Results 1 to 31 of 31
    Account Terminated Two Rings
    Apr 11 2010
    Michigan
    1999 Audi A6 2.8 Quattro 2.8l misfire!!
    i have a misfire when i go in reverse and randomly when im under 1500 rpms is this some kind of normal issue changed plug it went away for 1 day than was back
    Apr 11 2010
    Michigan
    Also thanks for any help!
    Apr 11 2010
    Michigan
    anyone?
    Established Member Two Rings csh724's Avatar
    Sep 23 2009
    Douglassville,PA
    check the ignition coil n wires and the and the socket that plugs into the ignition coil
    99' A6 2.8Q Tip
    Apr 11 2010
    Michigan
    coil wires n plug all new
    Senior Member Three Rings hcaudikeed's Avatar
    May 25 2009
    2000 A6 2.7t 6sp
    Around
    maybe the coilpack is going bad?
    J-Fonz Tuned| F21's | CoolingMist Stage 2| Southbend Stage 3 Kevlar w/ RS4 PP| Fidanza LWFW | Bosch EV14 72# | DW300 Pump | SRM SMIC's | 034 Track Density Motor Mounts | 034 Street Density Trans & Rear Diff Mounts | 034 Bipipes | 034 85mm MAF Housing | 034 Snub Mount w/ Bracket | EFK | 710N's | Hartmann DTM 18x8.5 | 235/40/18 Cooper RS3-S's & 225/45/18 Dunlop Wintersport M3's | H&R Race Springs | Koni Yellow Sport Shocks | SSAC V-Band DP's | Milltek 2.5 inch Catback | S6 Doorblades |
    Apr 11 2010
    Michigan
    i have 3 coils 2 plugs off each
    Sep 23 2009
    Douglassville,PA
    the 2.8 doesnt have "coils packs" per say it has one ignition coil
    99' A6 2.8Q Tip
    Apr 11 2010
    Michigan
    yea and the hwole thing is brand new cost me 200 plus 200 for wires plugs 30 on plugs
    Apr 11 2010
    Michigan
    if i knew audi had this many issues with heads and plugs and if i knew wires would cost me 229 wires and stuff i woulda sticked with my American i can pull and put a new engine in a trans am in 5 hours
    Apr 11 2010
    Michigan
    o and i have a cylinder 2 misfire and a secondary air injection low whats this mean?
    Apr 11 2010
    Michigan
    ok so im still fighting this thing it happens worse when its hot more than cold i change plug n wire checked coils with timing gun changed coil same problem
    Apr 11 2010
    Michigan
    it is only cylinder 2 misifre and its not all the time if i punch it 2 of 5 times it will drive normal the other 3 it will go full rpm but slower because the cyl 2 is missn randomly
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    what codes if any are you getting with the vag com or OBDII..
    Other wise, how do you know which cylinder it is?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Apr 11 2010
    Michigan
    just cyl 2 misfire and o2 sensor 2 bank 2 no reading but i changed that 2 a while back still same problem
    Sep 23 2009
    Douglassville,PA
    did you check you vac lines?
    99' A6 2.8Q Tip
    Apr 11 2010
    Michigan
    yea all vac lines are brand new if i pull that little one way restrictor flow after the cars been of for an hour i hear it go slurrrrrrrrrp for air
    Apr 11 2010
    Michigan
    i just swapped the coil at the car store same thing so its def not the coil
    Apr 11 2010
    Michigan
    any other ideas like if its the motor would it be constant because 65% of the time i punch it and its as quick as it was new
    Apr 11 2010
    Michigan
    i changed the coil again and same thing ran fine for 2 days than back to misfire all vac lines are brand new any ideas this is killng me and all the $ i have
    Apr 11 2010
    Michigan
    also i have a light saying "brake light" on my message screen and if my alt is only making 13.0v could this cause this random misifre? coil is new moved plug wires to see if moving wire moved misfire detected still same cylinder new plugs coil injector etc car ran fine for 2 days with new coil only missed a couple times
    Apr 11 2010
    Michigan
    bump
    2000 s4
    Fairfield, CT
    injector for cylinder two?
    i heart my s4
    Active Member Two Rings blackeda6's Avatar
    Jun 02 2010
    whats a garage???
    Miami
    did the check the spark plug is installed right???? when i changed my plugs i got misfire 2 and 4 took them out and reinstalled them it went away
    Apr 11 2010
    Michigan
    thought so to but the problem did not follow the injector and its not mechanical because when i down shift the auto and punch it goes like new
    Dec 02 2010
    windsor/canada/ontario
    Did You fix it ? i have the same problem .
    Dec 02 2010
    Audi a6 2.8 quattro 1999 .my car start shaking when i try to go faster and i get the check engine light flashing at the same time .mostly when the engine is hot and had cyl 2 misfire 11 times in 4 5 seconds.
    HELP ! any ideas ?
    Thank you
    Dec 12 2010
    michigan
    same thing with me cyl 2 omggggggggggggggggg
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    that's pretty scary since im planing to buy same car, any updates?
    Veteran Member Two Rings
    Nov 15 2004
    Brunswick, ME
    still could be a mechanical issue with cylinder 2, possibly one of the valves not seating right. The computer doesnt track misfires over a certain rpm and running the car at higher rpm will help mask the misfire, smooths it out, more noticeable at idle. try leak down test
    Nov 11 2011
    2002 VW GTI VR6 1999 Audi A6 Avant
    Arlington, Wa
    Did you get this figured out?
