to measure wear and deposits. and that won't still be definitive, as you need to have several cars driven and maintained identically, each with a different oil used.
    One thing is for sure, do not use regular oil in 1.8T engines, as the sludge problems that caused are well documented.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by scarecrowe View Post
    It actually isn't a 'true' synthetic. You need to check you information and stop buying into the XOM marketting.
    2020 Chevy AEV ZR2
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    This has been beat to death on bobistheoilguy.com which is a great source for related information.
    After I read a bunch of data sheets I picked Total Energy9000 5w40 due to specs, cost and availability. Been happy with the results, run 7500km OCI and never had an issue with cold starts. And by cold I mean -40* cold without being plugged in.
    Quote Originally Posted by EBG 18T View Post
    He's right.
    clicky: click
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
