Page 1 of 9 123 ... LastLast
Results 1 to 40 of 345
    Senior Member Two Rings lockeed's Avatar
    Feb 06 2010
    Quebec
    Question Shaking and sputtering idle on startup ??? WTF??
    My girlfriend drives the car to work each day so she end up driving 90% of the time. It happened 4 times in the past 2 weeks. Car has 8000km (5000miles). 2.0T - Manual trans.
    Very rough idle on cold startup. Last for 10 seconds, then stops. Unfortunatly, it hasen't happened while I was in the car...
    Anyone has experienced something similar?
    I love this car but so far, not impressed. 3 weeks after we purshased the car, we had a warning light telling us that the adjustable light where faulty. Diagnosed and they found out the entire passenger side light will need to be replaced. Looks like the electric motor inside the lens failled or something... Now this rought idle issue... car's not even 3 month old... Last week, at 7000km, we received a low oil warning. I had to put in 1L of oil to bring the level back where they belong.... never seen a car take so much oil... But since it's brand new, I'll let it pass the 10,000km mark untill I pass on any judgments on this...
    Anyway...
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by lockeed View Post
    Very rough idle on cold startup. Last for 10-15 seconds, then stops. Unfortunatly, it hasen't happened while I was in the car...
    I love this car but so far, no impressed. 3 weeks after we purshased the car, we had a warning light telling us that the adjustable light where faulty. Diagnosed and they found out the entire passenger side light will need to be replaced. Looks like the electric motor inside the lens failled or something... Now this rought idle issue... car's not even 3 month old... Last week, at 7000km, we received a low oil warning. I had to put in 1L of oil to bring the level back where they belong.... never seen a car take so much oil... But since it's brand new, I'll let it pass the 10,000km mark untill I pass on any judgments on this...
    Anyway...
    I had a terribly rough idle (but it did not go away after 10-15 seconds) that turned out to be a busted intake manifold. The dealer replaced it and all was well again. I know the car can idle a little rough on cold starts, which is normal, but I wouldn't describe it as shaking and sputtering.
    Senior Member Three Rings R3V3NANT's Avatar
    Apr 17 2010
    B6 A4 1.8TQ, B5.5 Passat 4M Variant,
    Dayton, OH
    No oil leaks that you can see or any burnt oil coming out the exhaust?
    Feb 04 2010
    Ottawa, Canada
    has happened to me twice (5000km) so far.. maybe 2 months apart..would be cold start. I just turn the engine off, wait a few seconds, and start it back up and runs fine... Will get the dealer look at it at 8k service.
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    happened to me two days in a row. lasts about 5 seconds where it can't make it to 1200rpm, tries, tries, struggles, eventually gets there.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    same thing happen over here, but only twice. i dont rmb it being a cold day either
    Feb 04 2010
    Ottawa, Canada
    Quote Originally Posted by dracolnyte View Post
    cold start..as in sitting for 8+hours etc.. since I know its been 30-40C outside when it has happened to me..
    Feb 06 2010
    Quebec
    Of course when I say cold start, I just mean that the engine is cold. Outside temp. is 20-25 degre c. (70-75 f )
    I wish it would've happened when I was in the car...
    Feb 06 2010
    Quebec
    Quote Originally Posted by R3V3NANT View Post
    No oil on the garage floor, never noticed anything out of the exhaust... I very rarely drive with my head out the widow
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Happens to me every now and again as well. Lasts a few seconds and then all is well. Just assumed it was no biggie. No other warning signs here regarding burning oil or anything like that....
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Feb 04 2010
    Ottawa, Canada
    anyone ask a dealer about it yet?
    Senior Member Two Rings dubaudifan's Avatar
    Dec 30 2006
    10' 01' A4 01'GTI 12' S4
    stuck in a pothole called NJ
    Apparently a bunch of us are having this issue. The car is actually misfiring, the EPC and Check engine light will go on, and the car seems it is about to stall out. After 10-15 seconds the secondary air pump will kick in and both lights are gone and the car will idle fine. From the other thread that was posted they said that coil packs are sensitive to high humidity which causes theses misfires and had their coil packs replaced by the STEALERSHIP. I do notice that this happens to me during high humidity days, and the car starts and does this rough idle. I just "blip" the gas pedal which makes the secondary air pump kick in and the idle smoothes back out. Unfortunately I haven't been to the dealer to ask about this, cause it hasn't happened since 1 month ago. I tried to scan for codes but no luck.
