Originally Posted by
Zaloo
sorry to revive old thread - is it necessary to change fluid soon after the initial change? I ended up using about 7-8 quarts of fluid but have yet to go full throttle b/c Im paranoid to do just yet. On 3rd week or so since change and was curious if others changed out just the fluid to ensure all old fluid is out.
TIA
No you don't have to do anything more. The most common procedure is just a drain and refill (once), every 40-60k. That schedule is suitable for most normal driving. If you are dragging the car every weekend, that's a different story.
Tranny "flushes", or othewise "getting all the old fluid out" is somewhat controversial. There is a belief that older, worn clutches will start having problems if you take away there old used fluid and fill 100% with new fluid. It is less of a shock to the system if you just drain out what you can, and refill it. Also, there is a fear that a tranny flush machine will stir up all the collected crap inside the tranny and can clog passages, solenoids, etc. That is why many people prefer to simply drain and refill, if the tranny is working fine. There is less chance of creating any issues that way. No need to "stir the pot" as they say. Some mechanics even believe that after a certain point of neglect, the tranny fluid should *not* be serviced. If it has 300k miles, the fluid is black as tar, but it is still working (miraculously) it may be best to just leave it alone. That logic mostly applies to very extreme cases, though.
