Results 1 to 11 of 11
    Active Member Two Rings extremeaudi's Avatar
    May 23 2008
    B6 S4, 330ci, 330Xi
    Las Vegas
    Transmission Control Module TCM Location??
    Can someone please tell me where the Transmission Control Module (TCM) is located on the B6 S4? I've read it's located under the ECU on the A4, but it's not that way on the S4. I've hooked up an amp and ever since then, I'm getting a U0101 code and engine will not start. Someone with some knowledge on the S4 please help me out.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    ive heard passenger side floorboard . not sure though
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Its inside the transmission. If yours is bad you need a new valve body and TCU
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    May 23 2008
    B6 S4, 330ci, 330Xi
    Las Vegas
    Ya, it is inside the transmission. It's at the dealer now and just needs a new TCM. It's only gonna cost $3300!!!! $2700 for the TCM, $500 for labor and $100 for oil and gasket. No more aftemarket electronics in the S4 for me. Guess I'll have to live with the crappy Bose amp and just upgrade the speakers.
    Established Member Two Rings ADynamics's Avatar
    Oct 06 2009
    Sprint Blue B7 S4
    Tri State
    Buy a whole new ZF 6HP-19 for that price!
    Jul 24 2008
    chicago
    Quote Originally Posted by extremeaudi View Post
    Ok before you spend that kind of money what fault code were you getting. These TCU's do fail but its rare.
    May 23 2008
    B6 S4, 330ci, 330Xi
    Las Vegas
    U0101. It happened after I hooked up a 0 gauge power wire to an amplifier in the trunk and connected the ground wire back to the battery and then would not start and showed that code. I dont see how it could of zapped the TCM from hooking up that one wire, but I have no choice but to pay it and have it fixed. I had it towed to an import shop in town and they told me it was the TCM and that Audi needed to order a new one and have it programmed because it was VIN specific and Audi dealer told me the same thing. It was the first time EVER that I had something wrong that I couldn't fix myself. I could have ordered the TCM and installed it myself but would still need to go to Audi to have it programmed! Now I have a sweet amp and subs to sell, because there not going in my car now.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Just ran into a similar issue. And I'm really looking for some kind of option outside of dropping almost $3k. Can you get a used TCM or transmission, and then have it programmed?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Or you could look into JHM's TCU tune.
    Old Geezer, formerly known as Stud Muffin
    Feb 06 2009
    328d, Tacoma
    Quote Originally Posted by QIKRNU View Post
    That's the thing though, if my TCM is fried, I doubt it'll take a flash.......
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Feb 06 2009
    328d, Tacoma
    Did you ever get this troubleshot down to a specific wire? or signal?
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
