Originally Posted by
mr shickadance
just sayen, if you are an extreme audiophile then yes obviously there will be sound differences between the golf and the a4....then again if you were an extreme audiophile chances are you would not be rockin a 15'' sub as they produce more thump but with less accuracy and not a tight crisp sounding bass if you put it in chances are you wont be able to notice the difference because the difference from going with the bose stock 8'' sub to a massive 15'' will be so much more noticable you wont hear the difference between the golf and a4 trunk styles
be very careful when you are installing the amp and sub tho as you are running the bose set up chances are you will tap a speaker line that has a high power current going through it....you can do this and be fine but you will have to turn the gain setting on your amp allllllll the way down, and then start from the bottom and work yourself up to a bass you are happy with and will not blow out your sub
Hmmmm,
Well here's an update I took my Inphase Sub and Amp plus wiring etc to caraudiocentre. The engineer said no problem will fit it but you may need some hi/low gain wire (something like that, am not very technical so not sure what he meant but said okay) after looking at the amp he said oh you wont need the hi/low gain wire because the amp I had already had some sort of feature or wire with it that will do the job probably he said. So anyway he start fitting the sub amp and wiring it all up.
After around 1hr 30mins he's finished. He then leaves the boot open and walks upto the driverside door, turns on the car and cranks up the volume quite high. My fav dubstep track was the first one to play and the subwoofer was working fine and kicking out for about 10 seconds and the sub just stops kicking out. My first thought was "OH FUCK" lol, The engineer was baffled himself as to what had happened. He checked the wiring again and amp to make sure a loose connection was not the problem.
He could not find the cause of the issue, he then says maybe you need the hi/low gain wire thingy. He gets one of them out of the shop and fits it to the amp but still the sub is not working. I feared the worst and asked is it blown but he says no he cant smell anything because normally there would be abit of smoke and a burnt smell. He then removes the sub out of the enclosure and could not find any fault and says its likely the coil is messed up and would need to be re soldered because of a loose connection but that was impossible to do and the sub was now useless.
I was really annoyed because I kept feeling that it was his fault, maybe he turned the volume to hi or didnt use the hi/low wire earlier before he turned the unit on and blasted the volume. I then paid him for the install and he said get another 15" sub and he would fit it into the enclosure for free.
I have now ordered a new 15" sub because it will fit in the box that I have nicely. My only worry is that it might mess up again. Any thoughts on what could have caused the problem and what to do? should I go back and give him a black eye haha
Cheers ;-)
