Results 1 to 36 of 36
    Oct 31 2004
    Michigan
    Changed the fuel filter now its making noise when the fuel pump is priming.
    Yesterday I changed the fuel filter as a precautionary maintenance i didn't have any problems or noises with the old one. Now the new filter makes very loud and weird noises when the fuel pump is priming or when trying to start the car. Anyone else experience this?
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    Same here. No issues with the old one but changed it anyway since I was at 70K miles. Mine doesn't make any noise when priming, just when starting the car. Once the car starts, the sound goes away. The sound it makes is like a bad electric motor. I changed my fuel pump thinking that was the problem, but the sound is still there. I also thought I may have accidentally reversed the hoses, but it's on the way it should be. Thinking of replacing it again.
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    I had the same issue. According to an indy shop and the stealership, the filter was bad. Had it swapped and it's been fine ever since.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Feb 09 2008
    Had the same problem with one filter, cannot recall the brand. Went to OEM and all was fine again with no noise at start-up.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    That sounds like what was happening when I decided to change mine. When I would start the car I would get kind of a metallic, hollow, chugging sound from the fuel filter area. Changed the filter and the sound went away.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | PodiŽ | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Senior Member Two Rings SilvA4Q's Avatar
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    i cant remember the exact thread but someone said that the reason it makes that noise is because of the internal fuel regulator inside the filter itself. mine has been doing it for a couple months now and i've somewhat got used to it but at the next servicing i will definitely go back to oem. i dont think it is doing any harm to the fuel pump, just embarrassing when you have people in the car at startup, i just cough really loudly when its starting!!!!
    Current:
    '14 S4 Premium Plus
    ll S Tronic ll Glacier White ll Bang & Olufsen ll Sports Differential ll Black Optics ll APR Stage 1 ll CR-15 ll H&R Front and Rear Sways ll AWE Touring Exhaust ll Afe Cold Air Intake ll
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Actually funny you say that. THe aftermarket one is probably what destroyed my Bosch 040. It was restricting fuel pressure starving the injectors of fuel. How do I know that? On oem filter, I was able to handle my 71R eliminator setup. But after changing it out to the aftermarket one, my fuel pump had to pump a lot harder to get fuel pressure in the rail. On my oem pump + aftermarket filter, my car would detonate @ 12 psi of boost. So go figure. OEM wins.
    whoever designed those aftermarket ones need to put out a recall, they are destroying motors.
    OEM guys. Pass this on too, it's important.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 31 2004
    Michigan
    so what aftermarket brand is everyone running? The new filter i put in is made by Hengst and its making the noise. Anyone with OEM Audi and the noise?
    May 03 2008
    Orlando
    Mine was OEM Audi and made the noise. I figured it was just the sound an OEM fuel filter makes as it starts to die with over 80k miles on it.
    Kevin W.
    Oct 31 2004
    Michigan
    yours was old, i want to know from the people with filter noise from brand new filters, what brand were they oem or aftermarket.
    May 17 2010
    I just replaced mine a week ago with OEM straight from Audi. Was getting the loud hum from passenger rear side. I was hoping it was only the filter, but the noise is still there. I'm assuming fuel pump is on its way out so I'm going to replace that as well. If it stills hums like a bitch then I'm out of answers
    Veteran Member Four Rings jmw241's Avatar
    Feb 23 2009
    Cranston RI
    Quote Originally Posted by RottieA4 View Post
    I got the OEM filter aswell. I get the hum you speek of. I think it's normal, or hope so.
    -Justin
    Current Cars: 07 Sprint Blue RS4 Cab,
    Old Cars: | EURODYNE Maestro | GTX-3071| B6 A4, Brilliant Black b6 S4, Phantom Black B7 A4
    07 Sprint Blue DTM S4, 12 Candy White Golf TDI
    Oct 31 2004
    Michigan
    do you guys get the hum as the car is running? i only get a beeping/chirping noise when the fuel pump is priming or im starting the car thats it, once its on its quiet
    May 17 2010
    I dont think its normal, because it has progressively gotten worse. From what I've gathered, it is the fuel pump working under heavy strain, producing the noise.
    May 17 2010
    Quote Originally Posted by dan4g63 View Post
    Ya only when its running. It goes through the priming stage without incident, but once running it produces the high pitched whine/hum. With the windows up and radio off its really noticeable, even when standing outside of the car.
    Feb 09 2008
    How many miles do you have? It sounds like the pump is giving you a 'heads-up' that it's about to go. Mine did not do that, it just died at about 68K.
    Jun 11 2005
    No it's not normal. The fuel pump should be silent. Those who still have the hum or a louder hum after you replace the fuel filter can be praying for a new pump. Because that's what's going to go out. THe Aftermarket filter (mine is Hengst) made that really loud rasp/humming noise upon startup, then it would go away.
    F*ck this. I'm not going to blow my 044. I'm going to switch it back to oem.
    Just to clarify OP, You and I are talking about the FILTER making the noise right? NOT THE PUMP. My pump is fine. it's an 044 and it's going to be loud, but I'm okay with that. we are talking about the filter (brand new filter) with a sufficient pump (semi-new or new oem pump, or other aftermarket fuel pumps).
    2003 1.8T
    May 30 2008
    Ashburn, VA
    I installed an OEM filter and the filter was making the sound. Will be replacing it again next week.
    Oct 31 2004
    Michigan
    Yes its the filter that makes the noise not the pump and its not a hum, its a beeping/chirping ONLY when the fuel pump is priming or the starting the car.
