The receiver/dryer must be replaced because it's function is to absorb moisture from the system that happens to get into the R134A. As soon as the system is opened to the outside air, the chemical inside the receiver/dryer absorbs moisture from the surrounding air, and becomes water saturated, unable to absorb any more water. If reinstalled into a repaired system, the R134A that is new and fresh, will be contaminated with water from the used receiver/dryer unit. Water moisture in the circulating R134A, will freeze at the evaporator expansion orifice, and block the flow of R134A, reducing the cooling capacity of the A/C system severely.
To flush the system, you must use an A/C system flushing solvent made specifically for this purpose, compatible with the synthetic compressor oil in the system. A compressed air nozzle that has a liquid suction tube to draw up the solvent and mix the solvent with the air at the spray nozzle, is used to blow the solvent through the system cleaning the old compressor oil and any particles from the failed compressor from the hoses, tubing and evaporator and condenser cores. The solvent should be blown through the system in both flow directions, forward and reverse.
"The 134a is not circulating. I found the ac compressor seized. The compressor, receiver/dryer, all seals, and restrictor will have to be replaced. All the hoses will have to be flushed of compressor debris."
Yeah, the quoted comment above is correct. Since the compressor was seized that started the problem, make sure the replacement compressor has a new drive pulley installed on it.
I recommend you have the system evacuated and recharged by an Automotive A/C repair specialist.
