I found the solution myself so I though I would post here for others. I went to see a friend of mine who is an Audi/VW mechanic.
He didn't have time to play around with me but he did give me his cable (Ross-Tech) and laptop. Took me a while to figure it out, but I was able to fix it.
Once you're all connected with VCDS go into [07] - Control Head Front, and then click on Adaptation. Then select Channel 11.
According to the Ross-Tech the setting for Channel 11 are as follows:
Channel 011: Additional MMI Options
+00001 = Owners Manual available
+00004 = Frequency/Source Change via Function Button active
+00016 = Driver Information System (DIS) installed
+00032 = Climate Control Comfort available
+00064 = Auxiliary Heating available
+00256 = AUX-IN installed
The initial value in Channel 11 for me was 4, adding 32 makes the new value 36. Therefore I replaced 4 with the new value 36, clicked Test, then Save.
I then turned off the car, and started it again, but to my disappointment this still didn't bring back the Climate control settings. My buddy suggested I reset the MMI, which can be done my pressing SETUP, BIG KNOB and top right soft button together.
Once I reset the MMI the Climate control settings were back!! :)
In summary:
- Go to [07] - Control Head Front
- Go to Channel 11
- Add 32 to existing value
- Test and save
- Reset MMI by pressing SETUP, BIG KNOB and top right soft button together.
