But the driver's front door/window frame has a few millimeter gap when the door is closed. I know that the PO has recently replaced the window regulators on both front doors, and I also know that he locked the keys in the car and he used a coat hanger to pop the door switch (there are multiple scratches on the door switch from this
Is it possible that: A) the door/window frame was slightly bent when he jimmy rigged the coat hangar into the gap between the door. Or: B) The PO didn't put the door back together properly when he replaced the window regulator. All doors close with little effort, this is another way that I know that this is not due to tweaked body panels due to any type of accident.
