Results 1 to 8 of 8
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    Cost to replace Automatic Transmission Pump?
    So, what is it going to cost me to have a shop replace the automatic transmission pump? I had the torque converter replaced while the motor and trans was out for my K04 build. When I was taken for a ride to test the boost guage, we drove approximately half a mile when the power stopped being delivered to the wheels. We are 99 percent sure the transmission fluid pump went out after talking to Sam at 517. My mechanic doesn't feel comfortable replacing the pump himself, so I need to find a shop that can do it in the northern VA (winchester) area and a rough idea of what it is going to cost me.
    Thanks.
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Jan 06 2010
    Any shop suggestions? I have called a few places, and most shops don't want to touch it. The ones that are willing to quote me, I really only want to use as a last resort.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Jun 24 2008
    Palm Coast, Fl
    were is that even located i have a problem close to yours i changed my tc and trans now cant get all the oil in i pump it in it over flows run thru the gears and nothing no power and the oil doesnt get sucked out of oil pan.... you have vag-com any codes..
    Jan 06 2010
    I am in northern Virginia. I haven't checked my codes, but I can pretty much guarantee what they will say...
    Thank you for running VAG-COM Diagnostics! You're Fucked!
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Send it to sam @ 517, The shipping rates he gave me were not to bad from CT to his shop fo rmy trans rebuild GL
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Jan 06 2010
    I was trying to avoid shipping the trans, but it is coming down to that. No shop wants to even touch the trans, let alone doing any work to it. I called the dealer as a last resort and they are only willing to replace the entire transmission.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    May 16 2008
    South Texas
    Quote Originally Posted by sjmelling View Post
    To replace the pump the trans has to come out. The pump is directly behind the torque converter.
    Jan 06 2010
    Quote Originally Posted by Scotty@Advanced View Post
    Yeah, there is nothing that can be replaced with the motor in the car. I am trying to avoid shipping the trans to a shop out of town, I know it has to come out of the car.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
