Results 1 to 28 of 28
    Mar 13 2008
    02 1.8t a4
    caribbean
    help needed for turbo upgrade?
    guys i have the B8 a4 1.8t 2008 model that has the 1.8t FSI engine i installed an ecu upgrade from super chips and it works great actually feeling the increase Hp and hearing the turbo a little more however i think i need a little more power so the rep from super chips recommended i up greade my turbo to the T4 and injectors to the S4 can anyone point me in the right direction to attain these parts? and do you reccomend i up grade my intercooler?
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    lets start with punctuation...
    Veteran Member Three Rings wildbill's Avatar
    Jan 25 2010
    work
    wow you dont know your own car? its a 2.0 fsi, half of your problem is superchips, giac or apr make the best off the shelf tunes....you need to start researching before talking about T3/T4, start with a stage 2 flash...apr you will need to mod your fuel pump, a free flow, and some real brakes...the stage three can make roughly 350...btw b8 wasnt out until 2009
    boost. a new band aid by Johnston&johnston
    Mar 13 2008
    02 1.8t a4
    caribbean
    bro my car is the 1.8t fsi engine
    Jan 25 2010
    work
    they ended the 1.8 block with the b6, so youre wrong in four places, the fact that you got superchips shows your credibility, ZERO bro!
    Mar 13 2008
    02 1.8t a4
    caribbean
    take a look at this link and you will see the model they bring for us in the caribbean http://paultan.org/2008/06/27/audi-a...ed-in-malaysia
    we always get the lower end models here bro
    Veteran Member Four Rings ThePiombino's Avatar
    Dec 01 2008
    North JerZ
    Quote Originally Posted by wildbill View Post
    Thought the 1.8T was available outside the US
    09 A4 2.0T Quattro - Tip - Black/Black /// MODS: APR Stage II+ | AWE CB Exhaust | 034 HFC l EC HFIC Pipe | Forge DV Spacer | 3M Di-NOC Carbon Fiber Interior Trim | 3M Chrome Grille Trim | SG Supreme 28 | Debadged | Fly Eyes Kit (f&r) | Needle Sweep | Window/Moonroof control w/Keyfob | Seat Belt Chime Disabled | "Wink" Disabled | Double Unlock "Beep"
    Mar 13 2008
    02 1.8t a4
    caribbean
    nd i am from trinidad and tobago which is in the caribbean
    Jan 25 2010
    work
    i wondered that when i saw caribbean, from that i would find a good shop
    youre going to be limited on tunes, best bet is a custom tune by a reputable shop with an awd dyno
    i would say a gt 28 is a good bet, anything more and its not a DD or daily driver
    its ball bearing and much larger than factory, but creates lag and may need a bottom end pending how aggressive the tune is
    check out awe for a fuel pump upgrade, 034 and apr make great cat deletes, exhaust on the b7 and b8 dont need to be changed
    injectors pend tune, youll need a new manifold...new diverter valve would be a must
    Mar 13 2008
    02 1.8t a4
    caribbean
    from reading up the car comes with a ko3 water cooled turbo produsing 160 horses with the superchip re map i am getting 214horses would this turbo your reccomending give me around 350horses?
    Jan 25 2010
    work
    28 easily, tht superchips number is bogus, giac and apr are the accurate ones. idk if anyone makes tunes for your special car
    Mar 13 2008
    02 1.8t a4
    caribbean
    can you reccomend a one stop dealer to provide me with this ?
    Jan 25 2010
    work
    in the caribbean, no. us...yes!
    Mar 13 2008
    02 1.8t a4
    caribbean
    in the us will be fine
    Jan 25 2010
    work
    awe should do custom tunes. black forest industries and absolute automotive in North Carolina. AWE is near philadelphia pennsylvania. euro tech of atlanta in Georgia should, but i know for a fact absolute does some legit work, pm me if you want adresses
    Mar 13 2008
    02 1.8t a4
    caribbean
    the 2.0tfsi and the 1.8tfsi carry the same K03 turbo so would the K04 work in both cars?
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    notice how he didn't get all in your face and insulting when it turns out he was right and you were ...dare I say...wrong?
    what's with the douchebaggery. good help afterward, anyway
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    ^lol
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hόper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Jun 02 2009
    San Francisco
    "ZERO Credibility!"
    Oh the irony.
    Trolls can be very entertaining.
    Senior Member Two Rings Audi_A5's Avatar
    Apr 28 2008
    Belgium
    I'm also loking into this, also ave the 1.8T engine and looking for a turbo upgrade.
    I Saw that APR is coming out with a K04upgrade, it might be that the turbo would be interchangeable as several products for the 2.0 also fit the 1.8
    SOLD - '09 A4 B8 Ibis White - AWE cat-back / H&R / S4 Titanium grill / Carbon Interior / 19" BBS LM F8.5 R9.5 / JD-Engineering ECU
    CURRENT - '11 Audi A1 8X Phantom Black
    Mar 13 2008
    02 1.8t a4
    caribbean
    seeing thet the turbo on both cars come with k03 borgwarner do you guys think the K04 borgwarner with fit plug and play?
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    I think i read on APR's site that the 1.8T offered in the ROW B8s is actually a de-tuned 2.0T... so get APR. Of course i have no idear what Superchips tune is and/or how it compares to APR...but I can readily admit that on here as i am a nub!
    And you got to love a know-it-all eating a nice old slice of humble pie! heh
    Mar 13 2008
    02 1.8t a4
    caribbean
    does APR offer an upgrade to the K03?
    Active Member Four Rings CrtchRktRcr's Avatar
    Feb 25 2009
    CRF50
    Scottsdale AZ
    haha now say you're sorry! do it.
    AEB B5 A4, QUATTRO MANUAL SPORT-H&R,FORGE,1BAR,5BAR,BOOM
    xbox live: Cr0tchf4i
    ["im in the computer lab and some dude with about 8" just sat down next to me -S4Jet"
    WWW.ASKMY2CENTS.COM
    May 26 2009
    Houston, TX
    False.
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Quote Originally Posted by advocate View Post
    Yes.
    http://www.goapr.com/products/ecu_up...8tsi_long.html
    The ko4 we will soon offer for the 2.0 TSI will fit on your 1.8TSI but I am not certain if and when we will have a calibration to support the turbo upgrade for your 1.8 TSI.
    Apr 28 2008
    Belgium
    Quote Originally Posted by Keith@APR View Post
    THis is some very exciting news! It would be good if this would be available withoug ECU upgrade, so we could have a custom tune done if we have other parts installed (exhaust, HFC, intercooler)
    But would our stock OEM clutch be able to handle all of the power, of would it be wise to upgrade to a DXD clutch?
    Mar 13 2008
    02 1.8t a4
    caribbean
    keith do you have a part no. for the K04 turbo that can be used?