    Im not drunk officer...... im just dodging potholes
    Past: 98' A4 1.8t | 99' VW PASSAT | 00' A4 2.8 | 00' S4 | 04' TT 3.2 | 10' A4 | 12' S4
    Present: 01' VW GTI VR6 | 04' R32 DBP | 01' A4 Avant | 14' S4
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    Happened to me in my A5 around 3 weeks ago. I just turned it off and turned it back on. Been running fine since. It was around 3k miles when it happened.
    Jun 26 2010
    South
    I have experienced this with my A4 on numerous occasions, approx 3,800 miles so far. I definitely live in a humid city in the south.
    Jul 23 2010
    Boynton Beach FL
    My 09 3.2 with only 900 miles has just started doing it too! Ran so rough on start up I thought someone was shaking the car.
    Veteran Member Three Rings Cherub's Avatar
    Jun 20 2010
    Golf-R
    FL-Global
    Since buying the car a month in a half ago, I've noticed the whole car shaking and rough idle at cold start. Next Monday it's going in due to this persistent shaking. My car is at 11k+ miles and that is definitely annoying.
    MK7.5 R Daily
    B9 S4 (Pending Sale)
    2 B8.5 & B7 - Sold
    Tints & More..........
    Established Member Two Rings Spacecadet_CC's Avatar
    Oct 21 2004
    2001 Audi TT - 225 Quattro Coupe, Manual
    Winnipeg, Canada
    Definitely keep an eye on it to make sure but it sounds like what was discussed last year. Sounds like what I experience from time to time. It is definitely disconcerting to have happen as one expects this type of car to feel totally tuned at all times but the rough idle at startup is apparently known and deemed 'normal' or 'expected'.
    2013 S4 :: Lava Grey :: 6spd :: VMR710
    2001 TT - 225 Quattro Coupe :: Silver/Black :: 6spd
    IE Engine Rebuild :: STaSIS BBK front and back :: Defcons :: Haldex Comp Controller
    MadMax DV :: MadMax Control Arms :: turning this into a Targa Rally car
    Previous:
    2009 A4 Phant Blk/Blk, 6spd, APR :: 2004 S4 Silv/Blk, 6spd :: 2005 A4 Blk/Blk UltraSport, 6spd
    Feb 06 2010
    Quebec
    2.0T engine has been nominated as one of "ten best" engine in the industry by Ward. This problem belongs to a Lada, not on a brand new Audi for crying out loud.... I have a 1968 Beaumont and it has never run like that on startup, even on humid day! This hole thing is just a shame for Audi...
    Jul 12 2010
    Q5 3.0T
    crud... it just happened to me again today, for the third time. cold start though, and its not so humid outside, maybe my garage is humid?
    2010 A4 quattro, Tiptronic, Ibis White
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    It just started happening to me two days ago... thought it was just a one time thing but it did it again today... Gonna mention it when I take the car in this weekend for the high speed steering wheel shake....
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
    Feb 06 2010
    Quebec
    Car will be in monday morning, anxious to see what they'll find out... My hopes aren't too high.... Did any of you guys had to put in a liter of oil in the first 5000 miles ??
    Also, 1.5h to change the oil on this car? Is this correct or the service guy is lost in fog?
    Dec 02 2008
    2009 Quartz B8 A4 2.0T
    Long Guy-land
    is that to do a complete change (100%) of the oil, or merely top it off?
    Feb 06 2010
    Quebec
    Car is due for it's first service, so it's for a complete oil change. But 1.5h ?? AN oil change is usualy done in 30min or so, even faster on some car... why 1.5 h? Is there any parts uninstall involved??