    Apr 14 2010
    San Francisco
    I've just replaced my fuel filter that i got from the dealership item#8E0-201-511-L and mines making some rattling noise n getting some vibrations from where the filter is. I gave them my vin in hope to get a correct one so i doubt i got the wrong one. Even my engine check light began to flash
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Quote Originally Posted by A4 Moda View Post
    just for another experience, i replaced my fuel filter about a year and half ago with an OEM filter i ordered from ECStuning. i didnt notice much humming prior to changing it, but noticed it after. its always been apparent since then. recently i noticed the same weird sounds, mechanical like, from the filter/pump area. its been well over a year and i havent had any problems engine wise, boost wise, etc. i have taken the car on a long trip and put probably close to 15k miles on the filter since then.
    im thinking of changing the filter and seeing if that makes a difference, but it may not since i used OEM in the first place and have had the symptoms since then. just a thing to consider.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Oct 31 2004
    Michigan
    UPDATE:
    So i returned the Hengst filter and bought one from the dealership and no more noise. Just to clarify i never had a hum from the fuel filter when the car is running, its was a beeping noise only when the fuel pump was priming or i was starting the car. Maybe i had a bad aftermarket filter i dont know.
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    Do you have the part number of the filter you got from the dealership? I think it's time to replace my Hengst with the correct OEM one.
    Current:
    '14 S4 Premium Plus
    Oct 31 2004
    Michigan
    For my 2003 the part number is: 8E0-201-511-J
    May 27 2009
    '17 Audi Q7 3.0T P+
    Houston, Texas
    dan4g63 - did the filter that you bought from the dealership not say Hengst on it? Was it different? The reason I ask is that I bought my fuel filter from AutohausAz and the part number for the filter i received is identical to the one you listed above. Is it possible that the part numbers will be exactly the same but the item itself is actually different? I might just get under the car and see what my filter says because the website says that Hengst was the oes for the filter so the should be the same.
    Current:
    '14 S4 Premium Plus
    May 03 2008
    Orlando
    Quote Originally Posted by SilvA4Q View Post
    I actually took a picture of the filter I got from the dealer:
    Kevin W.
    Oct 31 2004
    Michigan
    The OE Audi filter is not made by Hengst, its just like in the picture kwimberly posted. I think KYG is the brand. And yes they all carry the same part number you have to watch for who makes it and make sure it says "original equipment" or just get it from the dealership, suprizingly it was cheap at the dealership i went, "only" $50. The aftermarket Hengst was $45.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    I was told by a VW/Audi master tech to never use anything other than OEM fuel filters... changing mine soon too.
    Mar 05 2013
    CA
    I changed the fuel filter, with Mahle KL858. eBay, made in China.
    The dealer calls for 8E0 501 211 J
    But this one is 8E0 501 211 G
    (Both 4-prong w/ internal regulator)
    Upon key(on) and priming, there's a loud noise like a bad electric motor or something.
    Knockoff filter? Sub-OEM quality?
    I've read this is the sound of the pump straining.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by Spike00513 View Post
    I did this on my wifes car as it sounded like a sewing machine when starting and running, now on part throttle cruising it sounds like its humming and the new filter I installed was apparantly OEM or OEM supplier and was purchased locally, it came in the same white box and no stamping like the genuine one I bought from ECS for my B6 which doesnt make noise.
    spike the G suffix is for a fwd, im not sure what the difference is, they both look the same and some places list the same # for fwd and quattro.
    Mar 05 2013
    CA
    Quote Originally Posted by seanf86 View Post
    L, which was superceded to G, is quattro AFAIK. And G, being FWD.
    Their site lists the filter, as fitting quattro though. IDK why the difference. Internal regular pressure difference or something?
    I'll take a video of pre-start prime. But other than that, I don't think I can hear any noise. I'll lift the seat, and try to listen to the pump, and listen+feel the filter, to see if there's any noise.
    There were a few times where the engine felt like fuel was cutting out.
    Feb 27 2011
    Winnipeg
    Interesting to know that they superseded the quattro filter to fwd as last I checked ecs had diff #s still listed.
    Edit Looks like J is quattro and L is fwd according to ecs
    Jun 27 2011
    I bought a Hengst brand filter a few years back to replace my oem filter because it was making walrus noises on cold starts. That worked great for two weeks then sounded even worse than before. I then bought an OEM one and the sound went away immediately and never came back. I did eventually replace my fuel pump though because it started making chirping/whining noises while driving. I decided I didn't want to wait until it failed and would prefer to just presumptively replace it.
    I cant comment on the part number predicament, but personally I wouldn't trust an off brand filter because I don't think the regulators are built to a high standard. I would go OEM from a trusted source like GAP.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings USAF Long's Avatar
    Nov 05 2010
    Salt Lake City, UT
    Good info. Guess I'll just go order one at the dealership since I don't want to deal with this bullshit.
    - Scott Long -
    2002 Audi A4 1.8t Quattro - 5-sp | 3M Wrapped | Test pipe | Custom Exhaust | Tint | 19" Staggered Wheels |
    Aug 19 2013
    minnesota
    My pump sounds like a sewing machine when I let the fuel pump Prime. I was thinking my pump is going out?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by jacobsen View Post
    could be, or a bad filter. My wifes car is still making noise, not sure I want to gamble it being pump or filter and spending money on one when its the other, going to try a used pump from the wrecker for trouble shooting since its only $25 and go from there.
