Results 1 to 9 of 9
    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    Service warning reset
    I tried to search but found nothing......i want to reset the service interval warning myself. I did it before but i forgot how to. Can anyone tell me how
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Sep 11 2009
    NE
    Here it is as clear as I can make it:
    0. Display reads "Service!" when you first start the car.
    1. With the ignition key in the off position, push and hold the right button under the speedometer. This is the button you use to reset the trip odometer also.
    2. Turn the ignition key to the on position, but don't start the engine. Keep holding down the right button while you turn the key.
    3. Push the left button under the tachometer. Your service light should reset to say something like "Service in 8100 miles."
    OR
    Audi A4 & A6 (All years)
    • Turn off the ignition
    • Press and hold the button on the left side of the display while turning the ignition on
    • Service OIL will be displayed
    • Pull out the button on the right side of the display until the service prompt is cleared
    • The display should now read **-
    If the above procedure does not work, outlined below is an alternative procedure:
    • With the ignition off, push the right button
    • Turn the ignition on and then pull the left button
    • This should clear the warning message
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    The alternate procedure which works for the C5 A6 4.2L is:
    1. Turn off the ignition
    2. Press and hold the trip odometer reset button on the right side of the display while starting the vehicle, continue to hold in the reset button.
    3. The central display will now read "Service in X,XXX units", units will of course be in either kilometers or miles depending on whether you car is set for metric or standard.
    4. Press the press control button underneath the tachometer to reset indicator.
    5. The central display will now read "Service in 12,000km/8,000miles".
    The 4.2L engine has a sensor in the oil pan which automatically monitors the oil quality and is used to calculate the actual time needed to service so if you reset the service indicator in between oil changes, the oil service indicator will adjust the kms/miles to service accordingly once you've driven the car long enough for the sensor to get a reading.
    Active Member One Ring joesta19's Avatar
    Sep 27 2010
    2006 Audi A6 4.2 Quattro S-Line
    Chicago Illinois
    reset service
    i had reseted the service indicator for the next oil change, but my car is set to 10,000 miles. does anyone know how can i set it lower?
    Veteran Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    just rest mine last week. Turn key on, do not crank over engine. when service is displayed hold BOTH dash "pins" the odometer and the clock...
    BOOM reset occurs.
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    Quote Originally Posted by joesta19 View Post
    give this a shot clicky thingy i havent tried it on a c5, but i know for a fact this can be done on a b6 :)
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Active Member Two Rings ALFRED's Avatar
    Jul 01 2004
    Las Vegas, Nevada
    How do you reset on a 2007 A6 3.2L?
    Senior Member Three Rings MLFHNTR's Avatar
    May 29 2010
    '04 Allroad, '02 GTI
    Daytona Beach
    Good to know. Now I do not have to just ignore the light up there when I turn the car on.
    2 Hooker Limit...
    Embry-Riddle European Car Club President
    Established Member Two Rings Tourbo24's Avatar
    Oct 01 2010
    Peoria, AZ
    i have a 1999 a6 2.8 and mine says service OIL and none of the methods above are working for me, unless i am doing something wrong... BTW one of the methods says to pull on the knob on the right side but it is impossible to pull on that one, because you can only press it in. any ideas? :D