    Senior Member Two Rings Für Deutschland's Avatar
    Sep 24 2009
    DUN GOT WUN
    Long Island
    i did, my stealership thought it was weird but no one else did. completely normal. the 1.5h is on par with my first service, i thought it was a little long also
    2016 Audi Q5 | Monsoon Grey
    Jul 12 2010
    Q5 3.0T
    Crap this problem is occuring more often than I thought. Happened again this morning at like 20 degrees, no humidity, cold start. I did floor it last night though to the redline. My friend with an 09 stasis flash never had this problem before
    Established Member Two Rings DB33's Avatar
    Mar 25 2010
    12 A4 Avant Prestige S-Line
    Scranton,PA
    I have this happen at least three times a week on a cold start. I just give it a little gas and it corrects itself. I will take it to the dealer next week and report.
    Senior Member Three Rings harry's Avatar
    May 09 2009
    The Valley
    Can you guys report miles cuz I haven't had this issue. However, I'm wondering if this is an early on issue or develops with later mileage.... or mileage doesn't figure.
    I'm also having the creaking clutch, but not sure if this will be reproducible at the dealership.
    12 K miles.
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    6,500 miles and not a problem with mine. only really drive it on the weekends and a lot of miles are from driving on the highway/freeway.
    maybe everyone needs to take it on high speeds once and a while??
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Jul 12 2010
    Q5 3.0T
    im at 11,500km and this happens like an average of once every 2 months? but happening more frequent now. my friend with his stasis flash havent even heard of this problem at 25,000km.
    could somebody please ask the dealer at their next service/visit and report back what do they have to say? does the coil packs really need replacing? I'm getting worried, this will look ugly if my passengers get in my car and it starts shaking frantically.
    Thanks
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    Happened to me once around 4000m after leaving car in an outdoor airport parking lot for 6 days.
    2010 A4 Avant
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    Never had the problem on 09 B8 (15K miles) and the 10 B8 with 2K has not experienced it either.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Dec 17 2008
    Charlotte, NC
    Quote Originally Posted by harry View Post
    12 K miles.
    There's a TSB for the creaky clutch, search the forum for it.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    May 09 2009
    The Valley
    Quote Originally Posted by AofC_RR View Post
    Yup, thx. I think NJned posted one. I'm not too worried about that. Just isn't frequent enough to be reproducible at the dealership right now. I'm gonna wait and let them cool off after replacing the control arms. I got my car back with the front bumper curbed and added scratches at the bottom of steering wheel. Anyhow.
    The startup is what I'm worried about. At first I thought there was something wrong too, but then realized that it was normal. My first 4 banger, and the engine idles loudly and ticks, while sometimes creating very DEEEeep bass at startup idle. Heard especially when the automobile is enclosed.
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Mine did this today for the first time. 95 degrees outside and humid. First start of the day, sounded weak and was hovering around 600-700 rpms. I stabbed the gas a bit and it went up then settled into the normal 1100 rpms like the ususal start up rpm range.
    weird.
    edit: I'm @ 14.5K
    May 09 2009
    The Valley
    Actually, come to think of it. This has happened to me. The car wouldn't start. I took the key and restarted just fine. I totally forgot, it was miles ago...
    Feb 06 2010
    Quebec
    Wow... this is turning out to be one of the most common known problem on B8...
    Senior Member Three Rings neptunesfinest's Avatar
    Jun 03 2010
    New Jersey
    I have the same problem sometimes. It happened this morning as a matter of fact. I never really worried about it since it always goes away fairly quickly once the engine warms slightly.
    Feb 06 2010
    Quebec
    Even if it's nothing serious, and it goes away on it's own, I still think it's much more serious than if something would break.... When something break, you usualy have a part of responsibility as a driver... maybe you pushed too hard or just didn't care... but this is a problem affecting probably well over 50% of all B8...
    I hope we'll see a serious response from Audi about this issue. It's must be corrected ASAP.
    Mar 02 2007
    Fresno, CA
    How you figure?
    Feb 04 2010
    Ottawa, Canada
    How you figure?
    I think we need a poll :)
